Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
Water leaks out from under the ice maker and freezes in the bin
  • 1073 Answers
SOURCE: ice maker is not functioning
replace the cold control
Posted on Apr 19, 2008
SOURCE: i have a Whirlpool refrigerator
The ice door located in the ice chute in the door is not closing. Allowing wam air in your ice bin which melts the ice at the bottom of your bin there for making a huge ice dam. Replace cirercut board at cost of 295.00
Posted on Feb 14, 2009
peyton32034
  • 410 Answers
SOURCE: WATER AND ICE INSIDE MY FRIG
Most likely whats happening is you have a frozen drain for the defrost cycle. here are step by step instrutions for repair
  • Unplug refrigerator
  • unload food from freezer
  • remove icemaker if present (there are 3 screws remove the one on the bottom and loosen the 2 on top of icemaker then lift it off the 2 screws unplug from wiring harness)
  • remove 2 screws holding rear cover in place
  • move cover to the side or remove from unit altogether
  • defrost any and all ice from bottom of freezer and aluminum drain pan that is now exposed
  • flush drain hole that you will see once ice is cleared with warm water. (sometimes I use a large syringe or turkey baster to forcefully flush hot water thru the drain tube)
  • reassemble in reverse order
These are general instrutions for most top freezer refrigs. but if you need more specific directions dont hesitate to ask Thanks Peyton
Posted on Mar 21, 2009
  • 531 Answers
SOURCE: Ice maker makes hollow ice cubes.
check freezer
Posted on Mar 31, 2009
lojacksdad
  • 121 Answers
SOURCE: Water collects in bottom of refrigerator and gets in bins
there is a cup in the back wall of the fridge that is the drain pull it out gently and clean it plus take a small hose and blow through the small hole if there is no cup check under the crisper to see if the drain hole is there
Posted on Apr 17, 2009
I have a KitchenAid side by side fridge, type 25SSA, water is leaking from bottom of ice maker down front of freezer and into ice bin, how do I stop leak?
Is the refrigerator and the ice maker level? Does it appear that the ice maker is over filling or slowly overflowing due to a leak in the Click here=> W10408179 Refrigerator Water Inlet Valve? Look in the rear of the ice maker where the water fill tube enters the ice maker do you see water freezing and running down to the ice bin from there? Let me know.
http://appliance911seabreeze.com/
Nov 14, 2015 | KitchenAid Refrigerators
The ice maker is not working right
replace the water valve and clean the coils undrer neath . ( make shure the fan under is working . mm
Jul 03, 2010 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Ice Maker leaks water inside the freezer
I see you said you looked and the water valve is off but the only that I know of this happening is a defective water control valve. Like a dripping faucet that when off slowly drips until the ice forms and then one the ice maker dumps ice and tries to refill the water goes in every direction. Unplug water valve to confirm what I am saying, Tell me if it continues to leak. Sea Breeze
Apr 19, 2010 | GE 21.7 Cu. Ft. Top-Mount Refrigerator...
We have a side by side refrigerator with ice maker that leaks water on to the floor.The water also runs into the freezer part and freezes under the bottom bin. It will not make ice but the ice maker...
Could be one of several things.
The cold water reservoir in the refrigerator could have a leak. Usually located on the back wall behind the drawers.
The ice maker may not be operating properly either, or the hose leading to it may be leaking.
Or the ice maker mold may be cracked.
Or the ice maker fill tube has gotten misaligned with the ice maker.
Let me know what you find, and I can give you more direction.
All assumes the ice maker is acting as you describe. There are situations where the drain tube under the freezer coil will clog, preventing water from properly draining from the defrost cycle.
Dec 16, 2009 | Coffee Makers & Espresso Machines
Leaks into cube bin and freezes up
don't understand what you mean,if you're saying water is dripping into the ice maker more than it should you have a bad water valve,
Nov 25, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Ice in the bin on subzero 632 freezer is in clumps
if the ice maker leaking it's easy to replace, or may be just a water supply tube has been moved to the side
Oct 03, 2009 | Sub-Zero 632 / S
Whirlpool 4317943 Ice Maker Kit The ice tray overfills with water. Excess water drips into the ice bin & freezes
Probably the dual valve (solenoid) the one that opens when the ice maker calls for water is leaking.It's located in the back of the refrigerator at the bottom behind the cover.To be sure this is the problem turn off the ice maker and after a while if is water the valve is leaking ,if not the problem is with the ice maker.
Aug 23, 2009 | Freezers
WE have replaced our ice maker in our Whirlpool refrigerator 4 times in the last 4 years. Our refrigerator obviously is a Whirlpool and the ice maker was ordered with the ice maker installed. WE are...
If the fill tube gets choked up with ice, (Figure S-4) it usually means that the water fill solenoid valve is leaking. The valve is not closing properly and is dribbling water. If the leakage is slow enough, water may freeze in the fill tube. Over time it will freeze the tube completely shut.
Apr 04, 2009 | Refrigerators
I have a Whirlpool refrigerator model et22dq. The ice maker makes ice and dumps it but won't dispense thru the door. It seems to freeze in the ice bin. Could there be a water leak inside the ice maker?...
Nov 21, 2008 | Whirlpool Refrigerators
Ice Maker Overflowing
i would recommend changing the water valves as they may be sticking or leaking now you can take the icemaker loose get a small baby bottle short the terminals to cycle water fill catch it with the bottle and see how much water it dumps should be about 4 ounces if the valve leaks will over fill the ice maker over a period of time say the valve is leaking a few drops at a time and the bail arm has the icemaker shut off because its touching ice in the bin but the water just keeps dripping down the fill tube till it runs over did you replace the whole icemaker or just the motor module
Jan 01, 2008 | Maytag MSD2434GE Side by Side Refrigerator
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
13 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
