Question about RCA 25414RE3 Corded Phone
Change selecting line 2 when line one is not in use
When picking up phone line to use, line 2 picks up instead of 1. Want to make it pick up automatically on line 1 instead of line 2.
4 Suggested Answers
  • 103 Answers
SOURCE: Call waiting problem
The flash time is set too short to activate the call waiting. You'll need to make it longer. Try the following to change the flash time.
1. Press the MENU button while in standby mode.
2. Use the < REVIEW > button to scroll to SET PHONE OPTIONS.
3. Press the SELECT/SAVE button.
4. Use the < REVIEW > button to scroll to SET FLASH TIME.
5. Press the SELECT/SAVE button.
6. Use the < REVIEW > button to scroll through the flash time options. You may choose 100ms or 600ms.
7. Press the SELECT/SAVE button to save.
setting the flash time to 500ms should get it working right.
If this help, please rate my advice. Thanks, and good luck!!
Posted on Feb 05, 2008
pazman
  • 81 Answers
SOURCE: RCA 25202 Default to Line 2
only when you have call foward from one line to the othe when in use. so lets say line 1 is in use then line 2 will ring but now line 1 is open and its ringing (activate forward ) and will go to line 2 and be able to be picked up.
Posted on Mar 30, 2008
greg411
  • 45 Answers
SOURCE: VoIP setup with 2 lines - Both lines pick up on outgoing calls
It does not matter that you have VoIP or traditional telco with the problem you are describing. I think you have a problem with the adaptor or a wire. Check the connectors and the plugs in the phone to see if anything is bent.
Posted on Jul 21, 2010
2 LINES PICK UP ON PANASONIC KX-TG4500
Sounds like you have the cords into the back of the phone mixed up. If you have a cord with 1 and 2 plugged into 1/2, great. But then if you have another jack also with 1 and 2, but plug it into 3/4, now you answer line 3 on second phone and line 1 lights up on first phone. Or line rings line 1 here and line 3 over ther. Gotta keep that straight and the jacks have to have identical lines.
Apr 17, 2014 | Panasonic KX-TG4500 Phone
When I pick up my phone line 6 lights up is there any way to have line 1 light up when I pick up the phone?
Phone is programmed as:
-Access to Pool A = Y
-Primed to = Pool A
When somebody dials 9 or picks up handset it will go to the Prime To noted above which is Pool A.
6 lines are in Pool A, you cannot change the order......it will always select the bottom line.
You need to change Prime Line to = None, then when a line is ringing it will answer the first line that rang.
If you know how to program its under Config/SetXXX/LineAccess/PrimeLine otherwise you need to call a tech/vendor in for this.
Oct 17, 2012 | Nortel M7324 Refurbished Norstar System...
My company has an Avaya phone system that uses Partner 18d phones. When you pick out the receiver the phone would go to one of our 4 outside lines, but recently on ext. 10 when you pick up the receiver it...
http://dstech1.com/changing-the-line-that-is-picked-up-when-you-lift-handset/
All releases of Partner
Lets say that you currently pick up line 1 to make an outgoing call, but you want to pick up your last line (in this case we will say we have 6 phone lines).
This feature is called "Auto line select"
To program Auto line select:
From extension 10 or 11:
Press feature 00
LEFT INTERCOM
LEFT INTERCOM
RIGHT INTERCOM
Enter the extension number of the extension you need changed.
press ** (start, star)
Then the order you want the lines to get picked up
Then ** (star, star) when done
When finished, press feature 00 to get out of programming.
So, in this example I would enter my extension number (22) and press ** (star, star) and press line 6, line 5, line 4, line 3, line 2, and line 1. Then I press ** (start, star) to signify that I am done programming Auto Line Select. And feature 00 to get out of programming.
Easy as pie.
Aug 20, 2011 | Avaya 700340193 Corded Phone
I have a Kx-t7420 panasonic phone system. I have three of my phones that go directly to line 2. no idea why. Can I change this? Also there is so much noise on line 2 that I cannot hear. Is this something...
