Question about HP Photosmart C7280 Laser Printer
HP 5510 cartridges will not move - HP Photosmart C7280 Laser Printer
SOURCE: HP Officejet 5510 - Replacing Ink Cartridge
this should work for all 5500 hp printers i hope this helps you out richard from chicago i just noticed you have the wrong cartage you need hp 57 color that will make all the difference :-) HP Officejet 5500 series All-in-One model Black cartridge Color cartridge HP Officejet 5505 HP 56 HP 57 HP Officejet 5508 HP 56 HP 57 HP Officejet 5515 HP 56 HP 57 HP Officejet 5510, HP Officejet 5510xi, HP Officejet 5510v HP 56 HP 57 HP Officejet 5600 series Replacing the print cartridges
  1. Turn on the HP Officejet, and lift open the print-carriage access door. The print carriage will move into the access area. Figure 1: Opening the print-carriage access door c00034766.jpg
  2. After the carriage stops moving, push down on the top of the print cartridge to release it, and then pull it toward you out of the slot. Figure 2: Removing the print cartridge c00034767.jpg NOTE: It is normal to see ink buildup in the print cartridge slots.
  3. Remove the new print cartridge from the packaging and gently remove the plastic tape by using the pink pull tab. CAUTION: Do not touch the copper contacts or ink nozzles. Install the cartridge immediately upon removing the tape to prevent ink from drying in the nozzles. Figure 3: Removing the plastic tape c00034768.jpg
  4. Push the new print cartridge into the appropriate slot at a slight angle, until it clicks into place. CAUTION: Do not attempt to push the cartridge straight into the slot. It must slide in at a slight angle. Figure 4: Inserting the print cartridge c00034769.jpg
  5. Close the print-carriage access door.
Aligning the print cartridges The HP Officejet will prompt you to align the print cartridges every time you install a new print cartridge to assure high-quality output.
  1. When the message displays, press OK . The HP Officejet will print an alignment page.
  2. Place the alignment page face down on the left front corner of the glass with the top of the page facing the left side.
  3. Press OK . The HP Officejet will align the print cartridges and display Alignment Complete .
Posted on Apr 07, 2008
  • 240 Answers
SOURCE: hp 5510 io keeps stating to check color cartridge/3 lights blinki
hi..
try to install and reinstall the printer cartridge...and also clean the tab circuit of the cartridge and tab circuit of the printer carrier..
if the problem still exist..
rebreak the printer by full-out the power supply...to reset the settings and then turn it back...
Posted on May 12, 2009
efs_perpends
  • 1996 Answers
SOURCE: where does the cartridge go?
See this article and this site.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Aug 20, 2009
bschilz
  • 2049 Answers
SOURCE: hp 5510 print cartridge error
Here is a link to a step by step procedure to fix the "print cartridge error".
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpa00299&tmp_task=solveCategory&lc=en&dlc=en&cc=us&lang=en&product=311255
If you need the owners' manual, here's a link to it to refer to...
http://h10032.www1.hp.com/ctg/Manual/bpu72474.pdf
Posted on Nov 03, 2009
Testimonial: "Thanks, I should have thought of going directly to hp. The situation is not fxed though...still same error. The unit has set unused for about 3 years."
  • 7 Answers
SOURCE: HP Officejet 5510 error "Remove & check color cartridge
Re: OfficeJet 6310 Tricolor (93/95) Cartridge Stops Working After Replacing B/W (92) CartridgeOptions
04-26-201210:27 PM
1. Remove all cartridges and turn off printer
2. Unplug printer and wait one minute
3. hold down # and 9 while plugging power cord back in.
4. Wait a few seconds, then press the power button.
5. Display should read "Full Null Reset"
6 Only install color cartridge. Close cover
7. Wait for machine to ask for black cartridge, then open cover and install black cartridge.
8. Close cover
9. Alignment page should be printed automatically.
Posted on Apr 27, 2012
Show me where to install ink for model hp officejet 5510
hello!
first, you need to lift up both the ADF unit and the flatbed scanner glass unit.
then, when the print carriage moves into view, press down and pull the ink cartridge for replacement.
Jul 13, 2011 | HP Officejet 5510 All-In-One Thermal...
How do I change the ink in hp officejet 5510
  1. Turn on the HP Officejet, and lift open the print-carriage access door. The print carriage will move into the access area. Figure 1: Opening the print-carriage access doorc00034766.jpg
  2. After the carriage stops moving, push down on the top of the print cartridge to release it, and then pull it toward you out of the slot. Figure 2: Removing the print cartridgec00034767.jpg NOTE: It is normal to see ink buildup in the print cartridge slots.
  3. Remove the new print cartridge from the packaging and gently remove the plastic tape by using the pink pull tab. CAUTION: Do not touch the copper contacts or ink nozzles. Install the cartridge immediately upon removing the tape to prevent ink from drying in the nozzles. Figure 3: Removing the plastic tapec00034768.jpg
  4. Push the new print cartridge into the appropriate slot at a slight angle, until it clicks into place. CAUTION: Do not attempt to push the cartridge straight into the slot. It must slide in at a slight angle. Figure 4: Inserting the print cartridgec00034769.jpg
Back to top Aligning the print cartridges The HP Officejet will prompt you to align the print cartridges every time you install a new print cartridge to assure high-quality output.
Feb 08, 2011 | HP Officejet 5510 All-In-One Thermal...
Printer # 5510 - How do I open to replace ink cartridge?
If you mean HP OfficeJet 5510 then the following tutorial is for you:
HP OfficeJet 5510 Replace Ink Cartridges
If you do NOT mean HP OfficeJet 5510, please do not fail my solution. Instead, start a new thread with your make, model clearly defined.
Jan 13, 2010 | Office Equipment & Supplies
Printer cartridge error message for office jet 5510 printer
I JUST HAD ADVICE FOR ANYONE THAT IS HAVING INK PRINTER CARTRIDGE PROBLEMS WITH THEIR HP 5510. MAKE SURE YOU ARE USING GENUINE HP INK CARTRIDGE. I HAVE BEEN HAVING PROBLEMS AND THE HP HELP DESK SUGGESTED THIS. NOW IT WORKS PERFECTLY!!!! JUST WANTED TO SHARE THIS INFO IN CASE ANYONE ELSE IS HAVING PROBLEMS!
Dec 11, 2008 | Office Equipment & Supplies
Mar 18, 2008 | HP Officejet 5510 All-In-One Thermal...
Hp Officejet 5610
check the belt drive, motor may need a replacement
Dec 16, 2007 | HP Officejet 5510 All-In-One Thermal...
REPLACING INK CARTRIDGS
For HP 5510 series for replacing the cartige, you need to lift the door just above the paper tray. Pull out the old cartidge, hold it so you can see the way it is inserted and click in gently in the same way.
Nov 19, 2007 | HP Officejet 5510 All-In-One Thermal...
HP Photosmart C7280 Laser Printer Logo
20 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
