Question about Konica Minolta Office Equipment & Supplies
TOUCH SCREEN The touch screen on my minolta 350 can't be displayed whenever i press exactly on the written box but below the written box it can normal be displayed, i figure out it must need some adjusts to put it corectly but i don't know how to adjust it. will you be able to explain it step by step to adjust the touch screen corectly. thank you for your help
  • 26 Answers
Initial Mode Function Setting Procedure
1. Remove the Compact Flash Cover [1].
2. Press the Warm Restart switch [2].
3. When "." appears at the center on the left-hand side of the screen, enter "3" from the
10-Key Pad.
4. Enter the 8-digit service code and touch [END]. (Default value: 00000000)
Initial Mode: Total Clear
Touch Panel Adjustment
Marketing Area
Image Data Clear
Clear FAX Setting
Date/Time Setting
Trouble Reset
• To adjust the position of the Touch Panel display
• Make this adjustment if the Touch Panel is slow to respond to a pressing action.
• When the control panel is replaced.
1. Touch [Touch Panel Adjustment] from the Initial mode screen.
2. Following the arrow mark, touch the four points (+) sequentially on the screen using a
pen.
NOTE
• Be sure to touch the very center of each point.
• Use care not to damage the screen surface with the tip of the pen.
Posted on Feb 13, 2014
4 Suggested Answers
SOURCE: Ricoh Aficio 3025 Copier LCD Touch Screen out of Allignment
It's not in service mode, but rather in the 'self diagnostic menu'. Access it as follows:
Press "clear modes", 1 9 9 3, "clear/stop" (5 times).
** Do not try any other adjustments in this mode...only touch screen
please rate me :)
Posted on Apr 10, 2009
  • 37 Answers
SOURCE: Canon ImageRunner 3570 Touch Screen
you have to do it in service mode.
hit additional functions.....let go
hit the 2 and the 8 key together.... let go
hit additional function ......let go
then on the screen hit copier...
function
panel
touch check
this will put + on the screen touch the + in the 9 possitions it pots up in and then hit reset twice. if this doesnt align it you have to replace the screen.
Posted on Aug 12, 2009
newport74
  • 58 Answers
SOURCE: Lanier LD435c touch screen is not registering touch in right plac
Press the yellow clear modes button then press
1 9 9 3 and the red clear/stop botton 5 times
this will open up the touch screen calibration menu
select calibrate touch screen. follow on screen directions.
Good Luck
Posted on Apr 08, 2010
Touch screen not working
Touch screen is not repairable only change
change your touch screen then use your machine
Feb 14, 2014 | Minolta bizhub 350 Black and White Copier
The touch screen on my minolta 350 can't be displayed whenever i press exactly on the written box but below the written box it can normal be displayed, i figure out it must need some adjusts to put it...
10-Key Pad.
Functions • To adjust the position of the Touch Panel display
Use
Adjustment
Procedure
pen.
NOTE
Feb 12, 2014 | Konica Minolta Office Equipment & Supplies
How to reset to admin code on bizhub
1. Press the Utility/Counter key.
2. Touch [Check Detail].
3. Press the following keys in this order.
Stop ? 0 ? 0 ? Stop ? 0 ? 1
Then
1. Call the Tech. Rep. Mode to the screen.
2. Touch the [Administrator # Initialize].
3. Select [Yes] and touch [Enter]. defaults the PW 12345678
Feb 08, 2014 | Konica Minolta bizhub 350 All-In-One Laser...
I have a problem for bizhub 350 touch screen malfunction totally not working....please help me to solve this problem...thanks..
you must execute touchpanel adjustment.In the right side on copier in neighborough to USB connector located one plastic door.Pull out the plastic and press a little microswitch.After press the switch wait to appaire a * symbol and press 3.In the blue yield introduction 00000000 and press END.On the touchscreen appaire screen adjustment.
Dec 11, 2013 | Minolta bizhub 350 Black and White Copier
Konica minolta bizhub 350 touch screen not working
Remove the plastic cover located in the right side of machine near USB and LAN port,touch the reset micro switch,on the screen panel is displayed Touch panel adjustment and adjust the panel,press the Trouble reset and the Exit to return in copy mode.If necessary repeat the adjust.
Jul 21, 2013 | Office Equipment & Supplies
Come resettare touch bizhub 350
What code is being display? What to reset. Touch Screen?
Feb 20, 2013 | Minolta bizhub 350 Black and White Copier
C3452
hi ali... the problem with your mfp is fixing uunit warm up failure... try to perform trouble reset... turn off the machine, then hold press the utility/ counter... konica minolta logo appears... press 3, type eight 0's then then tuoch "end" then touch "trouble reset"( note: dont touch other menu displayed on screen because you might get another problem.) then the machine will re-statr.....If there is an abort code, there its time for you to change the fixing unit.... ( if you know electronics try to check the heater lamp and thermostat using a multitester, check if there is a continuity inthe both ends...)
Apr 29, 2011 | Konica Minolta bizhub 350 All-In-One Laser...
Simulation code for bizhub 350
Press Utility/Counter button, then on left side of display screen touch "details"
Now press Stop, 0, 0, stop, 0, 1
This key sequence will get you in to the service mode. Be careful what you mess with in here.
Good Luck and Thank You for using Fixya.
WheatlandServices
Dec 27, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
Problems with keyboard, I want to press an "A" and an "H" comes u
I don't have a Nuvi 2xx with me at the moment but on a 3xx & 6xx series, press the wrench symbol and then the display icon and select recalibrate screen and go through the process and touch the dots as it tells you to do. This will recalibrate the touch screen.
- Jim
SHARCNET-USA
Dec 21, 2008 | Garmin nuvi 350 GPS Receiver
380 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
