Hotpoint wma44 will not spin - Washing Machines
2 Suggested Answers
barkencoa
  • 3463 Answers
SOURCE: hotpoint aquarius extra manual WMA44 can't find the waste pipe
Remove lower rear cover of washer, locate, and remove large black hose fastened to bottom of drum, remove and clean plastic filter inside hose.
Please rate my solution.
Thanks.
Posted on Aug 28, 2009
Very loud noise on spin, something stuck between drum
unscrew the screws in back the what ever has ben lodged should be receaved make sure your legs is balanced out after so many washes they go off balance.
Jan 31, 2011 | Hotpoint WMA44 Front Load Washer
Operates ok but very noisy
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems
Washer noise when spinning
heatman101
Dec 24, 2010 | Hotpoint WMA44 Front Load Washer
Wma44 hotpoint washer. Did a wash as normal and
Sometimes a weak or broken spring in the door handle can be the cause of the problem, but you would have to take the door apart to check this.
If you have already fitted a new door lock, then chances are it is the control board, but I would check the door handle first.
Jan 30, 2010 | Hotpoint WMA44 Front Load Washer
WMA44 Hotpoint machine - the door light continues to flash before starting... what could be the problem
Could be a broken spring in the door handle, you would need to take the door apart to check this.
Jan 16, 2010 | Hotpoint WMA44 Front Load Washer
Drum bearing very noisy on my hotpoint wma44 wshing machine
Sounds like the seals have gone as did the ones on mine. It need a complete new spider frame and bearing set as the front bearing had collapsed and groved the bearing spindle. Open the door and try lifting the drum to see if there is any up/down movement.
Aug 31, 2009 | Hotpoint WMA44 Front Load Washer
DRUM BEARING NOISY ON HOTPOINT WMA44
RepairClinic.com (which is good)
espares.co.uk
AppliancePartsPros.com
Try these sites with your model number
Feb 27, 2009 | Hotpoint WMA44 Front Load Washer
Hotpoint wma44 - water not draining
I guess you or a friend will have to get out and get under to strip out the pump and take a looksee. Put your bathing suit on.
Sep 14, 2007 | Hotpoint WMA44 Front Load Washer
Wash starts it fills with water then stops and wont wash
problem may just be that drum is not turning so you think program is stopped. try cancelling and select spin program and see if you get spin
Apr 01, 2007 | Hotpoint WMA44 Front Load Washer
Door Lock
door lock blown this sometimes blows tracks off the main pcb behind the control panel. appliance doctor
Jan 29, 2007 | Hotpoint WMA44 Front Load Washer
Washing Machines Logo
11 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
