Question about Winter Sports
I have a 1999 zL 440 it runs fine @ 2500 rpm or higher but if it idles down the only way to clear it out is to lift the choke one notch I already put fresh gas and cleaned the carbs???
    Top Expert:
  • 2,044 Answers
Please do not take this the wrong way and I am going to walk you through the process so you can understand and it is actually an easy fix.
ANSWER IS: -
(a) Your Carburetors need to be cleaned,
(b) Jet in your Idle Jet or Low Speed Jet is Too Big
(c) Damaged Needle an/or Seat.
There is 3 orifices that need to be cleaned and requires a wire be fed through the hole on EACH of them. The issue you have obviously is Fuel Related and not understanding what was where when it was started makes it harder.
Completely disassemble the Jets and make sure the Needle and SEATS are in good condition and not damaged, a bad seat will cause it to flood out as you are describing. A TOO BIG JET will do the same thing.
Posted on Feb 12, 2014
  • clyde quinlan
    clyde quinlan Jun 22, 2014
    it dont seem like its flooding its not smoking
  • Todd Arndt
    Todd Arndt Jun 22, 2014
    It has nothing to do with Flooding, it has to do with the "Passage of Fuel", the Idle Control Jet allows the Sled to Sit and Idle, if the Idle Jet (which is much smaller) is blocked or restricted. If you REV the Motor, what is happening is the Fuel is now going to the Primary and you have Fuel traveling through the Seat and Needle. The Idle Jet is not controlled by the Seat, I bet if you clean that Jet, your problem will go away.
My 1999 zl 440 runs great at 2500 rpm's or higher but any less than 1500 rpm's I need to lift the choke to bring up the rpm's
You have a Blockage in your IDLE JET It is STARVING for fuel, at the higher RPM, the High Speed Jet is able to Provide Fuel but not at lower RPM. You make also have a Damaged Needle and / or Seat.
Feb 12, 2014 | Winter Sports
'99 silverado 5.3 engin will not idle runs at 2500 rpm and drops down to 1000 rpm the back up to 2500 rpm -------------------------
which car is it?
problem with 1993 Geo Prizm '99 silverado 5.3 engin will not idle runs at 2500 rpm and drops down to 1000 rpm the back up to 2500 rpm -------------------------
Apr 15, 2013 | 1993 Geo Prizm
My cbr 600 f2 1993 had been sitting for a long time
Sounds like the carbs were not properly cleaned or set up. Choke should cause the cold start rpms to be higher than what you are experiencing. Application of choke to a warmed up engine will usually cause the engine to stall.
Jun 28, 2010 | 1994 Honda CBR 600 F(2)R
Idles fine with or without choke - cannot
Few suggestions(if not checked already):
Holed or incorrectly seated diaphram?
Timing advance?
I Presume you have checked already the air correction and needle jets too.
Please get back to me if you require further asssistance.
May 23, 2010 | 1999 Yamaha Xv 250 Virago S
Echo CS-440 Chainsaw. Was cutting firewood, saw running fine until I refilled the gas tank. The gas was a few months old but looked clean and smelled OK. But after I filled the tank could not get the...
unleaded fuel is notorious for going stale,and it can leave a resinous coating in the carb-try running the saw on half choke with new gas and less oil eg 50 to 1 for say ten minutes,this should clear the gunk out-if this does not work,you have two choices-strip and clean the carb,or adjust the H (high) scew on the carb anti-clockwise by a quarter turn a time till it revs out full bore-good idea to remove the chain and wear ear defenders when adjusting-and always use a chainsaw at its max rpm,or you run the risk of "kickback"
Feb 25, 2010 | Echo 30.1CC Chainsaw With a 14 In.bar and...
1997 chevy truck rpm slow to return to idle
check operation the throttle control motor or cable if used ( broken /missing return spring
Jul 13, 2017 | 1996 Chevrolet Blazer
Pulsar RPM or idling problem.
sounds like when you say cold you mean very cold. If your choke has variable control on it try using more choke until the motor gets warm. Often times the cold weather causes a leaner condition because the air ppm is so much greater leaving you with a leaner running condition.
Dec 06, 2008 | 2007 Bajaj Pulsar 150
1999 DODGE RAM 2500 5.9L DIESEL
if it starts hard he could be sucking air in the fuel system mine did that it was one of the steel return lines that cracked on mine
Sep 19, 2008 | 1999 Dodge Ram 2500 4WD
Winter Sports Logo
294 people viewed this question
Top Winter Sports Experts
Arnie Burke
Arnie Burke
Todd Arndt
Todd Arndt
Are you a Winter Sport Expert? Answer questions, earn points and help others
