Question about Microwave Ovens
Kenmore electric range model 93521
I am out of town and need to need the dimensions for my Kenmore Range model 93521.
MicrowaveSvc
  • 9047 Answers
SOURCE: kenmore microwave range hood model 665.61612100 manufactured 2001
The problem is likely on the control panel, which we repair nationwide for $39.95 postpaid.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This often can affect the exhaust fan operation, too. The lights and fan can be inopoerable or stuck on.
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Posted on Oct 22, 2007
MicrowaveSvc
  • 9047 Answers
SOURCE: Kenmore over the range Microwave
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose connection on the control unit circuit board
- bad magnetron or other high voltage part
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
Posted on Dec 05, 2007
SOURCE: where can I get a HV transformer for Microwave?
I went on-line and found a site that gave answers to similar problems. I found that no power to the the control board usually meant a transformer issue. I checked the leads on the transformer (with a meeter) and found that it was shot. Now I need a replacement transformer, at a reasonable price, or else I will purchase a new Microwave.
Kenmore model 665.68682891
Posted on Mar 31, 2009
SOURCE: Kenmore mirowave # 72162643200 handle is broken
I have the exact same problem and the cost for a tech to replace the door is $80 less than buying a new one. They have to remove the unit from the cabinets and pull off the exterior box to unscrew the door hinge. Mine is only 3 years old. I also bought a new oven range. Never really use it. Decided it was time to use the self cleaning. It did not work. $280 to put a new board in. 4 months later I went to clean it and again it did not work. The f*^ing thing only cost $500. Decided Easy off will have to do. Kenmore s*&ks
As for the door... I very CAREFULLY used super glue/ gel and it did the job!
Posted on May 08, 2009
SOURCE: Generic problem for all Kenmore Microwave
Loud hum is usually due to faulty hv diod, resonance capacitor, or the magnatrone feed thru capacitor , chk it with a ohm meter , one by one n replace it .. zaheer Islamabad
Posted on Dec 31, 2009
Sears l kenmore microwave 665.60622000
Most Kenmore appliance manuals are available from Manage My Life. For the 665.60622000 microwave and range hood User's Guide, see http://www.managemylife.com/mmh/owner_manuals/5728/KENMORE-Microwave-Hood-Combo-L0211211?brand_name_search=665.60622000 . This will load the PDF in the browser window if you have a PDF reader plugin. If you wish to download the manual, the direct link is http://www.managemylife.com/mmh/lis_pdf/OWNM/L0211211.pdf . You need Adobe Reader or a similar program to read the file. If you want only the Installation guide, start here: http://www.managemylife.com/mmh/owner_manuals/search?query=665.60622000 . Unfortunately, you will need to print your own copy from the PDF. (Alternatively, go to a print shop with the file on a flash drive and they will print the file for a fee.) Sears no longer has the manuals available for sale at Sears Parts Direct, http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/All-Products-Parts/Model-66560622000/0582/0123370/P0080166/00001?blt=06&prst=&shdMod= .
I hope this helps.
Jul 18, 2013 | Microwave Ovens
Why does my over the range microwave keeps shuttingoff our electricity in the kitchen
This may have a short in the high voltage side, rectifier or shorted high voltage capacitor. You may find it cheaper to replace the microwave, however you do need to call a repairman.
Aug 13, 2012 | Kenmore 1.7 cu. ft. Over the Range...
Need to know what size wire and breaker to use to install my kenmore electric range model 790
need at least #12 (12guage wire) but #10 is even better and requires 50 amp breaker
Jul 21, 2011 | Kenmore Microwave Ovens
I need to replace my Kenmore slide-in electric range, model #991.4674990 and need to know if it is hardwired or plugged in. Can you help me?
Every range I have seen has wires that extend beyond the slide in or drop in so that an electrician can run an electrical line near by. I expect that your existing range has wires that are wire nutted to an extended line from your electrical service protected by a double circuit breaker located in your service cabinet. Remember that the range takes 220V ac service or three wires at least for hook up. A trip to Best BUY or any other like store, will enable you to observe a range in its un mounted state. This way you can plan how you are going to execute the swap.
I suspect that you can slide the range part way out to where you can reach the hook up ad un wire nut the connections.
Dec 28, 2010 | Microwave Ovens
WERE IS MODEL NUMBER ON KEMNORE RANGE?
The model numbers on most Kenmore ranges will be located on a nameplate along the oven door, or lower drawer opening. Some models may have this information on the back of the operator console.
If this question is in reference to a microwave oven, the model number will be located along the oven door opening, or inside the oven cavity along the upper portion on either the left or right hand side.
If you need further assistance, please let me know. I hope this helps you.
Oct 06, 2010 | Kenmore Microwave Ovens
I Bought An Old Kenmore Space Saver Microwave. It Doesnt Have A Manual. I Dont Know If It Can Go Over Top Of Electric Range Stove. I Dont know How To Install It. So What Im Asking Is How Can I Tell If It...
One quick way would be to look on the top of the unit. Do you see empty screw holes where the screws going through the cabinet above it will go through and screw into the top of that unit? If no open screw holes on top of unit probably not an over the range model. Also, look under the bottom of the machine. do you see feet??? Or just aluminum screen vent filters. If feet and no filters probably a counter top unit.
Sep 18, 2017 | Kenmore 62702 Microwave Oven
How do I opening a lock door on my Kenmore Oven? Model #790.95599102
we lost our owners manual for our kenmore elit smooth top range and forgot how to use the self clean oven.
May 10, 2010 | Kenmore Microwave Ovens
Kenmore Over the Range 1000 watt Microwave with no power.
I have the same problem now did you come up with anything for this model
Jan 05, 2010 | Kenmore Microwave Ovens
66993 pizza oven microwave oven combo pizza oven not heating error code f1 microwave part works
Hello, please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacement of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
KENMORE Range/Stove/Oven Fault Codes – 362 Series (General Electric)
F1 = Stuck Touch Pad Key - Replace Electronic Range Control (ERC).
KENMORE - 911 Series (General Electric/Roper)
F0-F1-FF = Failed transistor in Electronic Range Control (ERC).
KENMORE Range/Stove/Oven Fault Codes- 665 Series (Whirlpool)
F1-E0 EPROM Error - Electronic Range Control (ERC).
F1-E1 EPROM Error - Electronic Range Control (ERC).
F1-E2 U/L ERC Errors - Electronic Range Control (ERC).
F1-E3 Fuel Type Fail
Kill power 30 seconds-Cancel-Start/Enter-5 seconds-Should see “E” for electric-
“9” for gas-If code changes again-replace Electronic Range Control (ERC).
KENMORE - 790 Series Electronic Oven Control (Frigidaire)
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal check sum error.
Runaway Temp = Replace Electronic Oven Control (EOC).
Kill power 30 seconds - if error returns - replace Electronic Oven Control (EOC).
Thanks
Jul 20, 2009 | Kenmore 63662 / 63664 / 63669 Microwave...
Microwave Ovens Logo
21 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
