Question about Moen 3175 Legend One Handle Shower Faucet With trol Pressure Balancing Valve....
How to remove belanger shower faucet cartridge
2 Suggested Answers
  • 129 Answers
SOURCE: the shower control valve for my moen 2995 faucet
Turn off water main. remove round cap on face of handle, remove screw and pull handle. After that everything else can be pulled off easily. When you get to the diverter you should be able to why its stuck.
Posted on Sep 28, 2009
Where is the grub screw that has to be removed as I can't find it?
plumbing - How do I remove a stuck faucet/tap cover ...
diy.stackexchange.com/questions/.../how-do-i-remove-a-stuck-faucet-tap...
Apr 18, 2011 - Anybody can ask a question; Anybody can answer; The best ... There are total six faucets in a bathroom, two made into a bathroom basin ... The other possibility is that there's a small plastic "decorative" cap covering the screw.
How-To: Replace A Shower Faucet Cartridge ' Toolmonger
toolmonger.com/2009/12/01/how-to-replace-a-shower-faucet-cartridge/
Dec 1, 2009 - In many modern shower faucets like Delta and Moen (which is what I have) .... About a year ago, one of the bathtub faucets in my other bathroom jammedopen. .... the exact faucet I have in my shower, so you answered my first question, ...I can tighten and loosen the screw but the handle just won't come off!
Problem Removing Handle Off Of Delta Monitor 1400 Series ...
www.diychatroom.com/.../problem-removing-handle-off-delta-monitor-...
May 20, 2009 - 15 posts - ‎12 authors
... from a Delta Monitor 1400 series tub/shower single handle faucet. ... sorry for the REALLY sxxxxx question. which way to turn (loosen) the set screw. ... only suggestions i have on the issue. when a setscrew will not back off i ...
REMOVAL OF STUCK CURVED FAUCET HANDLE WITH HEX SCREW ' DIY Forums
www.diyforums.net/removal-of-stuck-curved-faucet-handle-with-hex-sc...
Feb 03, 2016 | Home
How to fix delta shower single knob faucet
Take handle off (either set-screw from side or bottom of handle, or phillips screw under cap on end of handle), pull off sleeve that's behind handle, unscrew nut that holds cartridge (strap wrench works great) and pull cartridge out.
Apr 29, 2015 | Delta & Single Handle Shower Faucet
How to fix bathroom shower faucet
shut off water to shower, remove knob by popping cover off and removing screw, remove valve cover by just pulling straight out. there will be a retaining clip that holds cartridge in you will need to remove, Pull out old cartridge and replace with new.
Feb 21, 2014 | Moen 3175 Legend One Handle Shower Faucet...
I have a single handle belanger shower faucet- replaced cartridge and no hot water , Need help
Check the hot water shut off valve, when the washer fails sometimes the valve itself sticks closed, and sometimes the washer breaks up and clogs water passageways down stream...
To test, pull the hose off of the hot water shut off valve, open the valve and see if you have water flow. (route hose into a bucket, you need more that a small amount of water.....
If you have good water flow from the shut off valve, then you likely have a particle that has lodged in the passageways of the faucet. Reverse flow with air pressure and see what you get out....
Jul 17, 2011 | Plumbing
I have Belanger taps all over the house and there is not much hot water coming out of my belanger shower taps(2 bathrooms), tech said I need to change the cartridge, would this fix the problem? All of the...
the only thing to do is to replace what was suggested and see if that improves the situation if you still have the old leaking one , that would be good enough to prove a point
Nov 19, 2017 | Plumbing
Shower/tub faucet does not provide cold water, only to warm and hot.
The faucet has a cartridge that is dirty or bad. Turn off water to the house and remove the cartridge. Take it to Lowes or Home Depot and get another replacement. follow the instructions in the package to the tee.
The old cartridge easily pulls out after you pull out on a clip on the top of the internal assembly. Just take the handle off, slip out the chrome sleeve and remove the clip. The cartridge will pull out with minimal force.
Then head to the store!
Oct 13, 2010 | Moen & One Handle Tub & Shower Faucet
Need an instruction sheet for cartridge replacement for Danze Sheridan tub and shower faucet
This link will get you to the Danze illustrated parts list for the Sheridan single control tub and shower valve.
http://www.danze.com/products/pdfs/D510055_ip.pdf
Aug 08, 2010 | Danze Sheridan Tub & Shower Faucet
Remove belanger one handles shower faucet cartrige . I took off the little colouted rubber plug but I cannot seeinside to remove the small screw to get at it. Can't even see what kind of screwdiver that it...
Please contact Bélanger Customer Service at 1-800-361-5960 with your product number or view our website at www.belanger-upt.com to find your model number.
Nov 07, 2009 | Plumbing
Moen 3175 Legend One Handle Shower Faucet With trol Pressure Balancing Valve.... Logo
115 people viewed this question
Top Moen Plumbing Experts
john h
Donni Steen
Don Numinen
Don Numinen
Are you a Moen Plumbing Expert? Answer questions, earn points and help others
