Question about Hitachi Touro Computers & Internet
Touro mobile 3.o USB Device
Hi there, the hard disk is recognized in the device manager but not in the explorer and in the disk manager in Windows XP SP3. I will apreciate a lot if some of you can provide me with a solution to this problem. Thanks in advance
Beni S-P
  • 1006 Answers
SOURCE: usb device not recognised
First try this OPTION:
Possibilities:
1) One of your USB devices have faulted, or is causing a resource conflict (or similar)
-- Remove all USB devices, and reboot.
2) Your USB chip/ports have been damaged.
-- Find a spare HardDisk or bacjup your data and re-install Windows and see how that goes.
3) Your Power Supply Unit (PSU) isnt supplying enough power to your PC (usually caused by a Video card upgrade). Try a more powerful PSU ... 400watts should do the trick
4) Bad memory (RAM) can cause wierd problems. run memtest for an hour to make sure your memory is ok
It seems that many people are still getting the 'USB Device not Recognized' problem from time to time. Unfortunately there is no easy fix.
Firstly, it's recommended that you make sure every one of your motherboard drivers are completely up-to-date, but you probably already knew that.
In XP, after a USB port isn't used for a long while the USB driver built into the OS sets the OHCI controller to suspend. When you plug a device back in, it can sometimes fail to 'wake up' properly. This problem was supposedly fixed in SP1 but there is a related registry hack that may still be able to help.
Run regedt32.exe and navigate to;
HKEY_LOCAL_Machine\SYSTEM\CurrentControlSet\Services\Usb
Create the Usb key if it doesn't already exist. Under this key, create a new DWORD value called DisableSelectiveSuspend and give it a value of 1. Then restart the PC.
A long shot perhaps, but I recall having similar problems with a USB hub built into my Microsoft keyboard and adding this key seemed to solve it. It wouldn't hurt in trying .
Alternatively, removing all entries relating to USB in Device Manager and all associated USB drivers will force XP into refreshing the USB driver stack.
Begin by unplugging all USB devices, then use Add/Remove Programs in Control Panel to uninstall any USB driver software. Next, boot up into safe mode and go to Device Manager. Once in device manager make sure 'Show hidden devices' is checked under the View menu. Uninstall all device entries in this order;
1. USB peripheral devices (printers etc.)
2. HID and/or Composite USB (Human Interface Devices) You're using PS/2 input devices so you may not have this entry.
3. USB Root Hub(s)
4. USB Host Controller(s) (Universal or Enhanced Host Controllers)
Then boot back into Windows (not safe mode) and it should populate the Root Hubs & Host controllers again. Proceed to plug your USB devices back in, starting with your powered hub. Be aware that most USB printers and scanners need to have their drivers installed first before you plug them in.
Hopefully some of this may be of help, let us know how you get on.
IF STILL NOT WORKING JUST BUY NEW EXTERNAL ( JUST EXTERNAL NOT HDD )
And rate me as fixya if u got help!
Posted on Dec 22, 2007
zzptichka
  • 95 Answers
SOURCE: My external hard drive is unreadable
Does you drive make any sounds like these? If yes you have a mechanical problem and you should get a specialist to work on it. If not - try to remove the drive from USB casing and connect it directly to your PC or put into another USB enclosure. This should help if the problem is with the enclosure itself and not with the drive.
Posted on Dec 30, 2008
Geekman
  • 32281 Answers
SOURCE: Lacie 250GB Hard Disk is not being recognized by PC (Windows XP)
Some PC's cannot deliver enough power to the USB devices to function properly through the USB port.
Does your Lacie hard disk have a power input connector if so conect a power adapter to it before you put it into your USB port.
Another alternative, get a powered USB hub connect it into your computer then connect the Lacie hard drive to the powered USB hub.
Posted on Jan 03, 2009
SOURCE: Zippy USB external hard disk case (2.5
I know this is an old thread, however if it helps any one try this:
Zippys power supply failed for me also. The problem here is your case support USB 2.0 ("A high speed USB device") and your port is only USB 1.1 ("plugged into a non-HI-SPEED usb hub"). This will not give adequate power to the drive. So use a y-cable (http://www.toshibadirect.com/images/ui3/accessories/toshiba-usb-y-cable-ba82010-300.gif) and connect one end to your casing and the two pins at the other end should be connected to two USB ports. (get it at http://www.toshibadirect.com/td/b2c/adet.to?poid=438342).
Another costlier way is to upgrade to USB 2.0 by a card like this http://www.belkin.com/support/download/download.asp?category=1&lang=1&mode=
or even better a USB 3.0 card : http://www.asus.com/product.aspx?P_ID=lGYmelQ8mJvPtYTv
Posted on May 24, 2010
shibuda
  • 1812 Answers
SOURCE: How can I install internal
Hi
Disassemble the laptop, follow the bellow link for details,
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-1200/take-apart-laptop-1.htm
http://www.irisvista.com/tech/laptops/Toshiba-Tecra-A2/notebook-disassembly-guide.htm
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-L355D/laptop-disassembly-1.htm
For install xp follow another link,
xp setup not detect hdd http://www.microsoft.com/downloads/en/confirmation.aspx?FamilyID=0856EACB-4362-4B0D-8EDD-AAB15C5E04F5&displaylang=en http://www.raymond.cc/blog/archives/2008/01/21/install-xp-setup-did-not-find-any-hard-disk-drives-installed-in-your-computer/ http://www.nliteos.com/download.html http://www.howtogeek.com/howto/windows/resolving-setup-did-not-find-any-hard-disk-drives-during-windows-xp-installation/ Hope this helps,reply me for further instruction,
Posted on Feb 27, 2011
Does microsoft office and student 2010 work in xp
If you would be planning to use microsoft office and student 2010 on xp you have to have SP3 of XP. You may refer to system requirements given below.
