Question about LG LHT854 Theater System
No power. Will not turn on. Electricity failed.
Electricity off. Would not turn on when power restored.
Dryer runs and stops and all l.e.d. lights come on
Was the dryer on that the time the power was cut? Was the dryer on when the power was restored?
It sounds as though it may have suffered a surge which may have affected the controller board.
Dec 11, 2013 | Maytag Dryers
Glowworm economy plus
follow this test and fix it. God bless you
If there is no hot water, first push the reset button on the high-temperature cutoff; test the thermostat and replace if faulty (see below). Test the heating elements and replace if faulty (see below).
If there is not enough hot water, adjust the thermostat settings. As needed, reset, test and replace thermostats and heating elements if faulty.
If the water is too hot, adjust the thermostat setting
An electric water heater is a 240-volt appliance that can deliver a fatal shock. Always turn off power to the heater at the electric service panel 3eaa58c5-8512-433f-991a-4ed5eb1cf944.jpgbefore beginning work, and verify that power has been shut off. Make sure others in the house know not to restore electricity prematurely. If you have any doubt as to whether electricity has been turned off, seek professional assistance.
Oct 01, 2013 | Water Heaters
We were without electricity for 2 daya following hurricane Irene. When power was restored, the oven display (time, temp, etc) did not come back on. The oven lights come on when the button is depressed. and...
Try turning off the circuit breaker to the oven for 30 min or so and then turn it back on. If it does not come back on the oven probably got a power surge and the control has been damaged. Hope that helps
Aug 30, 2011 | Whirlpool RBD305PD Electric Double Oven
Picture and sound go off and power indicator blinks eight times. TV will not turn off or back on. Disconnecting power for a few seconds restores the picture and sound for a time, but then it repeats.
The TV might be telling you that there's something wrong with the power (wrong or excessive voltage, for instance). Please test the TV at someone else's house to rule out electricity problems at your house. If the TV still shuts off, then there should be something wrong with its logic board or power circuits, and you should call a technician to inspect it.
Mar 02, 2011 | Panasonic Viera TH-50PZ80U Plasma TV
Have kenmore 61951 dryer PF comes on go thru the steps it turns on and then shuts off what could be the problem
PF is a power failure error meaning electricity has been interrupted to the machine. Any electrical interruption to the machine such as a circuit breaker being reset or weather related power outage can cause a PF error code. Try resetting the appliance by disconnecting it from the outlet or switching off the circuit breaker for 20-30 minutes, then restore the power. If the reset doesn't work I suspect the control board has failed.
Jan 12, 2011 | Kenmore Dryers
Not heating inside the home
Turn your fan switch at the thermostat to on, if the blower starts that is
better news for you. If it does not start you will need to check the fuses
or breakers.
If you are electricity driven. Turn power off, remove blower door compartment, remove and label thermostat wires. Hook a jumper wire
between R and W. Put door back on, restore power, if furnace starts and heats your problem is probably the thermostat
Jan 28, 2010 | Ruud Heating & Cooling
Our miele condenser dryer with the miele washing machine will often trip the whole house's electricity. Sometimes it will trip on the house circuit board. while other times it trips the external trip...
have the neutral power connection on that circuit and back to the main house panel and then have the neutral connection checked at the power companies side also, it sounds like you have a high resistance neutral connection somewhere in the circuit and its looking for another return path due to the high resistance on the line to another feed circuit line to make connection
Dec 07, 2009 | Miele Novotronic T220 Electric Dryer
Electricity went out and not flat screen will not come on
Hi, this was a very powerful surge that has occurred during the power outage. the surge has fried the power sector of your set. you will need to replace the damaged power board/flyback in this case. this will restore the normal power flow in the set.
Jun 18, 2009 | iLO IWT3206 TV
LG LHT854 Theater System Logo
44 people viewed this question
Top LG Audio Players & Recorders Experts
PNiss
Are you a LG Audio Player and Recorder Expert? Answer questions, earn points and help others
