follow the lower radiator hose to the engine. There is a silver housing that connects the hose to the engine block.The thermostat is in this housing. You can buy the whole assembly, with the housing, the thermostat, and the gasket at your local auto parts store.
hey bud let's see here there shouldn't be a single post with a 10 mm nut on it somewhere on the relay junction box on that post will be two red cables the size of a pencil one goes to either the starter or alternator not sure what color that one is but you'll see where it goes the other is short and red goes directly to the positive terminal of the battery
If your thinking of interchanging the head or short block then you can, depending on the cylinders, because the saturn sl2 2000 and 1999 were one of the few models ever to make a 1.9 liter DOHC. if you have a 1.8 DOHC then you should be fine with a 2001 or 2002
Hello, leotaaz1 and thank you for asking your question on Fixya!
Here is a simple process that will walk you through a few steps that
will pinpoint the overheating problem on your 2001 Saturn L-Series,
without even using any tools. It has helped millions of people, and I am
certain that it will help you, because I wrote it for people in your exact situation. How to diagnose your overheating 2001 Saturn L-Series Pay close attention to the block test part of the instructions.
disconnect power than unbolt egr using a carb cleaner and small stiff brush clean carbon build up in and on unit also clean around engine block reconnect and try usually works but if internal springs break will have to replace
