Question about Onkyo TX-DS787 Receiver
No TV sound
I connected my TV to video 3 in. I can't get my TV sound through the amp.
I am trying to connect my Onkyo DS-A3 ipod dock to my Onkyo TX-SR508 receiver and I cannot get the TV to display the ipod menu. I've connected the red and white (R/L) and yellow video cable to the...
Is OSD set to ON? See below
Set the OSD (onscreen display) mode before you start using the RI Dock. 1. Plug in the AC adapter. 2. Turn on your TV and amp, and select the appropriate inputs on your TV and amp. 3. Insert your iPod into the RI Dock. 4. Select the video output mode depending on the video connection. While pressing the remote controller's [SETUP] button, press the Up [ ] button for the component video connection, press the [ ] button for the composite (default) connection. 5. Use the remote controller's [MODE] button to set the OSD mode. On: Playlists (artists, albums, songs, and so on) are displayed on your TV, and you can navigate and select your music or video while looking at your TV. While this mode is selected, your iPod displays the Onkyo logo. Off: Nothing is displayed on your TV and you navigate and select your contents by using your iPod's display.
Mar 15, 2017 | Onkyo Audio Players & Recorders
I,ve connected my wii to the led tv using a wiii component cable(5 leads) but have used only 3 of them red green & blue 1,s leaving a red & white 1 left i have good picture but no sound help please
your cable is split into two different connections for your tv... the red green and blue cables are for HD only. They are their own little set. the yellow cable is your video cable for normal tv's. the red and white cables are sound cables, also for normal tv's. I would unplug the red, green, and blue cables, and use the yellow, red (right sound), and white (left sound).
Dec 31, 2010 | Nintendo Wii Console
Dynex dx-32l151a11 the picture is black and white with the dvd player
With a Black and White picture it sounds like you're trying to connect the DVD Player's "Composite" connection to the TV's Component Connection.
Composite is a 3 wire system with Yellow for the video, and red and white for the audio. On your TV this connection is located on the side.
Component is a 5 wire system, with Blue, Green & Red for Video, and Red and White for audio. On your TV this connection type is located on the rear panel.
Check to make sure you are hooking the DVD player & the TV to the same input types.
Dec 26, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
I have a JVC AV-27D501 TV, I'm trying to connect a DVD player to the TV but not able to get the Video or Audio. My DVD player has Video Out (Yellow) and Audio out (white & red). Connected the AV cables...
I'm assuming the cable was plugged correctly - the colors matched. VIDEO 3 is for the front connectors so it should have worked . Since it hasn't then one of the three parts in this setup (tv, player, cable) is defective. To find out which you must do some simple tests:
1. replace the cable and try again.
2. take your player and connect it to a surely functional tv - if it doesn't work in there then it's defective.
3. get another player that is surely functional and connect it to your tv - if it doesn't work then the AV switching IC from your tv (soldered on the mainboard) is defective and it will have to be replaced. Call a repairman, there is nothing more you can do.
Nov 06, 2010 | JVC AV-27D501 TV
My Yamaha RX-863 has no sound out of Component connection 3? I have an TV that only has "1" HD component connection. I do not have speakers yet, however, in the meantime I want to connect it to the TV. ...
If you mean the HDMI connections, the Out near #3 is the one that should carry audio and video to the TV after you go to page 101 in the manual (available at retrevo.com) and select HDMI SET = OTHER until you get speakers.
Later on, when you have real speakers, I'd recommend you take the TV out of the audio equation and let the receiver have direct digital input connection to each source you want to watch or hear.
Aug 17, 2010 | Yamaha RX-V863 Receiver
No picture
have you connected up correctly, have you selected correct EXTERNAL inputs, you do NOT "tune" a Channel to see picture, you choose external AV input on set. Must connect color to color. 3 for Composite Video AV.Yellow, Video, Red & White Audio. and 5 cables for Component 3 for Video , & 2 for Audio Blue, Green, Red, Also Red & White, Audio.
AV
Mar 18, 2010 | Panasonic DMR-ES10 DVD Recorder
When I try to play a DVD or VHS on my GO Video DVD/VCR Combo machine, I get audio but no video & the TV (Sanyo 37" HD) says "No Input". I've checked connections, the TV has multiple video inputs but I...
  1. I found the problem - on the back of the VCR/DVD unit there are 3 outputs: L (Wht) & R (Red) Audio + Yellow Video out. The cable from it to the TV was labeled Red/Audio,White/Video, and was connected to the R & W outs, but actually the Wht should have been connected to the Yellow Video out. There is so little space in the TV cabinet/stand that even though I turned the unit around to see the connections, I couldn't see the other (Yellow - Video) out until I pulled the cables out. It's working fine now - I'm not sure how things got connected wrong, since it was working OK before - possibly when I signed up for AT&T U-Verse & the installers moved things around. I'm very happy with that service, by the way - better than Comcast & cheaper, and didn't mean to imply the connection problem was their fault. I may have moved things around in the new cabinet & not realized I hooked up to the wrong outs...
Jan 03, 2010 | GoVideo Go Video DVD/VCR Combo
How to connect dvp 3356 t0 samsung 29 inch tv with crt tube.
Please check the connection. If you are connecting the 3 RCA cables to DVD component input/output, you need another pair of RCA cables to connect to audio out (FL&FR rear of DVD player) and Audio in (L&R) in your TV set. Else connect 3 RCA cable in 1-Video out & 2 Audio out of DVD player and 1-Video in & 2 Audio-in of TV.
Dec 15, 2009 | Philips Televison & Video
Onkyo TX-DS787 Receiver Logo
15 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
