Question about Campagnolo Cycling
Replacing a carbon rod on 11sp super record
I have a damaged rear deraileur carbon rod which needs to be replaced with a new carbon rod. Is there a special tool and or method to do this? Many thanks
No, this is one of the easiest jobs I have ever done!
  • Simply remove the cable from the carbon rod, and
  • Insert a Torx T-20 in the lower end of the brass pivot, and
  • They unscrew easily and you can then remove the carbon rod entirely.
There are no springs to fly out - they're attached to the lower alloy part - and no spring tension to cause problems. Then:
  • Remove the cable stop attachment and move to the new part, and
  • Rmove the the two limit screws (if they didn't come with the part), and then reinstall on the new part, and
  • Finally reinstall the new part on the derailleur base.
  • Then re-connect the gear cable to the new part, and
  • Reset the limit screws following Campagnolo's instructions very closely, see http://www.campagnolo.com/AU/en/Support/download_2?td=4 for the manual you need.
This was a very easy job indeed - and like you, I was very apprehensive knowing how tricky some Campagnolo repairs can be. Clearly this was envisaged at the design stage and well-implemented. Now if only the part was more readily available...
Posted on Mar 04, 2015
3 Suggested Answers
  • 82 Answers
SOURCE: I've just replaced my rear deraileur but now the
there are 2 screws that limit the movement of the derailer and you can loosen or tighten the cable.
Posted on Mar 14, 2010
emissionwiz
  • 76164 Answers
SOURCE: What are the differences (geometrically) between
What exactly do you need to know in plain English, please provide make and model number and what this device is. Thanks
Posted on Feb 04, 2011
Toro mower over heats
If you're Toro electric blower is slowing down, throwing sparks, overheating or not starting you may need to replace the carbon brushes. Replacing brushes and cleaning commutator early can prevent damage to motor armature!
There are Electric Motor replacement carbon brushes on E-bay for all three motor sizes (7 AMP, 10.5 AMP, and 12 AMP) of Toro Leaf Blowers (Toro Rake and Vac Super and Ultra Blower and "850" Vacuums)
Search E-bay for: "Toro Blower Carbon Brush"
- 12 Amp leaf blowers Toro Super (Old model 51552) through Toro Ultra (New model 51609).
- Toro 850 Super Blower Shredder-Vac 12 Amp (model 51575).
- 10.5 Amp leaf blowers Toro Old through Toro New model 51573.
- 7 Amp leaf blowers Toro model 51586 and other Toro 7 amp blowers.
Jul 10, 2014 | Toro Lawn Mower With Toro Power Tools
Why will my toro 5198 leaf blower not start?
If you're Toro electric blower is slowing down, throwing sparks, or not starting you may need to replace the carbon brushes. Replacing brushes and cleaning commutator early can prevent damage to motor armature!
Jun 28, 2014 | Toro 51599 Electric Blower 12 Amp
Motor won't turn on
There are Electric Motor replacement carbon brushes on E-bay for all three motor sizes (7 AMP, 10.5 AMP, and 12 AMP) of Toro Leaf Blowers (Toro Rake and Vac Super and Ultra Blower Vacuums)
Apr 14, 2014 | Toro 51599 Electric Blower 12 Amp
Toro model 51575. Was using it as a vacuum and it just shut off. Checked breakers ...all ok. Plugged it in direct to outlet and still nothing. What might be the problem?
Apr 06, 2014 | Toro Blowers Rake and Vac - Electric...
Blower does not turn on
Apr 03, 2014 | Toro Garden
Snow blower shorted out
Feb 17, 2014 | Toro 51599 Electric Blower 12 Amp
Motor was losing power and burning
Jan 13, 2014 | Toro "Toro" Super Blower/Vac
Problem is my hardly used Toro Blower Vac is getting no Power
If it has not run for awhile, check the brushes. they might need to be replaced. The plug is usually moulded right on power cord. That might have to be replaced because if there is a problem with a broken or disconnected wire right at plug there is no way to see it. Hope this helps.
Dec 07, 2010 | Toro 51599 Electric Blower 12 Amp
Cycling Logo
126 people viewed this question
Top Campagnolo Cycling Experts
John Egan
John Egan
Are you a Campagnolo Cycling Expert? Answer questions, earn points and help others
