After soak it wont wash
When it goes to spin it just stops a bunch of lights come on
  • 20 Answers
SOURCE: washer will not spin, will not spin in any spin cycle
Your water pump is clogged
Posted on Feb 10, 2009
SOURCE: washing machine wont spin, water still left in drum
machine wont spin just turns back and forth
Posted on Jun 01, 2009
  • 53 Answers
SOURCE: my kenmore front loader wont spin fast. it will
Check your drain and make sure it isn't plugged. If ok then remove the bottom panel on the front of the machine. Under it is the washer pump. The pump is either clogged or bad. The washer will not go into a full spin when the water isn't draining properly.
Posted on Sep 16, 2009
barkencoa
  • 3463 Answers
SOURCE: washing machine wont drain keeps bleeping ERR2
It will not spin with water in.
See if you can locate a filter, and clean same.
Posted on Jan 19, 2010
SOURCE: Whirlpool washing machine AWO/D 4305 does not spin
its probably an inbalanced load or its to light.it MUST have a good full mixed load to spin
Posted on Jan 28, 2010
Wme8227b broken?
Possibly blockage in pressure system
Jun 13, 2013 | Washing Machines
Simpson eziset 550 stops at rinse cycle, light flashing
I had the same problem before, but removing the kink in drain hose does the trick. Maybe yours is more complicated but try it.
Aug 28, 2012 | Washing Machines
Washer wont drain. fills with water. goes through wash cycle but wont drain. once it gets to the spin cycle, it spins for a few seconds and then stops and rinse light comes back on.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 21, 2011 | GE Washing Machines
It is a much older style washing machine. I put a load of clothes in then went to switch the load and i realized that they were soaking wet. The spin is not working.
Check the spin belt and the relay that engages it. Also make sure that your time is going to the spin cycle and not stopping short of it. If your machine has a two speed motor which goes into high speed for the spin, this might be defective.
Feb 03, 2011 | Washing Machines
It will not agitate or spin.
needs new bushes to electric motor common fault when the bushes wear down it cuts power to machine this will stop washer from washing and spinning
Jan 11, 2009 | Bosch Nexxt 100 Series WFMC1001UC Front...
HOTPOINT AQUARIUS WF 250 ON/OFF LIGHTS FLASHING
The lights are set off by the balance sensors.And if your balance sensors are  stopping    it from spinning than you first have to make sure the washer is level.You  could have bad Shocks and a bad electronic control board,.
May 05, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Wont Spin
Hi Vixxy, Which lights flash when you hear the beeping?
Jul 23, 2007 | Fisher and Paykel GWL11 Top Load Washer
Washing Machines Logo
10 people viewed this question
Top Washing Machines Experts