Office Home and Student 2010 Component Requirement Computer and processor 500 MHz or faster processor Memory 256 MB RAM; 512 MB recommended for graphics features and certain advanced functionality.1 Hard disk 3.0 GB available disk space Display 1024x576 or higher resolution monitor Operating system
Windows XP (must have SP3) (32-bit), Windows 7, Windows Vista with Service Pack (SP) 1, Windows Server 2003 with SP2 and MSXML 6.0 (32-bit Office only), Windows Server 2008, or later 32- or 64-bit OS. Graphics Graphics hardware acceleration requires a DirectX 9.0c graphics card with 64 MB or more video memory. Additional Requirements Internet Explorer (IE) 6 or later, 32 bit browser only. IE7 or later required to receive broadcast presentations. Internet functionality requires an Internet connection. Multi-Touch features require Windows 7 and a touch enabled device. Certain inking features require Windows XP Tablet PC Edition or later. Speech recognition functionality requires a close-talk microphone and audio output device. Internet Fax not available on Windows Vista Starter, Windows Vista Home Basic, or Windows Vista Home Premium Information Rights Management features require access to a Windows 2003 Server with SP1 or later running Windows Rights Management Services. Certain advanced collaboration functionality requires connectivity to Microsoft SharePoint Foundation 2010 or to Microsoft Office SharePoint 2007. Certain online functionality requires a Windows LiveTM ID. Other Product functionality and graphics may vary based on your system configuration. Some features may require additional or advanced hardware or server connectivity; www.office.com/products.
Mar 18, 2011 | Computers & Internet
I had a working Dell computer - accessing the internet through a wireless router - computer became unbearably slow - re-installed Windows XP 2002 SP1 everything's fine except the network adapter that was...
You don't say what make/model of network adapter (NIC), whether it's wired or wireless, or if it was operating under the same service pack level before, so I have to make a lot of assumptions.
Is Windows really not recognizing it (ie: does it have an exclamation mark next to the NIC in device manager?) or is it being recognized by Windows but just cannot connect to the wireless router? If the latter, check your wireless configuration (SSID, WPA key, etc). Since you have WinXP SP1, it could be that there is not a driver for that particular NIC. Later service packs include updated drivers as well as bug and security fixes. Recommend you identify the NIC and if you have the driver disk for it, go into Windows device manager to select a reinstall from that disk. If you don't have it, use another computer to download its driver and after installing it and getting Internet access, you should also download and install the latest SP, which would be SP3.
Feb 18, 2011 | Dell Ethernet Card Network Adapter
My iomega 250 GB usb2.0 is starting on one PC having window vista, but it is not detected by another PC having XP. USB port of this pc is working all right since my pendrives are detected and working...
hi,
1) right click on my computer > click on manage. 2) you will see computer management window on left side click on device manage. 3)click on universal serial bus controller
if you see yellow color acclamation mark then their issue with driver and check you have xp SP3.
to check that right click on my computer>click properties. when a windows open you can see computer information you can look there you xp or xp sp2 or sp3 check below Image
if you don't have then download from microsoft.com.
Jun 25, 2010 | Iomega 250GB Ego Portable HD Red 250 GB...
Hard Disk drive do not appear in Disk Management & Device Manager
to fix the problem you must open your laptop check the hardware inside of your laptop hardisk thats the problem try to unplug cables of hardisk to plug again or replace new hardware hardisk if not solve the problem
Jun 18, 2010 | Lenovo 3000 Y410 Notebook
Jan 03, 2009 | LaCie (300728U) 250 GB Hard Drive
No sound after reinstall windows xp sp3.
you cannot downgrade from Vista to Xp unless you format your hard drive or install xp on another partition check your device manager for yellow marks on sound devices and update your sound drivers
Nov 08, 2008 | Lenovo Computers & Internet
Siren MP3 player not recognized by Windows Explorer‏‏
Installing the latest Windows Media Player solved the problem.
Oct 02, 2008 | Siren Edge MP3 Player
Can not find the device when i plug the usb into my pc
You need to used Disk Management, goto Start> Control Panel> Administrative Tools> Computer Management> Disk Management. Select volume/drive, if you found drive doesn't yet assign a drive letter, you need to assigned it by right click at the highlighted drive then assign drive letter then apply.
Finally, you will just use double click or right click explore inorder you to view the data inside your harddrive.
Please rate me SOLVED!
Nov 17, 2007 | Western Digital External USB 2.0 80 GB...
Computers & Internet Logo
27 people viewed this question
Top Hitachi Computers & Internet Experts
Fotis Papastamatiou
steve morris
steve morris
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
