Question about Canon PIXMA MG4250 Inkjet Multifunction Printer - Colour - Photo Print
Paper jam, but there isnt anything stuck inside
SOURCE: paper jam
Just for sharing,
Yesterday i got same phenomenom. After i check , i found the root couse came from, printer head (PG-40) is hit foreign part in the left side when printer is initialize. So the home posistion of head become shift to right. So when the head move to right in parking area, become hit stopper of waste ink platen, that impact to mechanism of paper feeder.
After the foreign part is removed, my printer can work normally.
Posted on Feb 18, 2008
JongCur
  • 88 Answers
SOURCE: paper jam error
there are sensors located in the paper cart area. try to check if there foreign objects obstructing your sensors.
Posted on Apr 18, 2008
ghassun
  • 499 Answers
SOURCE: canon ip4300 Error code 1300
u have to reset ur printer try to hold ur finger on power button for more than 15 sec then turn it on again
Posted on Jun 09, 2009
  • 1382 Answers
SOURCE: paper jam
To fix this kind of error, remove the ink cartridge and turn the printer upside down and gently shake it.Check if anything comes out.If nothing goes, or you can't hear anything rattling around, get a piece of card stock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there. Open up the printer and clean the insides with a soft cloth and a brush. That should remove all the bits of paper inside.The teeth on the roller sides may have some dirt stuck on them which does not allow the rollers to roll freely and hence is as bad as paper jam. The idea is that the rollers do not roll whether because of paper or some dirt on the roller teeth. They have to be cleaned.
Thank you !!
Posted on Jul 14, 2010
Martyn01202
  • 217 Answers
SOURCE: I have a paper jam and the paper in stuck deep
The back should be opened and carefully drag it out that way.
Careful of electrical parts or hot parts.
Posted on Jan 08, 2011
Paper jam
Thank you !!
Jul 14, 2010 | Canon SELPHY DS810 InkJet Photo Printer
Paper jammed message and alarm light remain on even though there is no paper jammed
Thank you !!
Jul 09, 2010 | Canon PIXMA MX310 All-In-One Printer
Copier keeps jamming- prints a page but it jams on the inside. Looks like an accordian. I can open the side door, and pull out the jammed piece of paper.
It either needs a new fixing unit, or there is something stopping the paper on the paper path. Check and see if you can see anything obstructing the paer path. The fixing unit is what melts the toner to the paper, it is usually a consumeable option that isnt too hard to remove and replace, but can be pricey on some models.
Apr 13, 2010 | Sharp AL-1551CS Copier
Says paper jam but there isnt one
off your printer and manually feed paper by turning roller as guide, observe if sensor key freely move when paper pass, some sensor key stock when forcefully remove the jam paper inside.
Apr 05, 2010 | HP LaserJet 1020 Printer
Turned it on and it says paper jam. There is no
Paper jams can be tricky to solve. The paper is usually stuck inside the printer mechanism so even if there is no visible paper jam, you will still get the paper jam error. Try this:
1. Turn off your printer
2. Open all trays and remove any paper stuck there
3. Locate the button to open the printer, open it and remove any paper stuck there also.
4. Repeate the above step for all buttons that you can find to access the inside of the printer
5. Close all doors and put back all trays
6. Turn on your printer
NOTE: Please rate our help to keep this free service online.
Dec 22, 2009 | HP PhotoSmart C4280 Laser Printer
I have a HP laserjet 3055 all in one printer and its giving me the error message that says Doc. feeder Jam. There isnt anything in the printer. How do I fix it.
The jam it's talking about is in the feeder on top. Check for stuck paper, or a sensor stuck down, in the feeder area on top
Aug 06, 2009 | LaserJet 3052 All-In-One Printer
Won't print, and shows Error Code 3
Check to see if anything is stuck inside. Sometimes a small fragment of paper gets stuck inside and triggers the "jam" message.
Feb 03, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Cant get the paper jam paper to turn off and work again
1- either there is something stuck on the sensor or
2- the sensor is bad or out of place
Aug 19, 2008 | Sharp AL 800 Copier
Paper jam
Pull out power cable and, disconnect priter from power outlet, put cable back in.
If you still have led on after this, open all doors and check again fo intrusion. Pull out paper tray and check that there isnt a paper sheet stuck underneat the printer.
Open front door, pull out toner and chech under toner, put toner back , restart and try.
Open back door and check if there is a second paper sheet stuck inside
regards.
Mar 21, 2008 | Samsung ML-2550 Laser Printer
Says paper jam, no paper inside
If you are getting a paper jam error, but no paper inside- Check your Pick Up rollers in the paper tray and then check for any stuck flags in the printer.
Sep 20, 2007 | HP Color LaserJet 2600n Printer
Canon PIXMA MG4250 Inkjet Multifunction Printer - Colour - Photo Print Logo
old marine
old marine
