Choose the statement that correctly identifies the process and location that produces most ATP from ADP during cellular respiration.
  • 3,519 Answers
Hi Reese:
This sounds like you're looking for help in getting the correct answer to an exam question.
My advice would be to research it yourself and come to your own conclusion.
It's called learning.
Posted on Jun 15, 2016
Write down the hypothesis for this investigation of cellular respiration in a population of yeast material and equipment
Cellular Respiration in Yeast Video Lesson Transcript Study com
A hypothesis is a testable assertion rather than a question.
It is tricky to narrow the assertion to what is testable.
Are any of the following testable?
Fermentation by yeast occurs without oxygen.
Cellular respiration in yeast converts oxygen into carbon dioxide.
Cellular respiration in yeast converts oxygen into carbon dioxide and glucose.
Sep 01, 2017 | The Kitchen Appliances - Others
How is the process of cellular respiration in eukaryotic cells different than cellular respiration in prokaryotic cells ?
This does not seem like a cell phone question as it is posted to be so you should probably post it under a differnt cataegory that I cannot find
Dec 11, 2014 | cellular Cell Phones
I pay statements adp login
Contact paystatements.adp. Many places have password expiration dates and you may have just missed the notice that you needed to change it.
Jul 12, 2014 | Computers & Internet
Glycolysis
Glycolysis breaks down glucose and forms pyruvate with the production of two molecules of ATP. The pyruvate end product of glycolysis can be used in either anaerobic respiration if no oxygen is available or in aerobic respiration via the TCA cycle which yields much more usable energy for the cell.
Glycolysis Wikipedia
Mar 26, 2014 | Roofing
After installing DB2 query is not executing
could you check whether you are connected to the database, where you are trying to create table,
check the database list, then connect to the database you want then execute the table creation ddl,
if no db found then create a database then proceed.
Dec 05, 2008 | IBM DB2 Connect Enterprise Edition for PC,...
I installed DB2 in my laptop . then i go to all programs->DBCOPY1(default)-> command line tools -> command editor then write down query to create a table but i cant build it it is showing CREATE TABLE...
Before you create a table you need to:-
1. create a database
2. create a username and password or use the admin generated userid
3. connect to the database
you can then create a table and use the database
Please post if you do not know how to do this and i'll give you some links
Plasma cutters Question
There are a few things about plasma cutting safety that are different from general welding safety tips This short list of plasma cutter safety tips is geared toward light duty plasma cutting using compressed air not large industrial units that use gas mixtures and water cutting tables. Electric Shock Can Kill - Operating a plasma cutter completes an electric circuit between the torch and the workpiece. The workpiece and anything touching the workpiece are part of the electrical circuit. - Never touch the torch body, workpiece or the water in a water table when the plasma system is operating. Voltages & Currents - Plasma cutter output voltages are much greater than welding voltages, usually 100-200 volts. Precautionary Measures - Do not pick up the workpiece, including the waste cutoff, while you cut. Leave the workpiece in place on the workbench with the work cable attached during the cutting process. - During plasma cutting operations do not move the work clamp. Wear insulated gloves and boots, and keep your body and clothing dry. - Do not stand, sit or lie on or otherwise touch any wet surface when using the plasma cutter system. - Insulate yourself from work and ground using dry insulating mats or covers big enough to prevent any physical contact with the work or ground. If you must work in or near a damp area, use extreme caution. Work Cable - Ensure metal-to-metal contact between work cable and workpiece or work table. - Work cable clamp should make contact with clean metal free of rust, dirt, painted surfaces, etc. - Do not attach work cable to the piece that will fall away when the cut is complete Plasma cutter Arc Rays Plasma cutter arc rays produce intense visible and invisible (ultraviolet and infrared) rays that can burn eyes and skin. Protective Clothing - Guantlet gloves, safety shoes and hat. - Flame-retardant clothing to cover all exposed areas. - Cuffless trousers to prevent entry of sparks and slag. - Remove combustibles, such as a butane lighter or matches, from your pockets before cutting. Noise Levels of Plasma Arc Cutting - Plasma arc cutting systems can generate noise levels in excess of 120 dB during high-amperage cutting operations. - Ear protection should be used when operating or working near plasma arc cutting operations. Toxic Fumes & Gases Plasma arc cutting can produce toxic fumes and gases that deplete oxygen and cause serious injury. - Keep the cutting area well ventilated or use an approved air-supplied respirator. - Do not cut in locations near degreasing, cleaning or spraying operations. The vapors from certain chlorinated solvents decompose to form phosgene gas when exposed to ultraviolet radiation. Pacemakers & Hearing Aids - Pacemaker and hearing aid operation can be affected by magnetic fields from high currents. Pacemaker and hearing aid wearers should consult a doctor before going near any plasma arc cutting and gouging operations Overall Plasma Safety - The plasma arc cutting process can be very safe. - By paying attention to safety standards and correctly setting up and operating the system, plasma arc cutting poses no more a threat than most welding processes.
Aug 27, 2008 | Miller Spectrum 375 Cutmate Plasma Cutter...
619 people viewed this question
k24674
jasbo
jasbo
