Question about Boating
Fluid shooting out of filler plug - Boating
How do i check the transmision fluid on my 2011 kia sportage
Its not simple, but can be done.Idle the engine for around 15 minutes to get transmission up to temperature. Lift the front of the car and remove the under tray. Locate a filler plug towards the lower edge of the valve body cover. While the engine is idling in Park remove the plug. If fluid runs out there is sufficient fluid. If no fluid runs out, add fluid through the filler until it runs out. This will leave the fluid at a minimum level, to get it to maximum level you must add another 700ml through the breather. Refit the filler plug, switch off the engine, remove the banjo fitting at the top of the cover, and add fluid through this hole. Check for leaks and refit under tray. Lower vehicle to ground
Sep 25, 2014 | 2011 Kia Sportage
How do i check fluid for convertable top
"How do I get the air out of my hydraulic system"?
  • Remove the reservoir plug on the motor pump. Leave the plug out and do not put back until you have finished.
  • Fill the reservoir 3/4 full with fluid (to the bottom of filler plug hole). Put a rag under the hole to catch overflow that will occur as system fills.
  • Run the pump for 15-20 seconds. Stop. Check your fluid level and refill to bottom of filler hole. Continue running the motor in the same direction for an additional 15-20 seconds. When the top gets to the end of cycle, check your fluid level, fill to bottom of filler hole, and run the motor in the opposite direction.
  • You are literally running the top all the way up and down sereral times. Checking the fluid level as you go and fill as required, leaving reservoir 25% empty.
  • When you are no longer able to add fluid, put the top in the down position. Check the fluid level one last time, should be to bottom of filler hole. Put the plug into reservoir.
  • Apr 01, 2012 | 2004 Ford Mustang
    What type of trans. fluid does it take and how do i know when its full
    Transmission Fluid Fluid Level Checking & Filling To Check:
    1. Connect a scan tool to the vehicle to read ATF temperature. ATF checking temperature should be 95° - 113°F (35° - 45°C).
    2. Start the engine.
    3. Raise and safely support the vehicle.
    4. Place a drain pan under the transmission.
    5. Allow the ATF temperature to reach 95° - 113°F (35° - 45°C). Automatic transmission fluid inspection plug vw-07-00-7273.gif
    6. Remove the inspection plug from the transmission housing. Fluid is pipe will run out. If fluid continues to drip out, no additional fluid is needed. If only the fluid in the overflow pipe runs out, additional fluid is needed.
    To Fill:
    1. Pry the cap from the filler pipe. The cap locking device will be destroyed during removal.
    2. Pull the plug from the filler pipe.
    3. Add fluid slowly with VAG 1924 or equivalent until fluid runs out of the inspection hole. Install the inspection hole plug.
    4. Install the plug in the filler pipe and secure with a new cap.
    Jan 28, 2011 | 2000 Volkswagen Jetta TDI
    How do you change the transmission fluid on a 2002 ford explorer, v8
    Look on pages 269 and 270 of the owners manual.
    Checking and adding manual transmission fluid (if equipped)
    1. Make sure the vehicle is on a
    level surface or level hoist.
    2. Clean the filler plug or dirt and
    debris.
    3. Remove the filler plug and
    inspect the fluid level.
    4. Fluid level should be at bottom of
    the opening.
    5. Add enough fluid through the
    filler opening so that the fluid level
    is at the bottom of the opening.
    6. Install and tighten the fill plug
    securely.
    Use only fluid that meets Ford specifications. Refer to the Lubricant
    Specifications in this chapter.
    Nov 13, 2010 | 2002 Ford Explorer
    WHILE DOING AN ENGINE OIL CHANGE I DRAINED THE AUTO TRANS FLUID BY MISTAKE. HOW DO I RE'FILL THE TRANS ?
    To Fill:
    Aug 17, 2010 | 2003 Volkswagen Jetta TDI
    Where do you check the transmission fluid
    It's synthetic fluid and there is no dipstick , transmission sealed.
    How to check fluid:
    Warm up engine , raise vehicle on the lift with engine runing on park position , unscrew drain plug (don't warry it has tube in there ), if you see fluid coming out for 10-15 sec.- level is ok.
    If nothing coming out - level is low.
    There is a filler tube in front of the transmission with the red cap and red plustic sealing clamp.
    If you able to take clamp out without braking it , you can reuse it after.
    Fill transmission through filler tube with engine runing
    and trany on park position , till fluid starts runing from drain plug , reinstall drain plug , reseal filler tube.
    NEVER TURN ENGINE OFF WITH TRANSMISSION DRAIN PLUG UNINSTALLED !!!!!!!!!!!
    Jun 06, 2010 | 2000 Volkswagen Beetle
    How do i inject the transmission fluid in the transmission
    there is a small filler neck in frt. of the trany , with red cap on it. Brake the cap , there will be a plug under.
    Proccedure : engine on idle , take of plug at the bottom of trany oil pan(with engine on idle!!!!! , if engine off , fluid will leak out) , use transfering pump to pump oil in to filler neck untill it starts leaking from bottom plug , wiat till it only drips , put bottom plug back in and torque it. Now you can shut engine off and seal filler neck.
    Use only approved trany fluid .This trany takes syntetic fluid.
    Apr 22, 2010 | 1996 Volkswagen Jetta
    How do you change manuel trans fluid in a 1995 toyota paseo
    On the transmission underneath the car there are 2 bolts that dont hold anything onto the transmission. One is the drain plug (closest to the bottom), the other is a filler plug (usually around midway up on one side), drain all the fluid from the drain plug, then after installing the plug pump the new fluid into the filler hole until it starts to spill out, install filler plug. Easy as pie. Same procedure for front and rear differentials. Make sure you are using the manufacturer recommended fluids.
    Jan 20, 2010 | 1995 Toyota Paseo
    Need to put transmission fluid on my its stick
    there are 2 bolts on the transmission underside that are not connecting anything to the trans. itself. One is a drain plug at the bottom, the other is a filler plug on the side. remove filler plug and pump in fluid until it starts to leak out from the filler hole, re-install filler plug and you are all done.
    Jan 20, 2010 | 1997 GMC Sierra
    Gear OIL in Daewoo Leganza SX manual transmission
    CHECKING FLUID LEVEL
    1. With the vehicle on a level surface and the fluid in the transaxle cold, remove the filler plug and check the fluid level. The fluid should come to the bottom edge of the plug hole.
    2. If the level is low, add SAE 80 manual transaxle fluid through the filler plug hole until the fluid begins to run out.
    3. Reinstall the filler plug and tighten it securely. The speed gears and the synchronizer parts on this vehicle receive lubrication through specific passages in the mainshaft. It takes 1.8 liters (1.90 quarts) to fill the transaxle completely.
    its located next to drive shaft some on left hand side others on right hand side depending what gearbox.
    May 30, 2009 | 2000 Daewoo Leganza
    Boating Logo
    64 people viewed this question
    Top Boating Experts
    Steve
    Steve
    ray gallant
    Fabrice Wolters
    Are you a Boating Expert? Answer questions, earn points and help others
