Question about Samsung Televison & Video
Have a Samsaung BD-P4500 that will eject the disk before it will play
Unit ejects disk before it can play I do not have the remote
  • 15 Answers
SOURCE: vcr not playing tapes, just ejects them
Not enough info. What is the product? Brand, model, how old?
Posted on May 13, 2007
  • 3 Answers
SOURCE: Disc Tray Will Not Eject
Just next to the eject button on the actual recorder there should be a tiny pinhole.  If you use a small paperclip and insert it, then push, you should be able to manually eject the DVD.  Hope this helps!
Posted on Oct 16, 2007
  • 259 Answers
SOURCE: LG BD 300 blue ray player won't play dvds
have you tried more than one dvd ?? i have heard that even the slightest mark on a disc and they won't play hope this helps regards Jim
Posted on Apr 09, 2009
  • 46 Answers
SOURCE: DVD won't eject from magnavox MWD2206
Do u see a small hole in the front plate of the dvd player?
if you do ur in luck, unravel a large paper clip to make it straight, then very slowly push it straight into the hole until you see the dvd open.
If no hole then u will have to open the case while it is unplugged.
Posted on May 24, 2009
SOURCE: DVDR 3460H - problem ejecting disk
1) Turn it upside down.
2) Turn it on
3) Press eject button & use screwdriver with special slot
Similar example
http://www.ryan.com.br/prod_dvp642_ejection.htm
Posted on Oct 16, 2009
Samsung bd-p1600 keeps ejecting discs on its own and refuses to play blu ray discs
If it does this with all disks then the problem is with the unit itself. U can try a firmware update but that is usually to improve the players ability to play some newer releases - no effect on older ones that should play properly.
Aug 31, 2017 | Samsung Televison & Video
Samsumg bluray e6500 keep ejecting
Reduce any lights or reflections that can be detected by the "remote eye" on the player. Increase the distance to other electrical equipment.
Mar 30, 2014 | Samsung BD-E6500 3D BluRay Player No...
I put a disk in and there was already one in now it wont eject
The disc tray does not eject when the OPEN/CLOSE button is pressed. Solution
sp.gif sp.gif Follow the steps below to troubleshoot this issue.
    IMPORTANT: The disc tray will not open while a disc is loading; this is normal operation. If this is the case, wait until the disc is finished loading before pressing the OPEN/CLOSE button to open the disc tray.
  1. Make sure the disc tray is not locked; if necessary,
  2. Perform a power reset.
    1. Press and hold the POWER button for 10 seconds until the BD player turns off.
    2. After the BD player turns off, press the POWER button again to turn it back on.
  3. Attempt to open the disc tray by pressing the OPEN/CLOSE button on the front of the BD player.
  4. If the disc tray still does not open and a disc is stuck inside, follow the steps below to force the disc tray to eject:
    1. Turn off the BD player.
    2. Turn the BD player back on.
    3. Immediately after POWER ON is displayed, press the STOP button on the front of the player. IMPORTANT: Only use the STOP button on the front of the BD player. The remote control cannot be used for this operation.
      NOTES:
      • The disc tray should eject and the BD player will turn off. If it does not eject, repeat steps A-C.
      • It may be necessary to press the STOP button in step C two or three times.
If the issue is still unresolved, service may be required
Sep 15, 2011 | Sony BDP-S300 Blu-Ray Disc Player
I have a Pioneer DVR-57H and I was playing a CD. While playing the CD I physically hit the eject button on the face of the unit and nothing happened. Now I can not either eject the disk or even play that...
Did you try unplugging the power to the unit, then holding the eject button while you plug in and power it back up? Sometimes this releaves the "Logic Lock" caused by a frozen process on DVR and DVD units.
Aug 24, 2011 | Televison & Video
Hi - we have a Roberts MP53 DAB radio. When finished playing the cd we press eject with either the remote or on the unit and although it says eject on the screen it doesn't. After about 10 secs the visual...
Mine did the same at first. I turned mine upside down and pressed eject and that worked to get the CD out then let it warm up to room temp and all is well.
Jan 16, 2010 | Electronics - Others
My samsung BD-P2500 Bluray player is stuck at a load message
Hi.
First try disconnecting power cord for five minutes. On restart keep playing eject while the unit is starting up, to eject if there is a disk stuck inside.
Contact Samsung support number, listed on the owners manual. If a firmware update is available they will guide through the update.
If the firmware update does not fix the problem, then the BD player may have a defective or dirty lens.
Using lens cleaner can invalidate warranty, talk to Samsung first.
Dec 14, 2009 | Samsung BD-P2500 Blu-Ray Player
My uv8 wont eject my disk
I suggest you disassemble the radio and take it out that way. While your in you can check on the blockage. Shouldn' t be hard. Good luck.
Jun 07, 2009 | Jensen Car Audio & Video
2) Turn it on
Similar example
Mar 23, 2008 | Philips DVDR3450H DVD Recorder/HDD...
DVD tray will not open
When a disk is stuck inside the player , try following the procedure below:
Unplug power cord.
Plug back power.
Turn on the unit and press repeatedly the eject button at the same time. If you successeed in ejecting the disk before the player starts reading TOC(disk initial track), then the disk will eject.
If that does not work, then there is an internal fault, in that case the unit must be taken apart to remove the disk.
Feb 25, 2008 | Dual Presidian DVD Recorder
Cd is stuck
put the same disk in , play it for a while then eject it properly.
Nov 13, 2007 | Pioneer AVH-P6500 Car Video Player
Televison & Video Logo
60 people viewed this question
Jerry Greenberg
Jerry Greenberg
