Question about Vicks Humidifiers
Vicks hot steam cord gets really hot - Vicks Humidifiers
3 Suggested Answers
SOURCE: Vicks caporiser is spitting water instead of steam
Clean the unti - and do not add salt. I live in a major hard water city...and was amazed at how much dirt the tank collected. I tried adding salt to to stop the spitting, which did make a lot more steam, but did NOT stop teh water spit. I also noticed, with salt added, water in tank would only last 4-6 hours, not the 18-24 hours it should. I just figured it out, and now mine works great again, and does not spit. I cleaned the water tank throughly, several rinses, then wiped out entire inside. If you want it to work like new, you have to keep your tank as clean as new. I am going to start filtering my water that I put in with a double pantyhose I made simply so there no more dirt ~ a clean tank will fix the problem, it did mine :)
Posted on Dec 07, 2008
SOURCE: do you fill with cold or hot water for vicks warm
im pretty sure you fill it with cold water...at least thats the direstions for when you use the vicks medicine you can add in...works great by the way
Posted on Mar 06, 2011
WHERE CAN I BUY VICKS WARM STEAM VAPORIZER
Problems in a Vicks Warm Steam Vaporizer comes when it is mis-handled or when we buy non-warranted products. It is the best solution to spend money on the branded and cheap vaporizers.
http://www.vaporizerchief.com
Cheap Vaporizers Herbal Vaporizers For Sale
Jan 21, 2014 | Vicks Warm Steam Vaporizer 1.5 Gallon...
We have a water softener and I think the water has too much salt and therefore, our Vicks vaporizer has too much steam. Any suggestion?
If your softener is working properly, you should never get any salt in your water. The salt is used only to reactivate the ionic media in your softener cartridge, and during the backflush cycle, all that salt is removed, down to PPM (Parts Per Million) levels.
In any case, even if you used salt water in your vaporizer, it would not increase the amount of steam that it produces. Salt water has a higher boiling point than fresh water. You would also notice salt buildup inside the tank as the water level goes down.
The Vicks Vaporizer works by using only heat to produce steam- the hotter it gets, the more steam it makes. The only practical way to get too much steam outside of a malfunction that causes your heating element to get abnormally hot would be if you live at a very high altitude where water boils at a lower temperature.
High humidity in your home will make it appear as if your vaporizer is making too much steam since the surrounding air will be less capable of absorbing it.
A slightly "off topic" note- if you chose the Vicks Vaporizer/humidifier and have children, you have made a wise decision. Because it produces water vapor by heating instead of ultrasonics, contaminants and minerals (such as salt, iron, calcium, etc.) remain in the tank and will not enter the vapor stream.
Mar 25, 2011 | Vicks Warm Steam Vaporizer 1.5 Gallon...
Do you fill with cold or hot water for vicks warm steam humidifier
Feb 28, 2011 | Vicks Warm Steam Vaporizer 1.5 Gallon...
Is it normal for bottom part of unit to get very hot
mine gets pretty warm too its probably normal for it to be that temp from the elements heating it
Feb 22, 2011 | Vicks Warm Steam Vaporizer 1.5 Gallon...
My vicks vaporizor model101 is all limed up and won't steam. The light comes on but no sound or steam. How can I clean it? I can't get it open. I have hard water with lots of lime.
A 50/50 solution of White Vinegar and Water run through the system should clean it up. If it's really bad, you may have to do it twice. Just flush out the solution with claer water, before trying to use the Vaporizer, as it's intended.
In the future, due to high mineral content of your water, use Distilled Water. You can buy it by the gallon very inexpensively at pharmacies and grocery stores.
Feb 17, 2011 | Vicks Warm Steam Vaporizer 1.5 Gallon...
I need to know how to use the warm steam vaporizer i lost the instruccions..
you add vicks petroleum paste/jelly at the top where the air vent is. Add 1-2 tablespoons of salt with tap water in the tank, plug in the unit and warm steam will produce.
Feb 16, 2011 | Vicks Warm Steam Vaporizer 1.5 Gallon...
I have a vicks hot vaporizer and the unit itself gets very very hot on the outside...it didn't used to do this, so i think it may be broken. im aftraid it will burn it is so hot.
Good day. Here is the link for the manual. Please note page four which shows your issue and some solutions. Let us know what works.
http://www.google.com/url?q=http://docs.google.com/viewer%3Fa%3Dv%26q%3Dcache:pbhjzMo9E3sJ:www.kaz.com/kaz/support/manual/%253FProductManualAction%253DrenderProductManualById%2526ProductManualId%253D5faaee9ab20669a0a26a9fb6e6bb99f8%2Bvicks%2Bvaporizer%2Bblack%2Bparticles%26hl%3Den%26gl%3Dus%26pid%3Dbl%26srcid%3DADGEEShoMFRd7NbKZtGZM-qKr0_rmMQA7bQYO-r4VBGXLFKF1WnqeeQZDdU6pMTOMcxsZMFqdAfWvECyUPTLsoW2KBMr3QBWzicSiUPyG1F8iW4Wmil0atnkfBT1ulKofnvo5HX1DBdR%26sig%3DAHIEtbS-BI2SvXCl3TTlcQduwYAGXqORQg&ei=nuZFS7_EPMiVtgf65bDrAQ&sa=X&oi=gview&resnum=2&ct=oth
Oct 18, 2010 | Vicks Warm Steam Vaporizer 1.5 Gallon...
No steam comes out
I just took mine apart and cleaned the scale off the heating elements. Filled to the level with hot water and it was steaming good in about 2 mins.
Mar 01, 2008 | Vicks V150SG 1 Gallon Humidifier
Humidifiers Logo
280 people viewed this question
Top Vicks Humidifiers Experts
Paul Carew
Robert
Are you a Vicks Humidifier Expert? Answer questions, earn points and help others
