Question about Crosley Celebrity CR73-3 3-Disc CD Player
Power doesnt come on the crosley cr73:3 radio/cd/radio
Where can I find a replacement power switch?
Power switches are safety components that can only be replaced by manufacturer approved parts. Contact Crosley for where you can get approved parts.
Nov 24, 2015 | Crosley Entertainer CR-79 Turntable, CD,...
Need schematic for CR73. Only radio works.
I'd like to see the schematic/parts manual, too.
Mar 01, 2015 | Crosley Conductor CR73 Turntable
Crosley CR711
it sounds like the switch that indicates witch item gets power is gone,
Mar 16, 2014 | Crosley Audio Players & Recorders
Crosley cr704
I suggest you return it to the place of purchase, this is a manufacture fault.
May 26, 2012 | Crosley CR704 Shelf System
Will my autorama crosley cr712 record player work without
The record player will work with out a remote.
The CD will need a remote, for operation control.
The radio will work with out a remote
Nov 04, 2009 | Crosley AutoRama CR712 CD Shelf System
Crosley Radio CR246 CD door will not open
Try checking these:
- the CD door motor rubber drive belt (if there is one), it could be either loosened or broken, if so, it needs to be replaced
- the door open/closed sensor switches (contacts), they could be oxydized or damaged, they are located somewhere under the CD tray, possibly at the front end of the unit (depends on brand and model), you need to clean these with some fine sandpaper
It could be something else like the door motor driver IC, the power supply for the motor, a bad capacitor in the motor drive section, a loose connection or a broken wire somewhere, but hopefully, it's just a bad rubber belt or a dirty contact.
regards
3rq8 (Triarcuate)
Aug 08, 2009 | Crosley CR248 Turntable
Crosley CR704 record player wont work, HELP!!!
Make sure the switch on the back for line in, is off! I had mine on and it would not play. Switched it off and all works fine!
Aug 01, 2009 | Crosley CR49-TW Tweed Traveler Turntable...
Crosley Celebrity CR73-3 3-Disc CD Player Logo
51 people viewed this question
Top Crosley Audio Players & Recorders Experts
 Grubhead
Grubhead
Sam Palermo
Sam Palermo
Are you a Crosley Audio Player and Recorder Expert? Answer questions, earn points and help others
