Question about Brother Office Equipment & Supplies
Smudge paper I replace the drum on DCP 7040 using the same cartridge now the paper is smudged.
aomcopier
  • 22 Answers
SOURCE: printer drum light on
Have you already replaced the drum? If you have not replaced the drum that may be why you are getting smudges. If you have already replaced the drum, here is the reset procedure. The Drum LED blinks if the drum unit is near the end of its life. Use the drum unit until you have a print quality problem, then replace the drum unit with a new one. The Drum LED continues to blink if the drum counter was not reset when you replaced the drum. To reset the drum follow the instructions below: Open the front cover of the printer. Press and hold down Go button for about 4 seconds until al the LEDs light up. Once all 4 LEDs are lit, release the Go button. Close the front cover. CautionReset the drum counter only when you replaced the drum unit with a new one.Related Models HL-2030, HL-2030R, HL-2040, HL-2040R, HL-2070N, HL-2070NR http://www.tonerovernight.com
Posted on Mar 31, 2007
micromaster
  • 3614 Answers
SOURCE: Black lines and smudges on paper
Laser printers work by creating latent images on a rotating, light-sensitive drum and then attracting toner to exposed points on that drum. If any point on the drum’s light-sensitive surface is damaged, you may notice that toner is always attracted to that point, thereby transferring to the final page and appearing as a repeating mark. Because the drum is a cylinder, such marks will appear at equal distances down the page, corresponding to each rotation of the drum (maybe every two inches, for example).
The only solution to this problem is to replace the drum. For most low-cost home printers, the drum is part of the toner assembly and is automatically replaced each time you install a new toner cartridge (which explains part of the cartridge’s high cost). More industrial-strength laser printers place the drum on a separate EP (electrophotographic) “engine” that can be replaced in just a few easy steps. Check your printer’s documentation and replace the appropriate assembly (or have someone do it for you), and the repeating marks should go away.
Kindly regards,
micromaster
Posted on Mar 09, 2008
  • 300 Answers
SOURCE: blue color smears on every page
If you're still getting smudges, there must still be a label or part of a label either on one of the image drums or the transfer belt, i've found in the past it somethings gets stuck inside the unit on the cleaning blade. What i suggest is you run a print and open the front door at the paper travels along the transfer belt, look at all the image drums and see if you can see the smudge on one of them, if so the problem is caused by that cartridge if not it's in the transfer belt somewhere. You may need to try stopping the printer a few times and if the problem is in one of the cartridges, you will mst likely have to replace it, as with the transfer belt if you think that's causing the problem it's easier to remove it and rotate the belt manually.
Please note the image drums and the transfer belt are all light sensative
Posted on Sep 02, 2008
  • 85 Answers
SOURCE: laser scanner on dell 5110cn laser printer, prints black smudges
replace fuser. How far apart is the ghost image?
Posted on Feb 16, 2009
  • 77 Answers
SOURCE: I have black smudges on my printouts. I using
This may be the cartridge itself, take the black ink cartridge out and check the head on it (the part that points in to the printer, usually down) and see if it is dirty or has ink smudges on it.
Posted on Mar 12, 2009
Smudge marks on left side of paper?
If you use new original toner, this should not happen, nevertheless, clean the drum first.
Sep 04, 2014 | Brother Laser Printers HL5450DN HL-5450DN...
Brother MFC-7040 smudging
try replacing the drum unit.If that doesn't work look at replacing the fusing unit.there may be a blue slider on the front top of the drum unit;if so slide it back and forth 3 or 4 times making sure it is left in the same position as when you started.
Apr 16, 2014 | Brother DCP-7040 Laser Printer
When i first start my copies on my brother dcp 1000 they are clear by the time i get to copy 20 their are dark ink smudges on the paper. It seems when the copier starts heating up they smudges happen. I...
replace the drum,
( if you have used correct toner for refill because some time it happens if two different type of toner mixed up hence assuming that you have select gud toner).
vote me if found helpful.
Aug 17, 2011 | Brother DCP 1000 All-In-One Laser Printer
Just replaced black cartridge in my 2600n color laser. I have smudged about a half inch wide 2/3rds over the right of each page. It only smudges in black. I have recalibrated several times. Printed at...
If this just started after you replaced the toner cartridge, one would have to say that it is a bad toner cartridge.
Print something that smudges. Pull down the front cover and look at the cartridges. Pay attention to the top one(black).
Look at the drum on that cartridge. You should see the toner sitting there. Compare it to the other cartridges which should be clean.
Feb 08, 2011 | HP Color LaserJet 2600n Printer
I have a smudge on the right side of paper when printing on my lexmark E250dn printer. How can Iget rid of this smudge?
You have a mark on the drum. Find the drum cartridge and rotate the drum by the gear until you find a mark on the surface of the drum. You can try wipe it off with a very soft dry cloth but it is unlikely that this will be a cure and you will probably have replace the drum cartridge (+ $70). Do not try to clean it with any solvents or polishing material.
Feb 02, 2011 | Lexmark Office Equipment & Supplies
Black smudges down left side of page
How do I clean white or black spots on printed documents? Description: First make 10 to 15 copies of a blank, white sheet of paper.
If you still see the spots on printed documents after making multiple copies, clean the drum unit as follows:
  1. Remove the drum unit and toner cartridge assembly, and then remove the toner cartridge from the drum unit.
  2. Position the print sample in front of the drum unit so you will know the exact position on the drum that is causing the poor print.
  4. Turn the black gear on the drum as you check the surface of the OPC drum.
    The OPC drum is photosensitive so do not touch it with your fingers.
  6. When you find the substance on the drum surface that matches the print sample, gently dab the surface of the OPC drum with a cotton swab that is lightly dampened with isopropyl alcohol.
  7. Note
      • Do not use a scrubbing or wiping motion because this might damage the drum.
      • Do not try to clean the surface of the OPC drum with a sharp object, such as a ball-point pen, because this might cause permanent damage to the drum unit.
  8. If the print quality still has not improved you need to install a new drum.
Dec 02, 2010 | Samsung ML 2010 Laser Printer
Printing has smudge on edge
If it is right along the edge then the drum (well the cleaning blade of the drum) is faulty. In a unit like that I suspect it is all part of a toner cartridge. Try replacing that and I think you will be good.
Jan 01, 2010 | Epson AcuLaser C900 Printer
After paper jam, prints total smudge on Intellifax 2800...please
This is the test to determine toner/drum or fuser issue.
Print a test page
When you hear the paper feed into the machine open the top to stop the machine
Remove the toner/drum cart.
You should be able to see the page with printing on it. (This is before the page hits the fuser)
If you can see the smudge or marks on the page the problem is most likely the cartridge but NOT the fuser.
If the page is clean the problem is most likely the fuser.
Mar 13, 2009 | Brother IntelliFAX 2800 Laser Fax
Black Smudge of ink along top edge paper Brother Intelifax 2800
try cleaning the grid on the drum unit otherwise there could be some thing on the fuser preasure roller.
Jan 16, 2009 | Brother IntelliFAX 2800 Laser Fax
Blue color smears on every page
Sep 02, 2008 | HP Color LaserJet 2600n Printer
20 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
