Question about GE WHRE5260E Top Load Washer
Washer will not stay on - GE WHRE5260E Top Load Washer
Washer making a clicking sound, the tub isnt draining, and the add a garment stays on
Door switch isn't making. .if door isn't closed the washer won't run and will have the add garment light will stay on.
Oct 04, 2014 | Kenmore HE2 Plus Front Load Washer
Husky power washer won't stay on after I start it
low oil pressure switch faulty or oil level low, disconnect pressure switch then try.
May 14, 2014 | Homelite For Husky - Pressure Washer Pump...
Must manually switch cycles
washer machine will stay in one cycle and continue to operate without automatcially changing cycles
Jun 26, 2012 | Frigidaire FWS833A Top Load Washer
Washer reads dL f and door stays locked even
try to start another cycle then hit cancel and cancel again and it usually unlocks the washer
Apr 24, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washer rocks and will not stay put. Perfectly level
check to see if the shocks are broken, 4 of them. A service guy fixed mine with new ones
Aug 29, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer want stay running. I can pull choke and it
mr fixit, I have pressure but it just want stay running
Jul 11, 2009 | Garden
Washer bottle warning light stays on
the sensor for the washer bottle level is in the washer bottle simply unplug the sensor located at the washer resavor and the light will go off then replace sensor
Jan 08, 2009 | 1997 Ford Probe
Balance
No washer will stay balanced.
but if the feet on the bottom are not solid on the floor. or the rubber feet have degraded/hardened it will bang the washer side to side with all loads.
if you can lean on the washer while it is spinning and that quietens the noise then it needs the feet adjusted or replaced.
Jan 23, 2008 | Maytag Atlantis MAV6000 Top Load Washer
GE WHRE5260E Top Load Washer Logo
24 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
