Question about Zebra 105SL Thermal Label Printer
ERROR CLEARED HEAD OPEN - Zebra 105SL Thermal Label Printer
How do i clear error c4154
Polygon Motor for the Black Print head LASER is bad, the motor is internal to the print head get a new print head for the black, requires tech to install, clear code bye open closing front door.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Oct 17, 2015 | Konica Minolta Minolta Bizhub C253 Copier
How do i clear error code c4154 on bizhub c250
Oct 17, 2015 | Konica Minolta bizhub C250 All-In-One...
Printer head missing or not installed properly.
First change the old head with the new box pack head if the problem persist then change carriage unit the problem will be clear.
Jan 02, 2013 | Kodak ESP 5 Printer
The message "head open " printer idle v53.16.5z
Try taking the printer off pause. It should clear the error.
Mar 03, 2011 | Zebra ZM400 Thermal Label Printer -...
I have a Z4mplus printer that keeps giving me the error "error cleared, paper out" and "error cleared, head open". I have done a manual calibration and still nothing.
I've had this problem as well. It occurred because somehow the Media Type was set to non-continuous with continuous media loaded.Simply changed the setting back to continuous and everything was fine.
Dec 21, 2009 | Zebra Z4Mplus Label Printer
Error cleared head open
This is not an error, it is a notification that the head has been open and is now closed. If you get Head Open warning when the head is closed check the metal area over the top of the sensors are clean as it is reflective.
Nov 23, 2009 | Zebra Z4M Printer
Paper Output Slot Error Message
When the print head temperature falls, the error is
automatically cleared.
Note:
If the print head temperature exceeds the specified limit
when the scanning unit (printer cover) is opened, the
carriage does not move to the ink tank replacement
position.
Oct 11, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Zebra 220xiIII Error Condition Head Open will not go away
The head open sensor is inside the printer is detected by the gear head.
Mar 16, 2009 | Zebra 220XiIII Label Printer
E04 Error Message
Here's what i found. I was able to clear the message by opening and closing and ejecting the cassette. I also had to play with the battery at the same time. Keeping the cassette door open and then pulling out the battery. After is did this a couple of times i got the message to clear. I too haven't used my camcorder for some time and now that the error message has cleared the camcorder tells me that i need to clean the heads. Hope this helps. Below is the message i found that pointed me toward ejecting the cassette. Good Luck, i'm off to buy a tape head cleaning cassette. An error indication (E03 or E04) appears. - (E03 or E04 UNIT IN SAFEGUARD MODE REMOVE AND REATTACH BATTERY) This massage a malfunction of some kind has occurred. In this case the camcorder's functions become unusable. - Eject the cassette once and re-insert it, then check if the indication clears. When it does, you can resume using the camcorder. If the indication remains, consult your nearest JVC dealer or service center
Oct 17, 2007 | JVC GR-DVF21 Mini DV Digital Camcorder
Zebra 105SL Thermal Label Printer Logo
19 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
