Hello, Mi name is Ariel and I live in Argentina. A short time ago I started recording with an m audio fast track ultra 8rand I'm having 2 problems I would appreciate if you can help me solve:Two of the channels have constant cracking/fuzzing sounds (no matter if it isconnected or not to any device)and while I turn the volume up the strange sounds get stronger. The only way I can stop these sounds is by muting them from the software options.I'm also unable to use the Earphones Output #2.
  • 4 Answers
Maybe contacts need looking at? might be one stuck.
Or leaky capacitor?
Posted on Feb 15, 2014
Dr_Joseph
  • 86 Answers
SOURCE: problems recording on acid pro 7 with edirol ua4-fx
point nr 1:
when you record midi, you are not recording sound but a key code and time info it was pressed.
point nr 2:
the midi keyboard may be seen as a remote controller.
check the midi configuration on your software host
Posted on Jan 25, 2009
SOURCE: Bose Companion 3 and Realtek HD Audio Card
i think your spund drivers are not updated as per your requirement and they are not working properly....
secondally it might b a problem in your volume controler or audio pin
Posted on Feb 23, 2009
  • 285 Answers
SOURCE: I have a Encore 5.1 Sound card and have installed
When you install the sound card drivers, they disable ALL motherboard sound functions, and enable them on the sound card, meaning you can do the same things, with better quality, you just need to connect everything to the soundcard or it won't work. SO then you cannot connect any sound to the front of the computer anymore, but a soundcard should have plenty of connections on the back side of the PC.
From what I understood from your story, you switched cassette players AND installed a sound card. If I were you I'd first install the sound card drivers, then try to play audio with the old cassette player, and see wether that works. If it does, your new cassette player has another (if at all) output than the old one. Then you'll just have to use the old one. If it does not work, your soundcard is the problem, which seems a bit odd. Soundcards are usually meant to do more than on-board sound, not less. I'd contact your manufacturer and ask wether it's normal this doesn't work, or that the card's broken.
I hope this helps,
Yannick.
Posted on May 14, 2009
SOURCE: HP 6730b Laptop Pardus Linux and no sound
I had no sound in my Pardus first. I went in the settings of the Kmix symbol/speaker down at the meny list and changed the main channel from "Front" to "Master Front"
Then I restarted the pc and it was ok. But you must adjust the volume, it propably is settled on 0 % first.
In my other PC it was not necessary to do that. So it effect only some computers with no or low sound.
Posted on Jun 09, 2010
  • 389 Answers
SOURCE: I am using M Audio
My suggestion is to uninstall the Fast Track device, restart and then reinstall the software. Also, not knowing the computer you are working with, I would also suggest that the speakers are not disabled somehow ( IE, Mute button that got accidentlly activated). Was anything else done to the computer between the time is was working and the time it stopped working). If your audio card and and software are working properly, your speakers are the problem.
Let me know if you can add any more detail to the issue so I can help your further if necessary.
Brian
Posted on Jan 02, 2011
Taking recordings from mixing desk
As the Fastrack can only receive one audio signal at a time you would have to record each track seperatly into Pro Tools.
I'm guessing your mixer is a multitrack recorder.
Solo track 1 on the multitracker and playback from there into the Fastrack, with track 1 on Pro Tools set to record. Repeat this for each or your tracks on the multitracker.
When you've finished you'll need to align all the tracks in Pro Tools so they all playback in time with each other.
Jun 25, 2008 | M-Audio Fast Track USB (FASTTRACK) Audio...
Recording live d.j. mixes ,
Audacity and Krystal (free windows based programs)
What about an LE version of Cubase or Sonar (little hard to learn if your just want to record something light and not edit).
May 28, 2008 | M-Audio Fast Track Pro External Sound...
I guess if your still looking for an answer your probably desperate. Never the less, if someone else is looking for an answer you need to select FT Pro in the preferances. Basically, you have to tell the software what to record and when. Pretty easy really.
Apr 19, 2008 | M-Audio Fast Track Pro External Sound...
Hello, i am new to recording music on my pc and need help! i bought a microphone, an m-audio fast track pro and have a guitar and a voice! bundled with the fast track pro was ableton live lite and...
get straight into protools. it is worth learning in the long run, and most studios operate on it also. you can take you tracks into a studio then to work them up more. It is great software for editing audio and so on and sounds great. there are heaps of quick start guides on line to use it also. check here. If you are serious about your tunes... then just get into it and learn Pro Tools. It worthwhile
Apr 18, 2008 | Audio Players & Recorders
Computers & Internet Logo
David Payne
David Payne
