Question about Yard Machines Cultivator
Yard machine 31cc tiller dies when moved from choke fuel lines routed correctly
2 Suggested Answers
  • 61 Answers
SOURCE: fuel line routing yard machine 31cc cultivator
unit with primer bulb,,,,,line from gas tank with filter, goes to bottom of carb, from top of tank to suction side of primer bulb, from output of primer to tank return
Posted on Apr 29, 2010
Testimonial: "Thanks for the info, tiller runs fine. Phil"
Mantis only runs with choke half on.
Try fuel with 30% injector cleaner (or 25% auto transmission fluid) Something is clogging the fuel route.
May 11, 2012 | Mantis 2-Cycle Tiller
I have a Yard Machrines by MTD Yard & Garden Cultivator 31cc: Model No.21A-121R900 Ser.No.1A246DG1150 and I need to replace the primer bulb. How do I do that?
hello l, how to change primmer bulb,,remove the two fuel lines making note which line came off where,use needle nose pliers to push the two ears down and pull bulb out,make note on where the long and short stem was at,go to the mower shop and get a new bulb and install,put lines back on, done start engine,,hope this helps,,
Jan 27, 2012 | Yard Machines Cultivator
MTD lawn tractor will start but dies after 3 seconds no matter where speed control is moved or left, choke adjusted, etc. First starting after 5 months.
If your fuel valve fully ON? Is there dirt in the tank? Is the filter clean? These are the the first things you should check.
Apr 30, 2011 | Mtd Products Yard Machines 158CC Tiller
I cannot remember how to start my tiller
This Could be a problem? Turn the fuel on, place throttle lever to choke, prime if available and pull cord. when running move throttle to run. Good Luck, your gonna need some!!!!
Apr 20, 2011 | Mtd Products Yard Machines 158CC Tiller
Cultivator won't start.
After sitting for that long the carburetor will gum up and not let gas through. Buy a carburetor repair kit and replace the diaphram and gaskets. Be sure to make a sketch of where the fuel lines are routed to. It's easy to forget where they went and a headache to try to figure out. If it has a primer button I would replace that also.
May 01, 2010 | Yard Machines Cultivator
Fuel line routing yard machine 31cc cultivator 21A - 120R000
Apr 29, 2010 | Yard Machines Cultivator
Yard Machines Cultivator Logo
Top Yard Machines Garden Experts
dannydoesita
Phil Walker
Phil Walker
Dean Gruber
Are you a Yard Machines Garden Expert? Answer questions, earn points and help others
