Question about Xerox WorkCentre 3550
Printer says please wait updating after i make a copy
How do I reset wf 3540 printer to factory default to eliminate the driver updates software problems
Turn it off, if you can. Then unplug it from the wall and wait for it to shut itself down. Then plug it back in, wait, then push the start button.
It should have recycled itself.
Aug 15, 2014 | Epson WorkForce WF-3540 All-in-One InkJet...
Minolta 4000 how to remove the C-40 code
One of the copier fans is bad. Open close the front door. to reset
Mar 29, 2014 | Minolta DiALTA Di183 Copier
Lexmark pro 900 will not print properly or copy or scan
There is a firmware update for the Lexmark Pro900 Series printer that addresses print quality issues. Please visit the Lexmark website to download and install the Lexmark Pro900 Series Firmware Update.
After successfully updating your printer, try to print, scan or make a copy again to verify that the problem is fixed.
Should the problem continue, it might be a printhead problem. Please contact Lexmark Technical Support Center for further assistance.
Dec 29, 2011 | Lexmark Office Equipment & Supplies
Minolta DiALTA Di183 Grayscale Copier Logo Minolta DiALTA Di183 Grayscale Copier printer driver problems
Contact for Konica minolta, Canon copier for repairing/rental/amc/fsma.
We provide CANON IR SeriesDIGITAL PHOTOCOPIER for rental basis also, our rental prices per month 3500/- with free 10,000 copies pre month.
New Delhi & NCR.
Gaurav Pahuja : 9811139117, 9990258388
Jul 01, 2011 | Minolta DiALTA Di183 Copier
Hi I have a Lexmark S405 from yesterday it has stopped copying documents, the scanner works perfectly and the printer seems to be working however when I put a document in to copy it either prints me out a...
Try to reset the printer. Unplug the power adapter from the printer. printmastert_38.jpg
Wait at least 10 seconds before replugging the power adapter into the printer. When the printer completely boots up, try to make a copy a again. If problem continues where it is partially printing copies or having print quality issues, you may need to update the printer's firmware. Firmware update for the S405 is available at http://bit.ly/s405fw.
Apr 12, 2011 | Lexmark Interpret S405 Wireless All-in-One...
When use adf with letter paper sise, push print botton then askme paper 5 1/2 X 8 1/2 inch´s, why do this?
is there any sensors on the adf unit, if so is the paper being feed into the adf unit, there might be a bad/defective sensor, try placing a letter size sheet on the document glass and make a copy, if it copies you have a problem with the adf, and it needs to be serviced
Feb 19, 2010 | Ricoh Aficio 2018D All-In-One Laser...
Long (25 seconds) cleaning wait after each page
You may have a feature on that needs to be turned off or there is somthing that the printer companey needs to fix.
May 01, 2009 | Xerox Phaser 6350DT Laser Printer
Ricoh aficio 1045 error e990 please help it
Error 990 can be cuased by many things. Most of the time it is related to the Hard Drive. you could try replacing it.
Nov 05, 2008 | Ricoh Aficio 1035 Copier
Hp printer
go to : http://www.hp.com/support , and download the installation program , thanks and please rate AJ
May 18, 2008 | HP Photosmart C5180 All-In-One InkJet...
Xerox WorkCentre 3550 Logo
23 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
