Question about iHome iBT16 Speakers
Not connecting with iphone - iHome iBT16 Speakers
How do I connect to iTunes from my disabled iPhone?
iphone is disabled connect to itunes HOW???? ' Apple Support ...
discussions.apple.com > Support > Apple Support Communities
Apple Inc.Jul 26, 2012 - i have connected my phone to the computer and nothing. phone still reads disabled connect to iTunes. frustrated!!!!!!!!!!!!!!!!!!!!!!!!! iPhone 4. My Iphone 4S is disabled and says connect to Itunes but i can't as ...
Jan 26, 2014
to allow acesss please respond on your iphone, ...
Nov 27, 2013
ipad is disabled connect to itunes
Aug 11, 2013
iPhone is Disabled connect to iTunes
Mar 14, 2013
More results from discussions.apple.com
If you forgot the passcode for your iPhone, iPad, or iPod ...
https://support.apple.com/en-us/HT204306
Apple Inc.Nov 2, 2015 - ... forgotten your passcode, or if a message says that your device isdisabled. ... If you're signed in to iCloud and Find My iPhone is enabled, use iCloud. If you don't use iCloud and you can't sync or connect with iTunes, use ...
iPhone 4 Disabled but cant connect to iTunes to fix it ... - iFixit
Jan 06, 2016 | Cell Phones
Tip
How to connect an iPhone to the Internet
Connecting your iPhone to the internet is an easy process. You just simply use any application on your iPhone which uses internet service.
Your iPhone can either use WiFi or Cellular for internet access.
- A WiFi network is simply a wireless network. You can find them at coffee shops, libraries or even at your house if you a router setup for wireless access.
- Cellular data networks allow Internet connectivity over the cellular network. Check your carrier's network coverage in your area for availability.
When you use an application on your iPhone that requires internet service it will either connect to the last WiFi network used, or if that network is not available it will list all available networks in range. You can simply tap on the network you wish to join and it will connect. If the network requires a password it will show a lock icon. If no Wifi networks are available your iPhone will connect over the cellular data network and fees may apply.
To see all the Wi-Fi networks in range, from the Home screen choose Settings > Wi-Fi. Tap a network to join it.
I hope this article was informative. You can check out more of my tech articles by clicking here then going to the Tips section.
Regards,
G33k
keywords
how to connect iPhone to the internet, connect to internet, iPhone internet, connect iPhone internet, how to use internet on iPhone, iPhone internet application, iPhone wifi, iPhone wireless internet connection, iPhone no internet, internet not working iPhone, iPhone 3g,
on Jul 09, 2011 | Apple iPhone Smartphone
The volume on my iphone 5 is not working
I can safely say you connected your iPhone to a speaker dock sometime in the past.
When connecting an iPhone to a speaker dock, the volume control is set through the speaker and not through the iPhone.
Sometimes after unplugging the iPhone, the iPhone keeps thinking that it's connected and won't let you change the volume through the iPhone.
To fix this - simply plug your iPhone to a speaker dock again and unplug it until you can manage the volume with the iPhone.
Apr 08, 2014 | Apple iPhone 5
IPhone deletes my contact names when I sync it to computer! Leaves the numbers, delete only names.
If you've set up automatic syncing, iTunes syncs your device by default whenever you connect your iPod, iPhone, or iPad to your computer. If you don't want iTunes to sync your device without being prompted, you can change this setting.
You can prevent unprompted syncing for any specific iPod, iPhone, or iPad; or for all iPod, iPhone, or iPad devices you connect to your computer.
To prevent unprompted syncing for a specific iPod, iPhone, or iPad:
  1. Connect your iPod, iPhone, or iPad to your computer.
  2. In iTunes, select your device (below Devices).
  3. Click Summary, and then deselect "Open iTunes when this Device is connected."
To prevent unprompted syncing for all iPod, iPhone, and iPad devices:
  1. In iTunes, choose Edit > Preferences.
  2. Click Devices.
  3. Select "Prevent iPods, iPhones, and iPads from syncing automatically."
    If this checkbox is selected, any connected iPod, iPhone, or iPad won't sync without being prompted.
