Question about Konica Minolta Office Equipment & Supplies
The touch screen on my minolta 350 can't be displayed whenever i press exactly on the written box but below the written box it can normal be displayed, i figure out it must need some adjusts to put it corectly but i don't know how to adjust it. will you be able to explain it step by step to adjust the touch screen corectly. thank you for your help
  • 26 Answers
Initial Mode Function Setting Procedure
1. Remove the Compact Flash Cover [1].
2. Press the Warm Restart switch [2].
3. When "." appears at the center on the left-hand side of the screen, enter "3" from the
10-Key Pad.
4. Enter the 8-digit service code and touch [END]. (Default value: 00000000)
Touch Panel Adjustment
Functions • To adjust the position of the Touch Panel display
Use
• Make this adjustment if the Touch Panel is slow to respond to a pressing action.
• When the control panel is replaced.
Adjustment
Procedure
1. Touch [Touch Panel Adjustment] from the Initial mode screen.
2. Following the arrow mark, touch the four points (+) sequentially on the screen using a
pen.
NOTE
• Be sure to touch the very center of each point.
• Use care not to damage the screen surface with the tip of the pen.
Posted on Feb 13, 2014
SparkGap
  • 363 Answers
SOURCE: Fuser won't adjust
Just checking something.. Did you use the A3 sheet supplied with the fusing unit and load it in the bypass tray?
Posted on Oct 01, 2007
printech
  • 159 Answers
SOURCE: Konica Minolta 2300DL waste box full message
see the services manual and you can find how to clear this massage in the service mode menu good luck
http://printer.konicaminolta.com/service/ASP/mc2300/documentation_manuals/mc2300SM.pdf
Posted on Mar 22, 2008
SOURCE: Minolta Di200
I need the default password for my copier its. Dialta Di 200
Posted on Jun 11, 2009
  • 1294 Answers
SOURCE: Minolta EP1085 copier - replaced drum but need to
After replace the photocopier drum you need perform the F5 Auto Image Density Control.Enter in the service mode:press Stop key - 0 - 0 -Stop key - 0 - 1 and press 1.In the LCD appear E and press 5 and the copy(start) button for perform the F5.Begining place A3 sheet paper in the original glass.To replace the OPC drum clean the optical section(glass,mirrors,lens,sensors) and change the OPC drum cleaning blade.Clean the quenqing lamp and erasure lamp amd the transfer/separator corona unit(holders,wires) and the charge corona unit.
Posted on Oct 03, 2009
  • 214 Answers
SOURCE: need to reset admin code for konica minolta c-350
Hello
press utility/counter - then under the counter "details" - stop 0 0 stop 01 - now you are in service mode, - stop 0 C, and there shold be admin pwd
Posted on Oct 14, 2009
Touch screen not working
Touch screen is not repairable only change
change your touch screen then use your machine
Feb 14, 2014 | Minolta bizhub 350 Black and White Copier
TOUCH SCREEN
10-Key Pad.
Initial Mode: Total Clear
Marketing Area
Image Data Clear
Clear FAX Setting
Date/Time Setting
Trouble Reset
pen.
NOTE
Feb 12, 2014 | Konica Minolta Office Equipment & Supplies
I have a problem for bizhub 350 touch screen malfunction totally not working....please help me to solve this problem...thanks..
you must execute touchpanel adjustment.In the right side on copier in neighborough to USB connector located one plastic door.Pull out the plastic and press a little microswitch.After press the switch wait to appaire a * symbol and press 3.In the blue yield introduction 00000000 and press END.On the touchscreen appaire screen adjustment.
Dec 11, 2013 | Minolta bizhub 350 Black and White Copier
Konica minolta bizhub 350 touch screen not working
Remove the plastic cover located in the right side of machine near USB and LAN port,touch the reset micro switch,on the screen panel is displayed Touch panel adjustment and adjust the panel,press the Trouble reset and the Exit to return in copy mode.If necessary repeat the adjust.
Jul 21, 2013 | Office Equipment & Supplies
Come resettare touch bizhub 350
What code is being display? What to reset. Touch Screen?
Feb 20, 2013 | Minolta bizhub 350 Black and White Copier
Whenever I switch on to start operating, during my waiting to warm up, it displays error code C-D369. and it doesn't function from there.
Error code reset:turn OFF the copier ,press and hold the Utility key to right hand,to left hand turn ON the copier,wait appaire on the display Trouble reset,touch the screen and turn OFF the copier.Wait 2 minute and turn ON.
Jan 17, 2013 | Konica Minolta bizhub C250 All-In-One...
Konika minolta bizhub 350 Error c3451
error c3451 is abnormal heating temperature. al you have to do is reset the machine. open the back cover and on the main board look for a micro switch. press it will the machine is turn on. i hope this will help you.
Sep 16, 2011 | Konica Minolta bizhub 350 All-In-One Laser...
C3452
hi ali... the problem with your mfp is fixing uunit warm up failure... try to perform trouble reset... turn off the machine, then hold press the utility/ counter... konica minolta logo appears... press 3, type eight 0's then then tuoch "end" then touch "trouble reset"( note: dont touch other menu displayed on screen because you might get another problem.) then the machine will re-statr.....If there is an abort code, there its time for you to change the fixing unit.... ( if you know electronics try to check the heater lamp and thermostat using a multitester, check if there is a continuity inthe both ends...)
Apr 29, 2011 | Konica Minolta bizhub 350 All-In-One Laser...
Simulation code for bizhub 350
Press Utility/Counter button, then on left side of display screen touch "details"
Now press Stop, 0, 0, stop, 0, 1
This key sequence will get you in to the service mode. Be careful what you mess with in here.
Good Luck and Thank You for using Fixya.
WheatlandServices
Dec 27, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
Problems with keyboard, I want to press an "A" and an "H" comes u
I don't have a Nuvi 2xx with me at the moment but on a 3xx & 6xx series, press the wrench symbol and then the display icon and select recalibrate screen and go through the process and touch the dots as it tells you to do. This will recalibrate the touch screen.
- Jim
SHARCNET-USA
Dec 21, 2008 | Garmin nuvi 350 GPS Receiver
228 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
