Question about Maytag MFI2568AES Stainless Steel Bottom Freezer French Door Refrigerator
Remove freezer trays in maytag refrigerator freezer bottom freezer
  • 159 Answers
SOURCE: Maytag MFD2561HEQ Bottom Freezer Refrigerator - Freezer working, refrigerator not
Marc of Nc. check to make sure the fan in the freezer is operating when the compressor is on. The only thing the fresh food section gets its cool air from is the freezer. and if the fan is not operating no cold air will get up there. If the fan is running you need to make sure the air duct is not blocked with frost of the evaporator is not iced up. Check that out and get back with me if there still is a problem. Good Luck
Posted on Aug 06, 2007
SOURCE: Bottom of Maytag Freezer Ices Up
I just had the Maytag repair man out and he wanted to replace to parts after defrosting the freezer. Over $300. He did not have the parts with him. Soooo... I am now in the process of using a hair dryer, even tough it is 107 here today. Ice was totally covering the coils under the back panel in the freezer. Easy to take out. Just remove the shelves and you will see it. If you don't totally get all the ice out it will build up even faster. He claims this will give us 2 weeks or so while the parts on on order. I now have all the ice I can see removed, I just hope it is out of the tube above the coils. I have all my food, lots of good steaks, I want to put back in the freezer. The original problem seemed to be the refrigerator was not working but the freezer seemed to be. Well, it just faked me out because it was just a fan or ?? I heard in the freezer. Wish me luck...MJ
Posted on Aug 31, 2007
  • 1462 Answers
SOURCE: MY MAYTAG REFRIGERATOR
remove back panel inside freezer and there is a tray at the bottom with a drain hole in the middle. this is blocked with ice. melt off with a hairdryer and follow up with hot water till it flows waay freely
Posted on Oct 02, 2008
alex_salve
  • 78 Answers
SOURCE: maytag side by side refrigerator ice forms at the bottom of freez
DEFROST THE FRIDGE BY SWITCHING IT OFF FOR 2 DAYS
Posted on May 25, 2009
  • 16 Answers
SOURCE: Maytag refrigerator clicking noise and stopped working
either inside fan out of alignment or defrost timer could be bad
Posted on Jun 02, 2009
Maytag icemaker drips dirty water onto existing ice ini tray.
please check or install screen filter in the water valve at the back beside compressor
Jan 15, 2014 | Maytag AFD2535
Maytag msd2758ges ice maker squirts water
Sounds like the water solenoid is not shutting off cause once the tray fills it should stop sending water located in the back bottom with the water lines connected
Mar 24, 2013 | Maytag MSD2756GES Side by Side...
Refrigerator won't cool but the bottom freezer works
under bottom shelf there are air inlets to fridge take out tray clean ice frominlets
Jul 22, 2012 | Maytag MFD2560HES Bottom Freezer French...
Mr refrigerator leaks water out of the front of the machine on the corners, the bottom tray is solid ice. The model is MBF2255KEB with the freezer on the bottom.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Mar 17, 2011 | Maytag Refrigerators
Ice maker not making ice
check the water solenoid for the ice maker on the back
Jun 11, 2010 | Maytag MFI2266AES Stainless Steel Bottom...
Ice freezing up on bottom of freezer and water puddles in front
Two possibilities, ice maker leaking or the defrost drain is blocked with ice or another object. Unplug the freezer and remove the rear panel in back of freezer. At bottom of the evaporator coil is a tray that catches the defrost condensate and sends it to the pan beneath your refrigerator to be be heated by the compressor and fan heat produced from the condenser. The moisture is then returned to the air inside your home. If the drain is blocked with ice or anything between the freezer and the pan below, the condensate tray will overflow will end up inside your freezer or fresh food compartment. Questions? I will be here to help you, Let me know, Sea Breeze
Jun 23, 2009 | Maytag MSD2758G Side by Side Refrigerator
My Maytag side by side (no icemaker) keeps leaking water under the freezer side front roller area. Ice is forming on the inside bottom of the freezer under the bottom basket. I've vacummed underneath and...
OK, You need to unplug for a hour or so. Remove the rear panel in back of freezer to expose the evaporator coils. At the bottom of the evaporator there is a tray that catches the defrost water to take it through the back and down to the condensate tray located near compressor and condenser fan. Most likely you have ice or something trapped in that drain beginning in the freezer. I have heard some people turn the freezer temperatures so cold ice will form before the water can drain. If you still have problem contact me. If this helped vote or rate me. Thanks Sea Breeze
Jun 22, 2009 | Maytag MSD2732GR Side by Side Refrigerator
Oct 02, 2008 | Maytag Refrigerators
Ice build up on bottom of freezer
remove back panel inside freezer. you will see drain tray at bottom with a drain hole in the middle - this is blocked usually with ice. melt off with a hairdryer and follow up with hot water till water flows away freely
Sep 25, 2008 | Maytag MSD2732GR Side by Side Refrigerator
THE ICE DOOR PROBLEM
Budd, if you want to stop the flapping until service shows up to replace the high voltage board do the following: remove the drip tray, remove the 2 screws under the drip tray. From the bottom, where you removed the screws, pull out and up. The whole disp cover lifts off. Unplug the 2 harness going to the board on the dispenser. The refrigerator will still operate normally minus the dispenser. Catriver.
Dec 25, 2007 | Maytag MFI2568AES Stainless Steel Bottom...
Maytag MFI2568AES Stainless Steel Bottom Freezer French Door Refrigerator Logo
18 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
