Question about Alpine Cde-136bt Car Cd Receiver W/ Bluetooth Cde136bt
Factory reset alpine cde-136bt
How do i factory reset this unit?
simplemitch
  • 752 Answers
SOURCE: Alpine CDE-9843
Page 16 of the manual:
http://vault.alpine-usa.com/products/documents/CDE-9841,%2043,%2045%20OM.PDF
Setting Time
1 In the Clock priority mode, press and hold
TITLE for at least 2 seconds while the time is
displayed.
The time indication will blink.
2 Turn the Rotary encoder (CDE-9845/CDE-9843
only) or press
4 and 3 (CDE-9841 only) to adjust
the hours while the time indication is blinking.
3 When the hour has been adjusted, press the
Rotary encoder (CDE-9845/CDE-9843 only) or
press MODE (CDE-9841 only).
4 Turn the Rotary encoder (CDE-9845/CDE-9843
only) or press
the minutes while the time indication is blinking.
The time is automatically set 5 seconds after the minute
adjustment. The time can also be manually set by
pressing the Rotary encoder (CDE-9845/CDE-9843 only)
or press MODE (CDE-9841 only).
• To synchronize the clock to another clock/watch or radio time
announcement, press and hold the Rotary encoder (CDE-9845/
CDE-9843 only) or press and hold MODE (CDE-9841 only) for at
least 2 seconds after setting the “hour.” Minutes will reset to 00. If
the display shows over “30” minutes when you do this, the time
will advance one hour.
Posted on Aug 05, 2008
creativeleeh
SOURCE: Where is fuse in Alpine CDE 9842 Car Reciever?
Had to take the vehicle back in to the repair shop. Good thing. Found smaller fuses blown and wires crimped behind stereo in dashboard. Told this could have been the original reason for main fuse failing. Works like a charm now, auto antanna raises, seatbelt light beeps and security system lights up. Stereo also works.
Posted on Sep 23, 2008
SOURCE: Connecting High Speed IPOD Cable to Alpin CDE-9874
Best Buy solved my problem.
Posted on Oct 02, 2008
etirbynnor
  • 655 Answers
SOURCE: Alpine CDE-102 w/usb port: will not
Hello desoren,
The receiver may not be set to recognize MP3 files.
Press and hold "sound setup" until the unit enters setup mode. Rotate the volume knob to "play mode" and press "enter". Check that the setting is CD/MP3 (not CD/MA), or rotate the volume knob to change the setting to CD/MP3 and press enter again. Press and hold "sound setup" again until the unit exits sound setup.
If the files are still not recognized, I'd try using a different USB drive, a different computer to write the MP3's, and/or a different application to download or rip the original music content.
Hope this helps.
Posted on Sep 23, 2009
etirbynnor
  • 655 Answers
SOURCE: i am getting a DC error on my alpine cde-102 head
Hello christo12385,
The DC error is most likely caused by a shorted or grounded speaker wire. Check all speaker wires, correct the problem, and then go into the sound setup settings and reset the POWER IC to ON.
Hope this helps.
Posted on Sep 25, 2009
DLink password
To perform a reset, please follow steps below:
Step 1 With the unit on, place a paper clip into the hole on the back on the unit labeled Reset.
Step 2 Hold paper clip down for 10 seconds and release.
Note: Do not repower unit during this procedure.
Step 3 The unit will reboot on its own. Once the WLAN light stops blinking, the unit is reset.
Resetting the router does not reset the firmware to an earlier version. It will change all settings back to factory defaults.
Note: The factory defaults username is admin, and there is no password.
Mar 28, 2012 | Computers & Internet
Ho to reset D-Link DES-1228P 24-Port Ethernet Switch to factory default setting?
This article teach you how to D-Link router to restore factory settings,di-524 as an example.
Step 2 Hold paper clip down for 10 seconds and release. (Note: Do not repower unit during this procedure.)
I hope this information will be helpful. Thank you for using FixYa!
Jun 08, 2011 | D-Link DES-1228P 24-Port Ethernet Switch
Alpine head unit CDE-9870 will not play sound through speakers of a 2003 pontiac vibe. what could be some issues to cause this?
This generation of Vibe may have the upgraded audio system installed from the factory. In order to get the audio from an aftermarket radio to play through the factory amp, the factory remote turn-on lead must be located. If you are using an adapter harness, it may have the wire installed, just attach the blue/white stripe wire from the Alpine to the blue or blue/white stripe wire on the aftermarket harness adapter.
Mar 01, 2011 | Alpine CDE9870 CD Player
A few months ago someone was getting into my router & downloading movies, I assume. Had a tech help me put in a password to secure it. Forgot the password & now can't use my ipod touch at home. Any...
Yes there is.. BUT you'll have to set up the security again... Fortunately DLink has a handy setup wizard which you can access here.. http://support.dlink.com/emulators/di514_revc/h_wizard.html
This will work right on your browser. You might want to test that it works on your system before wiping the router. (Just start it up then cancel if it starts)
Find the recessed reset button on back of the router close to the power input. Press and hold it with paper clip or pen tip for 10 - 15 seconds. This will restore it to factory settings.
You should use a wired connection to access the internet after that, no password. Go to the link above and use the online wizard to setup the router with encrytion and new password.
If it all orks wout for you kindly give me a rating. Thanks.
Jan 29, 2011 | D-Link DI 514 Wireless Router (DI-514)
How do i reset my d-link dir-615 to factory settings
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 20, 2010 | D-Link DIR-615 Wireless Router
I have WGT624 v2 used for years and in a pretty good condition. Unfortunately, it suddenly doesn't work recently. No internet connection at all. The power LED light keep blinking and the color change...
Nov 20, 2010 | NetGear WGT624 Wireless Router
I have a dvdvr375 that needs factory reset. How?
Try unplug,replug the unit back an hour later,should have everythings,reset to Factory setting.If no,electronic component's parts burn in ur device.
Jul 29, 2010 | Samsung DVD-VR375 DVD Recorder/VCR
Alpine Cde-136bt Car Cd Receiver W/ Bluetooth Cde136bt Logo
159 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
