Question about Epic Exercise & Fitness
Clunking when running
Tread mill makes a clunking sound that seems to come from under the running platform near the middle or front of the machine. I hear the sound when my feet impact the treadmill while I am running. Otherwise it sounds fine when I start it up and run the belt while no one is on the machine. The noise made from running on it has seemed to grow more noticeable over the years.
5 Suggested Answers
SOURCE: treadmill won't run. trys to start and gives up after 1-3 seconds
i am having the exact problem, any answers to this?
Posted on Dec 29, 2009
ercupa190
  • 12223 Answers
SOURCE: treadmill deck squeaking on left hand side
please do the following:
1) LUBE the deck belt , this happen because the lack of maintenance schedule.+adjust it each side see the diagram,worn deck probably.
2) Lube the rollers bearing too
3) test the motor for bearing need repair
4) test the drive belt for broken or worn.
5) test the puller for drive motor,can be worn, and replace.
God bless you
Posted on Jul 18, 2012
Testimonial: "Thanks so much - seemed to do the trick!"
ercupa190
  • 12223 Answers
SOURCE: treadmill makes loud grinding sound when I run in the middle of the tread. it doesn't make the noise if I run on the left side.
1)you must LUBE the DECK BELT, inmediately, for to avoid the friction
2)LUBE the rollers bearing.too
3) See the main motor for bearing and repair the motor for bearint too.
4) If the problem persist you have worn deck belt, and replace.
God bless you
Posted on Nov 07, 2012
  • 28 Answers
SOURCE: For the last couple of days tread belt seemed to
treadmill belt need always to put a special oil from below, for better sliding. it is a special product you can find it at any service center for treadmill.
Posted on Nov 15, 2013
Kia Sedona 2008 just started making clunk sound dull vibe/thud felt in steering wheel.cant tell if it's from steering or brake,seems to be drivers side front but not sure,any help,thank you.
My car did that it was a bad wheel bearing Then later I found a tire the steel belts were coming out of the tread. Replaced both and now ok.
Dec 23, 2016 | Kia Cars & Trucks
Have toyota tacoma 2003 4x4 sr5 have clunking sound seems like coming from drive line help plz
A clunking sound is usually a universal joint that is going out. Check the joints by getting under the truck and trying to shake the drive shafts near the joints. The other cause could be the pinion (front or rear) has developed slack. You may see some slack at the pinion bearing of the axle housing when you shake the drive shaft.
Oct 11, 2016 | 2003 Toyota Tacoma
Landice executive L8 treadmill makes clunking noise when I run on it
You need to get someone out to look at it. Noise issues are rarely able to be diagnosed remotely.
Mar 21, 2013 | Landice L8 80 LTD Executive Trainer...
Treadmill makes loud grinding sound when I run in the middle of the tread. it doesn't make the noise if I run on the left side.
God bless you
Nov 07, 2012 | Exercise & Fitness
Loud clunking, banging sound during the spin/drain cycle.
the make , model and year are missing but if it is a top loader unit , it indicates that the tub suspension bar motion absorbers have broken and need replacing
Sep 06, 2017 | Whirlpool Duet GHW9150P Front Load Washer
STAR TRAC 3500 SERIES ERROR EL4
1) Run the software calibration for easy diagnose and troubleshooting and fix. it
2) tight very well all connectors, and clean
3) Adjust the REED switch, see the diagram , clean and tight the connector very well.
God bless you
Jun 19, 2012 | Startrac Fitness Products StarTrac 3500...
Kenmore Model 363 makes Clunking sound
sounds like the mount may b loose.(motor mount)
If so you may want to get under the machine and check to see if there are some screws missing or lost. (they may b on the floor rite next to the motor;)
good luck;)
Feb 26, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Super mario bros nintendo ds world 8 castle - need a walkthrough
in the first area of platforms take the bottom row in the second take the top in the third take the middle platform when you choose the right platform you will hear 2 puick musical notes that almost sound like it said ok
Nov 17, 2008 | Nintendo New Super Mario Bros. for DS
Bowflex treadclimber 5000
Hi ddmyatt.. They sell what is call dry lube at sports store's. for spraying under the tread's and on the wheels that the tread run's on.. Lift the tread and spray as far under it as you can on both side's. She'll be lot's quieter then before and lots easier on the motor too..
Nov 03, 2008 | Bowflex Treadclimber TC5300
Exercise & Fitness Logo
Top Epic Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Electro Med Services...
Are you an Epic Exercise and Fitnes Expert? Answer questions, earn points and help others
