Question about Bosch Dryers
How do i remove front panel of bosch WTMC3521UC/03 dryer
    Habit-Forming:
    New Friend:
  • 82 Answers
With a screw driver.
Posted on May 22, 2014
SOURCE: Whirlpool dryer front panel
I located a video on youtube.com free of charge. I removed the lint screen, and removed the two screws located in the lint screen housing. Then I pryed the top off near the front of the dryer, which has two clips. Then I remove the two screws locate on the top of the front panel, but they are located on the inside. I removed the door lid swich by removing the two screws. Lastly, I pulled the front panel outward and pulled up lightly. The front panel was off. The issue I had was the dryer would heat up and then got cool after five minutes. The solution was to replace the coils. Important point is that the coils ohm readings were within specifications, but I did located information on the web that indicated this was a potential solution to the issue, and I replaced the coils even though the resistances were within specification. Total cost $22.95 plus tax.
Posted on Mar 25, 2009
vickygomar
  • 460 Answers
SOURCE: How to remove front panel of dryer
Be sure to unplug the machine from the mains,
1.-Remove the top cover of the machine, very straight forward.
2.-Unclip the universal coupling from the main timer to the back of the knob.
3.- The whole knob assembly is held in place by a backing plate.
4.- There are 2 clips at the top of this backing plate raise them and the backing plate and knob can be pulled out.
5.- there is a plastic clips but be careful not to break it.
Your ffeed back and ratting are so important for me. thank you
Was this helpful?
The knob breaks when it has been turned in the wrong direction several times. It's a safety device so as not to damage the main timer.
Posted on May 21, 2009
Maytag317
  • 1136 Answers
SOURCE: Remove front panel - no heat and buzzing sound
Hi, If the lint screen is at the top of the dryer, remove the screws located at the lint screen. Then pry the top by inserting something flat into the gap between the top and the front panel. Now locate the screw inthe upper inside corners and remove them. Now the front will lift up and release from the cabinet.
If the lint screen is inside the door, the lower half front panel will release and let you see under the drum.
I hope this helps. Please let me know if I can assist you further.
Vic
Posted on May 22, 2009
SOURCE: Samsung DV409AG gas dryer front panel removal
i need diagram on how to remove front panel of samsong front loader dryer
Posted on May 17, 2011
  • 110 Answers
SOURCE: how to remove the front panel of a maytag epic z dryer
If your unit is not drying well or slow dry it is being caused by poor external venting rather than internally. first make sure you are not crushing the vent hose behind unit then next clean venting in wall and make sure outside flaps are opening and closing properly before opening up dryer. Easy way to tell if it the machine or venting is to take vent hose off and connect a pair of sheer pantyhose to exhaust port on back of dryer and run a few loads if all works well your issue is in the wall not the machine
Posted on Apr 17, 2012
The gas dryer works on timed dry but not any autosense cycles. The sensors were cleaned and 2 seperate service people checked it.
your post did not say if you have removed the vent tube and ran the dryer in any of the auto-sense cycles, I would do this first. If it runs normally with the vent disconnected then the vent is restricted. if you have already tried this then the reason it may not be working is that the wires(either blue or green) behind the sensor bars is/are disconnected/broken. There is a diagnostic mode you can enter to test the control's ability to sense the bar contact that is illustrated in the tech sheet which is located within the control panel, when you are in the diagnostic mode touch the two wires of the sensor together and if the light illuminates, it means the wiring to the sensor block and logic of the control is good. If the light doesn't illuminate, then either the control is bad or one of the blue wires is broken or not connected at the control. Hope this helped Tim
Mar 11, 2011 | Bosch Nexxt WTMC3521UC Gas Dryer
Trying to locate the ignitor on a bosch nexxt dryer..........looking through the round hole on the bottom left.....haven't found it yet. any help? tx
Welcome to FixYa.
The ignitor and burner assembly/burner tube are accessible from the rear and the rear panel must be removed.
i.e.
Once that has been removed, you'll need to remove the rear drum support & drum.
i.e.
Then you can pull the drum assembly out...Now you should see the motor and burner components. The ignitor is partially hidden via the burner tube, but is pointed out in the image below.
Hope that helps you identify and access the ignitor for your Bosch WTMC dryer, good luck.
Regards,
Macmarkus :)
Feb 17, 2011 | Bosch Nexxt WTMC3521UC Gas Dryer
Dryer won't heat
The problem is the ignitor...
Check out this tip that I wrote about that problem...
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
heatman101
Apr 10, 2010 | Bosch Nexxt WTMC3521UC Gas Dryer
Kenmore 110.74832400 gas dryer doesn't start
take off the back panel and look down by the motor next to the drum belt there should be a black piece of plastic with springs on either side push it to the left and then try your dryer.alos check your door switch
Mar 16, 2010 | Bosch Nexxt WTMC3521UC Gas Dryer
Noisy; how to remove circular service access panel on front?
If you are referring to the filter, then unscrew it anti-clockwise to remove and clean.
Or if are referring to filter access panel, thrn it it could be a drop down flap, or press the flap to. release.
Trust this is the info you are looking for.
Jan 30, 2010 | Bosch Nexxt WTMC3521UC Gas Dryer
Kenmore 110.74832400 dryer runs but no heat is coming. I removed the back panel from the dryer and I can see the glow from the ignitor but there is no flame. When the dryer is first started the flame is...
the solenoid is going bad on you. there should be two on the bottom by the front of the machine... gotothis site www.techray1.com and click on the guru guy on the left. this will take you to the site where it will sell it to you cheap and installation instructions
Jun 14, 2009 | Bosch Nexxt WTMC3521UC Gas Dryer
Bosch dryer nexxt 500 (wtmc3521uc) broker plastic window
The plastic window can be repalced you dont need to get a new door...
Just remove the door from the washing machine and undue the screws around the rim and unclp the plastic rim and you should be able to fit in a new one with no problem...
hope it helps any questions dont hesitate to ask..
Jan 20, 2008 | Bosch WFMC 3200 Front Load Washer
Dryers Logo
216 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