To sync your iPod, iPhone, or iPad when unprompted syncing is disabled, connect your iPod, iPhone, or iPad to your computer, and then choose File > Sync "Device Name" in iTunes, or click your device (below Devices) and then click Sync.
For more information, see the iPod, iPhone, or iPad User Guide or the Apple Support website.
Dec 18, 2012 | Cell Phones
After a while my iphone 4 can't connect to my D-link wireless router. the password is correct, and after router restart, the iphone can connect. every day when I come back from work the iphone is not...
Solution - reset the network settings Settings -> General -> Reset -> Reset Network Settings
This will remove previous settings and bugs related to connecting to the wireless, try reconnecting, and see if this solves the issue for you.
If it does not, connect your iPhone to iTunes, backup your iphone, and perform a full 'restore'.
This will solve the problem, unless there is a hardware issue with the wireless module inside the iphone.
Apr 27, 2011 | Apple iPhone 3GS Black (16 GB)
My iphone won't connect to my blackberry, or my handsfree, to allow me to transfer my address book... any thoughts?!
Hi
iPhone will only connect to another iPhone/iPad etc it wont connect with a blackberry to transfer anything you need to try get your content to your computer and sync your details to your iphone via itunes, what type of handsfree do you have? If its not compatible with the iphone it wont connect.
Jan 14, 2011 | Apple iPhone 3G
How we connect internet to iphone
The iPhone can connect to the internet through both Wi-Fi and EDGE. Wi-Fi would be the wireless network at your home or business. When the iPhone connects to the internet through EDGE, it is actually connecting through the AT&T phone connection (or any other service provider the iPhone works with in the future).
safari.jpgTo the connect to the internet, you simply need to open up Safari (which is the internet browser used by the iPhone). If you're used to using a pc, think of Safari as the 'Internet Explorer' that the iPhone uses. You can use Safari the same way you could use Internet Explorer.
Once you open up Safari, the iPhone will attempt to connect to the internet. If there are wireless networks available wherever you happen to be, the iPhone will prompt you to choose one to connect to. If you're trying to connect to a network that has security, you will be prompted to enter the password for the network.
If you want to check to see whether there is a wireless network available where you live, work, or play, go to 'Settings' and then 'Wi-Fi'. The iPhone will show you all of the wireless networks that are available.
If there aren't any wireless networks to connect to, iPhone will connect to the internet over EDGE. Connection speeds over EDGE will likely be somewhat slower than they would be over a Wi-Fi network. You will also not be able to answer phone calls while connected to the internet through EDGE. If the iPhone is connected to the internet over EDGE you will see this small icon at the top of your screen: edge-icon.jpg
for more information you can go thru this link
http://support.apple.com/kb/ts2756
Hope this helps. Please rate my response.
Thanks.
Have a good day
Dec 29, 2010 | Opera Software Mini
Restoring iPhone
Hi. My 2G iphone was connected to Itunes and it was accidently disconnected...now the screen is showing a UBB cord with an arrow pointing towards the Itunes logo. can you help?
Oct 05, 2008 | Apple iPhone Smartphone
Disabled iphone
my iphone show me iphone is disabled connect to itune when i connect itune show massege iTune could not connect the iphone
because it is locked with a passcode. i forgat
Aug 22, 2008 | Apple iPhone Smartphone
Iphone is disabled connect to itunes and when i connect to itunes it says "cannot connect since it is locked with a passcode. unlock the phone. what can i do?
To get iphone to connect to itunes disconnect it from USB cord, press on/off button until you see slide to turn off, slide to turn iphone off. After iphone is off press and hold home button and reconnect to USB cord (do not release home button) continue holding button until you see itunes has detected an iphone in recovery mode then release home button. Proceed with restore.
Aug 10, 2008 | Apple iPhone Smartphone
iHome iBT16 Speakers Logo
69 people viewed this question
Top iHome Audio Players & Recorders Experts
ray gallant
Tom Chichester
Are you an iHome Audio Player and Recorder Expert? Answer questions, earn points and help others
