Question about 99.5-01 Ford 7.3L Powerstroke F250,F350 Manual 6 Position 4-Bank Chip
2001 f350 slow to start when cold. Then when it starts and rpm rises it dies.
    Sergeant:
  • 361 Answers
Fuel water separator ?, change the filter and make sure gasket sits. Tight if it sucks any air at all you can get this problem or it will not start at all ,air filter , water in fuel .
Posted on Jan 22, 2015
My 05 f350 with 6.0 hard to start wen cold now wont start it trys but no go
First thing to do Is plug it in 6.0ltrs hate the cold second check glow plug circuit if you don't have a block heater you need one a coolant circulator is the best but if its really cold a heater on the oil pan a swell
Dec 11, 2013 | 2001 Ford F350 Super Duty SuperCab
2001 Ford F350, 7.3 Diesel, 6 speed manual trans. Starts and idles just fine but when I let out the clutch the engine dies when the rpm reaches about 1500. Even in neutral it dies when rpm is slowly...
I want to say APP , If the Cam sensor degrades or is out of range it will do this, I wish I could hear it,The turbo can also do this, just make sure all turbo connection are clamp down, and there is no leak from any of the tubes
Feb 25, 2013 | Cars & Trucks
My 2001 F350 seemed to have gelled up overnight with cold temps. I had fuel additive in the system. Once it warmed up today and batteries fully charged, it cranked very slow and then after 3 tries it...
glow plugs may be bad,when starting try turning switch on several times,each time you do,wait for the wait to start light goes off, if it starts like that,then your glow plugs need replacement. you can start it with either spray,but when you do that the motor gets addicted to the bottle,so to speak, then you'll really need to replace the glow plugs if you keep either starting it.when using either spray it into the air induction,use very little either,if you can't find the either,you can use regular starting fluid,but either one you choose,it takes just a quick spray to start. thank you for choosing fixya.com
Jan 04, 2011 | 2001 Ford F350 Super Duty SuperCab
When I start up my truck it makes a slight reving noise. The RPM fluxuates just a little. But it only started since it has been really cold.
Pretty typical in cold weather. Computer is compensating for the outside air temperature. It should slow down after it runs a bit. Mine does the same thing this time of the year. . .
Good Luck
Dec 14, 2010 | 2001 GMC Yukon
I have a 2001 F350 diesel 7.3L crew cab. Since the cold night, I’ve been using my plug-in heater at. In the mornings it starts fine. But after 8hours of work (where I can’t plug the heater in), I have to...
very normal with a 7.3 to be hard starting at lower temps the only thing i can recommend is getting a remote start with cold start where it starts it every 2 hours and runs it for 10 mins other than that you need to plug it in
Dec 14, 2010 | 2001 Ford F350 Super Duty SuperCab
2001 F350 just died and won't start??? Replaced cam sensor, been trouble shooting. Any sugestions????
first check all fuses.replace all burnt fuses check the big main fuses in distribution box in engine compartment,if this is a diesel engine.I would start looking at a direct injection module 100% its usually located on driverside inner fender 2"x8"x10" dimensons
Mar 18, 2010 | 2001 Ford F350 Super Duty SuperCab
Hyundai xg300 engine dies when cold and sputters
If you were driving a voyager I'd suspect the fuel pump is starting to fail.
Feb 14, 2010 | 2001 Hyundai XG300
99.5-01 Ford 7.3L Powerstroke F250,F350 Manual 6 Position 4-Bank Chip Logo
Top Bully Dog Vehicle Parts & Accessories Experts
ausiepaul
Level 1 Expert
AZBen
AZBen
ray gallant
Are you a Bully Dog Vehicle Part and Accessory Expert? Answer questions, earn points and help others