Actually, you have a Panasonic TD phone system and a 7420 phone, but no matter. The feature you have is probably "idle line preference" or "preferred Line Assignment-Outgoing". In TD systems by default, you select lines from highest to lowest. If you only have 2 lines and PLA is set, you get line 2 then line 1. You can change it to get line 1 first, or chage the trunk access order. The first is something you can do from each phone, the second requires access to system programming. The bad thing about the first solution is if line 1 is busy, you won't get any line. The second will give you the entire trunk group.
Anyway, from each phone without picking up the handset, press PROGRAM 99 and dial 1301 STORE. That will give you line 1 when you pick up the handset. Just so you know or can change it, 11 is none, 12 is idle line, 13xx is specific line and 1+the intercom is intercom. Pick up the handset and drop it back down to exit programming.
As far as the noisy line, it's probably a central office issue. It's hard to test as that line is the outer pair of the jack that plugs into the phone sytsem (RJ-14 pair 2), but you can probably take a regular phone and test it at the demarc point.
Carl
Jul 14, 2010 | Panasonic KX-T7420 Corded Phone
Avaya / Lucent MLS-12D Partner MLS12D Display Phone - BLACK: when A user picking the Avaya phone up, user don't...
get more lines.
Or check Auto line select.
From ext 10 or 11:
press feature 00
press left intercom twice
press right intercom once
enter extension number
press **
then press the lines in the order you want them picked up (line 5, 4, 3, 2, 1 then the intercom )
press**
press feature 00 to exit programming.
When the extension picks, it will pick up line 5. If 5 is busy, it will pick up line 4 , etc....
May 16, 2010 | AT&T Lucent MLS-12D Phone
Change the line selected when lifting the handset (from #4 to #2)
that is not a user option it must be programed by a tech. it is a feature called idel line prefrence the other way iy can be accomplished is by using a hunt group but you will still need it to programed by a tech, you can contact me by email @ brcrory@buyrite.com
May 05, 2010 | Comdial Impact 8124S Corded Phone
I should be able to use Feature 75 to pick up an incoming call; however, when I try the phone tells me that it is denied in admin. How do I fix this?
more than likely your not in the same pick up group as the phone that is ringing. Instead of setting up pick up groups you could use feature 76 (directed pick up) if you know which set is ringing.
Apr 08, 2010 | Nortel T7316E 2-Line Corded Phone
I need help programming the phone to pick up CO1
This is a guess because you still didn't tell me what system you're connected to. On an idle phone, try pressing PROGRAM 131 STORE. In a TA-824, that makes you select line 1. If it's busy, nothing happens.
Carl
Nov 19, 2009 | Panasonic KX-T7731 Corded Phone
Winfax Pick-up
Try looking at best buy for a fax switching device it can tell the difference between data and voice. I don't know how well they work but i have not used that particular program. I did find this though on another site http://www.windowsitlibrary.com/Content/238/15/1.html
You can have Microsoft Fax automatically answer every incoming call to your modem or, instead, you can manually choose which calls to answer. The quickest way to change this setting is to right-click on the fax icon on the Windows taskbar then choose Modem Properties to display the Fax Modem Properties dialog box . Another way to get to these properties is from within Exchange; choose Tools, Microsoft Fax Tools, Options, then switch to the Modem tab, select the modem, and click the Properties button.
So you have to change the settings in Exchange I assume
Jul 08, 2008 | Symantec WinFax Pro 10.0 for PC
HOW TO CHANGE THE AUTO LINE SELECTION WHEN PICKING UP HANDSET
Sounds like you have two seperate line groups programmed in the system, Program 32 " Automatic Preference " controls the lines the phone will automatically be connected to when the telephone handset is taken off hook or the Spkr button is used.
Apr 24, 2008 | Toshiba DKT-2010 Corded Phone
Lands Phones Logo
19 people viewed this question
Top RCA Lands Phones Experts
David Burbee
David Burbee
Are you a RCA Lands Phone Expert? Answer questions, earn points and help others
