Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Mitsibushi WD-52525 almost horizontal red lines that appear to be streaming from top to bottom on the screen are driving me this going to be one of those cap replacement issues that i have been reading about on this site ...?
  • 39 Answers
Re: mitsibushi WD-52525
Yes if the lines are on all inputs and also on the menu of the set itself then you may want to test your 5 volt power supply on plug j19 of the lite engine.this does require removing the back of set along w/the back shield,about 30 screws.good luck joe tv
Posted on Nov 16, 2007
0 characters
3 Points
Wd-52525 vertical lines on screen
Your reference to across the screen to me means horizontal. Check the bias on the video drive, there may be a potentiometer on the board to adjust. The new parts may have picked up the drive, turn it down if possible.
Mar 15, 2010 | Projection Televisions
Green horizontal lines on screen no picture
The green CRT's (color picutre tube or color wheel, or ballast) will need to be tested for replacement.
It is quite common with these tv's
You will need an ohmmeter and or voltmeter and test each component for currency and accuracy
May 06, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi DLP WD 52525 has small green lines on the screen
do the lines go from top to bottom, and are they about 1 inch apart? or do they move diagonally across the screen?
Dec 27, 2008 | Mitsubishi WD-52525 52" Rear Projection...
H Lines on the left side of the screen
just in case you came across this - it is the light engine! $950 - thanks mits for complete junk
Oct 13, 2008 | Mitsubishi WD-52725 52". Rear Projection...
Mitsubishi WD-52525 with green horizontal lines
You need to replace the capacitors on the FMT PWB this is a common problem with the V26 chassis which is what your model number is. They have some bad capacitors that need to be Changed. There is a repair Kit available for the FMT repair.Let me know if you would like the link for the repair Kit. Please respond to this same post if you do want the repair kit which does involve soldering.
Jul 09, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Flashing Horizontal, Circuluar, Colored Lines
sounds like bad capacitors on the FMT board need replacing that is a common fault with the first generation DLPs There are 3 bad capacitors.
May 31, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Screen Noise
replace DM or try to fix it.
Jan 03, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Red lines, green lines, now static!
Uneven colors with multicolored lines in the center of the picture and/or flashing, C9A37 and C9A38 both 3300 UFD 10 V part # 181P732040 on the Power PCB (part # 930B921002)
Nov 27, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Wd 52725 mitsibushi dlp
Do self diagnosis test by pressing input and menu on set at the same time for 5 sec. It should blink a 2 digit code. Remember code and let me know.
Oct 28, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
54 people viewed this question
Top Mitsubishi Projection Televisions Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Projection Television Expert? Answer questions, earn points and help others
