Question about Canon PIXMA iP3600 Photo Printer
IP3600 how to reset memory after error - Canon PIXMA iP3600 Photo Printer
Conon won't recongnise the cartridge when i just refill it manually?
The cartridges for the IP3600 printer have a chip on them that needs to be reset before the printer will accept the newly refilled cartridge. if you don't have the resetting device then unfortunately refilling these cartridges won't help you at all.
Feb 20, 2015 | Canon Pixma iP3600 InkJet Photo Printer
Error 6502
this error indicates a problem with an ink cartridge. this can include a bad cartridge, improperly installed, or possibly ink leaking out when installing it.
reinstall ink catridges.
Oct 17, 2013 | Canon PIXMA iP3600 Photo Printer
How Do I remove the casing on a Canon iP3600 Photo inkjet printer? I have removed the drip tray for the ink nozzle and cleaned it but, with little foresight, now found out I cannot replace it correctly...
Hello
To reset the waste ink error you will need to download a reset program. This resets the printer counters back to zero and the printer will work again as normal. You can download this reset program from our website.
<a href="http://www.wasteinkpads.com/">waste ink reset</a>
Thank you.
Aug 29, 2013 | Canon Pixma iP3600 InkJet Photo Printer
Not printing - Flashes 14 times
My printer IP3600 Canon flashes 21 times alternatively between green and orange. It then gives me an Error Code C000. How can this be fixed?
Sep 10, 2012 | Canon PIXMA iP3600 Photo Printer
Error 6C10 keeps coming up on my Cannon Prixma ip3600 and it will not print. I had a look at a few other blog posts and tried a reset using the power and reset button, but no koy. Any ideas?
6C10 error (valve cam sensor error) is a mechanical problem in the purge unit area where the valve cam sensor is located (on the purge unit just behind the power switch button). On my experience, the movable gear assembly (with spring on top) can't move downward to move the other gear that is connected to the valve cam therefore the sensor is not sensing any movements.
Solution:
1. Open the entire top cover.
2. Locate the purge unit (the area where the ink carriage rests when not in use).
3. Move the carriage to the middle of the printer to access the purge unit.
4. Try to gently move the gear assembly downward using your finger or a screw driver to loosen the stuck gear.
5. Turn on the printer to test.
Oct 12, 2011 | Canon PIXMA iP3600 Photo Printer
Canon IP3600, error # 6A80. Can't fix the issue
I have pixma ip3600 canon printer, been used 8months working fine, but today, when I turn on just wait for little whileand the amber light turn on, and when I open thetop cover the printer head won't move at all, please show me how to fix the problem. thanks. Email ( bui_lac972@yahoo.com )
Apr 13, 2011 | Canon PIXMA iP3600 Photo Printer
Have error code B200 on my canon ip3600?
how to fix error B200 of ip2770 printer?
Mar 26, 2011 | Office Equipment & Supplies
Canon PIXMA IP3600 Service error 6C10, and doesnn't print at all
Try keeping the paper only in the bottom tray (there's a tray in the bottom) Try pulling any paper out of the top and just close that top tray. Open up the head so that u can see the ink cartridges and turn the printer on and off and maybe it will center itself again. If it's still not working (even if lights aren't red and print head wont align in the center) try manually moving the head back and forth like 18 times so you can lubricate that rail in the back that's holding it. After that, re-turn it off and on again.
Sep 27, 2009 | Canon PIXMA iP3600 Photo Printer
Canon PIXMA iP3600 Photo Printer Logo
18 people viewed this question
old marine
old marine
