Question about Canon iR 2016i Black and White Copier
Canon ir1022 paper jams
Im getting paper jams from cassette but not multifeed.i have changed paper feed/separation rollers
3 Suggested Answers
prashanthcl
  • 460 Answers
SOURCE: paper feed roller
you can changed it from shop.
Posted on Aug 31, 2009
canontech
  • 1219 Answers
SOURCE: Hello My machine is Canon iR2016
so, first, did you clean the vertical path roller? ( its a axis with two rollers beneath the paper registration sensor )
Second, when you open left cover, and paper guide plastic cover ( black ) there is also sensor flapper, that can be a quite of pain because slow reaction of spring on it. Apply wd40 on its spring and in left corner where he lays into bushing. To check flapper response, manually close the paper guide plastic, the sensor must be in middle position.
Also it can be the problem in paper pick up clutch and it needs to be cleaned or replaced.
But, also the problem can be separation claws in cassette ( metal claws that holds the paper ). From experience, the probably is sensor flapper or pick up clutch the problem.
Hope that helps!
If you need service manual or help, write on emma.servis@gmail.com
Posted on Jun 18, 2011
How to replace pickup rollers
This should help. Good luck !
Cassette (Tray 2) paper pickup and feed rollers
To remove the paper pickup and feed rollers
1 Remove the cassette.
2 Locate the two rollers on the bottom of the paper pickup unit (above the cassette). The pickup
roller is the smaller roller, and the feed roller is the larger roller.
3 Pinch the tab on the end of the cassette pickup roller (callout 1), and pull the roller out.
4 Pinch the tab on the end of the cassette feed roller (callout 2), and pull the roller out.
Figure 6-24 Removing the cassette pickup and feed rollers
Note Always replace the cassette pickup roller and the cassette feed rollers at the same time. Also replace
the separation roller (located in the paper cassette) when replacing these rollers
Aug 14, 2014 | HP Color LaserJet 4600n Printer
Getting a error message JAM11 on copier CS-1815?
A paper jam in the
paper feed section
is indicated during
copying or printing
(no paper feed from
the cassette).
Jam code 11
Paper in the cassette is
extremely curled.
Check if the feed roller is
deformed.
Defective registration sensor.
Check if the feed clutch
malfunctions.
Electrical problem with the
feed clutch
The above is taken from the sm
Also the feed tyre needs cleaned / changing and or cassette springs need stretching !!!
Dec 03, 2013 | Copystar CS-1815 Printer
Why does ir3300 canon photocopier show paper jam between the lower tray and right cover yet no papers jamed and even else where, what could be this?
these also can occure if the paper from the cassette isn't picked up or if the paper pass the cassette and exits but sensor flapper has slow response.
As first step I would recommend to change the paper pick-up, feed and separation rollers in cassette.
Remove the cassette out, look inside, on inner right side you will see 3 tire rollers. Each roller has nose with plastic hinge. To remove him you need to push hinge on the nose and pull out the rooler to a side.
If they are worn out they will be smooth.
You can remove the rollers from the tray that works and put it into troubled one for test. If the paper jam doesn't occuress you are sure that you need new rollers.
If not I recommend to call service.Because, also the problem can be in paper lifting claw, broken gears,...
For service manual you can contact me on emma.servis@gmail.com
Hope that helps!
Sep 01, 2011 | Canon Office Equipment & Supplies
Hello My machine is Canon iR2016 and i have problem with Paper Jam. I have problem when I copying more then one copy and i got a problem sometimes in the first 10 copys, sometime at 20th copy... Error...
Hope that helps!
Jun 18, 2011 | Canon iR 2016i Black and White Copier
When im making copies it will run off 4-5 pages and the jam up, i keep un jamming it and it keeps happening any ideas whats wrong?
Sounds as though the feed rollers for that particular paper drawer/cassette is in need of replacement.
Mar 28, 2011 | Canon NP 6545 Copier
I have a hp laserjet 4250 printer it had a paper jam in tray 2 i have cleared the jam but it keeps saying i still have the jam in tray 2
There is still paper stuck in the printer. try lifting the printer off of tray 2 to inspect it or here it is straight from the service manual...
Jams in tray 2
Table 7-10 Causes of tray 2 jams
Cause Solution
The feed or separation rollers are dirty, worn, or damaged. Clean the rollers. If they are dirty after cleaning, or if they are
worn or damaged, replace the rollers.
