Question about Samsung DVD-V4600 DVD Player/VCR
Dvd tray will not open, but the display window is loading
4 Suggested Answers
krihard
  • 407 Answers
SOURCE: Will not open the DVD tray.
if your dvd tray is not open you need a one inch pin or needle into hole..the hole right side .....then your dvd tray open
Posted on Feb 01, 2008
quang123
  • 107 Answers
SOURCE: Samsung DVD-VR375 says "load" but tray for DVD/VCR won't open
I think you have problem in DVD deck assembly the owner manual won't help you if still under warranty bring back to Samsung if out of warranty you can buy the DVD deck from Samsung and replace by yourself
Let me know if you need part number for the DVD deck
Posted on Dec 09, 2008
  • 10 Answers
SOURCE: Tray Wont open
Hello All. Well, I just finished troubleshooting the same problem of one of my customers units. At first I thought it was the tray contacts but they were good. What I noticed with the cover off and the shield for the laser removed...BE CAREFUL NOT TO BREAK IT TAKING IT OFF ANF DON"T LOOK AT THE LASER...that if I moved the DVD motor, the motor that turns the DVD...it has a rubber wheel on the shaft...that the tray would open. The trouble was intermittent but I also noticed that the wheel would move when pressing the OPen button. I therefore concluded that the motor somehow was in the circuit to open the tray. So, I took the motor out CAREFULLY and on the end opposite the wheel there are two small holes. These holes appear to be access holes for assembly and to hold the brush contacts away from whatever they use for a commutator. At first i was going to disassemble the motor but changed my mind. I have contact cleaner spray and some old Color Tuner Cleaner spray from the old days of mechanical TV tuners. I gave each hole a small shot of spray and turned the wheel. Careful not to contaminate the rubber on the wheel as it is what grips the DVD and pushes it against the white nylon bearing. Voila, the tray opens and closes and the Load display is no more. As I said, be careful. If you are unsure...let someone who understands this stuff do it. Ed
Posted on Dec 27, 2008
DVD ' s tray won't open when pres OPEN, DVD is inside
There are little gears to open the tray with a little rubber belt that drives it you should be able to open door and pull on tray to get disk out if not unplug it take top off push tray out Cheapper to replace player than to fix but little flap should pull down grab tray and pull
Feb 21, 2013 | RCA DRC247N DVD Player
The tray on DVD won't open when pressing OPEN button DVD/CD is inside
Often the tray is powered by a rubber belt. If the latter breaks or slips the try will not open/close. The motor will work and tell the electronics that all is well because it has done its job but it really hasn't since the tray is inert!
Sep 10, 2017 | RCA DRC247N DVD Player
My JVC TH-G30 gives me a locked message when I try to open the load tray what should I do?
hello Setting the disc ejection lock
You can lock the disc tray to prevent the disc form
being ejected.
When the main unit is turned off, hold down the STOP
key at the front panel for 5 seconds
If you attempt to open the disc tray by pressing
OPEN/CLOSE key, the disc tray does not open and
“LOCKED” appears in the display window.
To cancel the disc ejection lock, hold down the STOP
key at the front panel for 5 seconds again when the
main unit is turned off.
“UNLOCKED” is displayed in the display window.
Note:
Before the main unit is turned off, DVD/CD function
should be selected.
Mar 29, 2010 | JVC TH-G30 Theater System
The disc tray will not open. The display shows "open" and it makes noise as if it is trying to open, but it doesn't.
There is a small loading belt that is slipping. The noise you hear is the loading motor. When in the loaded position, there is a "clamper" that magnetically attached to the hub assembly to clamp the disk in place. It takes quite a bit of force to open this up. If you feel comfortable working inside the unit, you can try to gently lift up on the clamper assembly while you are trying to open the tray. That may provide enough to release the tray to open. Replace the loading belt with a new one and your problem should be resolved.
Dan
Dec 07, 2009 | Memorex MVD2042 DVD Player
Disc tray on RDR-HX720 doesn't open and display
1 of 2 things
can you hear the motor running inside the player ????
there is usualy a snall pin hole under the tray insert a paper clip into this hile and push it in if tray starts to auto open it might be just a dry set of rails
if rails asumed dry open unit and coat the rails with anti seize and try again with the switch on front cover
Aug 03, 2009 | Sony (RDR-HX710) DVD±RW Dual Layer...
If you press the open key and it say open on the display then yu have a cut belt / blowm loading motor or power preoblem insdie the set. If it does not say open/close on the display then you could have a faultt button or processor.
May 12, 2009 | Televison & Video
Locked dvd tray.
with the unit off press and hold the stop button and the eject button.
Jul 08, 2008 | JVC TH-S11 Theater System
DEST ERROR CODE
I HAVE A SONY MODEL MHC GNZ55D AND IS WRITING DEST ERROR ON THE DIS PLAY AND CANNOT LOAD OR OPEN DISC TRAY PLEASE HELP AM A TECHNICIAN
Display indicates 'DEST ERROR' when any DVD functions are used.
May 16, 2008 | Audio Players & Recorders
Feb 01, 2008 | Samsung DVD-HR720 (80 GB)
Samsung DVD-V5500 DVD tray intermittently wont open
Sometimes the loading belt can cause this problem or else have seen the tray in switch assy cause this as well.
May 23, 2007 | Samsung DVD-V5500 DVD Player/VCR
Samsung DVD-V4600 DVD Player/VCR Logo
35 people viewed this question
Henry  Thomas
Henry Thomas
