Question about Kyocera Mita Office Equipment & Supplies
Cannot use 2-sided original due to failure - Kyocera Mita Office Equipment & Supplies
Front panel stopped working and fridge is not running now,interior light works ,no humming or clicking sounds when plugged in ,short power failure before it stopped working
IF the power failure was due to lightning or something that caused a surge, the control board is most likely bad. You can attempt to reset it by unplugging it for 5 minutes and try again. If not you are looking at a new control board. You could contact your insurance for coverage due to the power issue.
Jul 06, 2015 | Hotpoint Hot Point - HSS25GFTWW...
Heater blows out cold air on the drivers side
Is this a GMC or Chevrolet? If so what Year? The most probable cause of this condition is one or more Damper Stepper Motor failures. These are prone to failure due to the Manufacturers failure to spend a few more pennies for Premium Quality devices. The replacement is often very costly due to the location of the one most prone to failure is located on the top of the Plenum which requires a technician several hours to replace.
If only the drivers side is affected and the passengers side has full control it could be the Dual Control module is defective. These are far easier to replace and less costly.
Fastest Robe
Jan 07, 2012 | Cars & Trucks
With the product recall on a simplicity crib with diaper changer 8994w what was the product recall for?
All simplicity cribs were recalled due to part failure and child deaths not to mention the company went out of business and there was no remedy. Technically, Simplicity was sold to the highest bidder and the company that bought it refused to be responsible (I guess the government let them) for the products the company they bought had made. But the bright side is Walmart offers a full refund of the original price (no receipt required) as they sold the beds.
Mar 10, 2011 | Simplicity for Children 8994W Crib
Tv is not getting on. one red led is blinking
Since you are having the red light blinking the power supply board is working fine and the set is tripped off due to some overload in the HT side. So after disconection of the power use a multimeter to probe. check for short in the HT side, the Line output transformer, the output drive. If there is no short and on powering the amin +B powerr drops off then if is possible failure of the LOT. You may notice that the output driver heats up before shutting. Confirm it before replacing with the original or take a consensus by asking an experienced friend to confirm.Any other short in the main board can also result in the same symptom. Hope you try . Good day
Aug 10, 2010 | Sony KV-XG29M61 29" TV
Not cooling frig or freezer, cleaned coils underneath, fan running,
If your fridge or freezer is not cooling at all even after you had done a full clean up, thenit is possible that you compressor is faulty due to the failure of its pumping , maybe failure within the system due to any valve or O rings failure. The oher major problem could be that your gas had leaked out, in such case you will need to check for the system leak before any gas is pumped in. I think you will need the help of a service technician to come over and give you an estimate before you decide if it is feasible with the cost. Since you ahve an idea of the job that could be expected decide only after you think that the service cnetre gives you warranty on the work done specially if the compressor is service. So check this out. Good day
Jul 30, 2010 | Amana ARSE66MB Side by Side Refrigerator
I race a 1994 saturn on a dirt track. My car runs
Is it a stock engine?
If so check your ECTS water temperature SENSOR not sender, it's located on the right side of the block towards the bottom drivers side engine compartment.
Change the harness connector to it as well it usually goes bad due to corrosion, the original ects sensor was plastic which cracks, the replacement is 8 bucks at auto zone and is brass.
If this goes bad your engine will run rich, waste a lot of fuel and foul the plugs causing the engine to cut out.
If this is fine then check your ignition system for failures due to vibration.
Apr 05, 2010 | 1999 Saturn SL
My freezer cools properly but my refrigerator is not staying cool .its kenmore and bought from sears 2004 $1000. side by side refrigerator
Quick temporary fix - defrost the freezer (inside frezer lower back) it is probably full of frost/ice - this prevents air flow and therefore no air enters fridge side. common failure due to bimetal defrost thermostat failure ($20) - replace this part for a permanent fix - also advisable to swap out the defrost timer at same time
Aug 03, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
The refrigerator is not staying cold. the freezer works fine. we tried the settings to no avail. any advice?
Quick temporary fix - defrost the freezer (inside frezer lower back) it is probably full of frost/ice - this prevents air flow and therefore no air enters fridge side. common failure due to bimetal defrost thermostat failure ($20) - replace part for permanent fix
Aug 02, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
HP photosmart 6188 Ink Failiure System
Not sure how to help you. Ink failure I would think is cartridge failure. Are you original virgin cartridges or refills? I need the actual error message that the printer is giving.
Nov 14, 2008 | HP Photosmart C5180 All-In-One InkJet...
Hp CM8060 error code 49 4C02
This error is typically due to some sort of data corruption. If this is happening on a single file, it could be that file. It could also be related to the individual software sending the print job, bad print commands or invalid. Although rare, a bad cable or connection can be to blame.
First step is to restart the printer, clear all jobs with the Stop button, restart printer again. Then try printing from another program, such as txt editor. If ok, then print a different file from original software, if ok, then print original file.
If failure is with final print, the file is corrupted for printing, recreate file.
If failure is with original software see if there is any updates.
If failure is there directly after restart, try updating printer driver (this is not be a bad idea anyways).
If none of this works, it may well be a formatter board issue, requiring technical service.
Apr 22, 2008 | HP Office Equipment & Supplies
165 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Kyocera HP Expert
Adorjani Laszlo
AAAA262430
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