The pickup roller is worn or damaged. Replace the pickup roller.
The tray 2 paper pickup assembly drive gears are damaged
or the assembly is defective.
Check the drive gears in the paper pickup drive assembly.
Replace the pickup drive assembly if the gears are
damaged. See Paper-pickup drive assembly.
The tray 2 pickup solenoid (SL101) is damaged. 1 Disconnect the connector for the tray pickup solenoid
from the dc controller PCA (location J92).
2 Measure the resistance between the cable connectors.
3 If the measured resistance is not approximately
160 ohms for the HP LaserJet 4200/4300, or 110 ohms
for the HP LaserJet 4250/4350, replace the tray 2
pickup solenoid.
The tray 2 lifter-drive assembly or the stack position
sensor (PS107) is defective.
Replace the lifter-drive assembly. See Tray 2 lifter-drive
assembly and/or Printer switches and sensors.
The dc controller PCA is defective. Replace the dc controller PCA. See Dc controller PCA.
Dirty, worn, or deformed pick-up roller, cassette separation
roller, and cassette feed roller.
Clean the rollers if they are dirty. Replace any worn or
deformed rollers. The cassette separation roller and the
cassette feed rollare are to be replaced together.
Damaged gears in the cassette pick-up drive unit. Move the gears in the cassette pick up drive unit. If the
gears are not rotating correctly, or are damaged or worn,
replace the cassette pick-up drive unit.
Dec 25, 2010 | HP LaserJet 4250 Printer
I have a canon copier ir6800 jamming at paper side deck
If the other paper trays work and you use your paper deck more than any other cassette.Your side paper deck tires are worn. You need to replace the 2 pick up tires, the 2 feed tires and the separation roller. Hope that helps.
Apr 21, 2010 | Canon IMAGERUNNER 6570 Copier
Canon faxphone L170 won't copy
if you look at the top piece of paper in the cassette is there a smug mark or wrinkle in the paper. you my just need to clean the feed roller. ( black or gray roller ) . I'm not sher on this model if it is a rear paper feed or a cassette from under if it is a back feed one look in side the paper shoot of any fourn object is in there. Hope for the best.
Feb 02, 2009 | Canon FAXPHONE L80 Laser
Error msg: Paper tray empty or jam, when there is not
Clean The Paper Feed Rollers Using The Unit's Operation Panel Ifthe paper feed roller is dirty, paper is not fed properly because thepaper feed roller slips. Cleaning the paper feed roller could resolvethe paper feeding problem. Please follow the instructions below toclean the Paper Feed Rollers directly from the unit. Caution:Since the cleaning process wears down the paper feed roller, performthis procedure only when necessary and no more than three (3) times.
  1. Ensure that the machine is powered on and remove any paper from the auto sheet feeder or the cassette.
  2. Use the <Feed Switch> button to select the paper source where you do the paper feed roller cleaning. Click for additional information.
  3. Press the <Menu> button.
  4. Use the right / left cursor button to select [Maintenance/settings] press the <OK> button.
    Note: This procedure is skipped if your machine is in Scan mode. Proceed to step 5.
  5. Use the right / left cursor button to select [Maintenance] and the press the <OK> button.
  6. Use the up / down cursor button to select [Roller cleaning] and press the <OK> button.
  1. Use the up / down cursor button to select [Yes], then press the <OK> button. (The paper feed roller cleaning starts.)
  2. Tocheck if the rollers are clean, load a sheet of Letter-sized plainpaper in the same paper source you selected in step 2, and press the<Open> button.
  3. Use the up / down cursor button to select [Roller cleaning] and press the <OK> button.
Use the up / down cursor button to select [Yes], then press the <OK> button. (Paper will be fed.)
Note: If paper is not fed properly, repeat steps 4 through 10 above up to three times.
Paper Source
Press the <Feed Switch> button to switch to toggle between the Automatic Sheet Feed (ASF) or Cassette. The light will come on when the <Feed Switch> is set for that paper source.
Cassette
Note: When printing from the computer, if paper does not feed from the source you have selected on the operation panel, check Paper Sourcesetting in the printer driver. If the option is not set to 'Paper FeedSwitch', paper will feed from the source selected in the driver.
Nov 27, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Canon iR 2016i Black and White Copier Logo
63 people viewed this question
old marine
old marine
