Question about Powerfast Stanley TR110 Light-Duty Staple Gun
Staples are bent
When I staple one side of the staple is coming out bent
5 Suggested Answers
SOURCE: LOAD IT
pull out the spring at the end of the gun. turn the staple gun upside down. Lay the staples in the track pointed side up, push in the spring slide so that it locks. You are ready to staple.
Posted on Dec 07, 2008
  • 3 Answers
SOURCE: I have a PowerFast staple gun #31600. Can not
I got some staples stuck in my Powerfast 31600 too. I THOUGHT they were the right staples, I was wrong. You have to bend a little tab on the bottom of the stapler to let the slide come out of the back. Then you can remove the staples. Replace the slide and tap the tab back into place with a punch.
Posted on Aug 11, 2010
jesusandsean
SOURCE: TRYING TO LOAD A STANLEY
Have you looked at the spring for possible loss of pressure.
Posted on Mar 05, 2011
SOURCE: I have a stanley heavy
The staples load on the underside of the stapler.
Step 1 Push down and retract the stapler pushup mechanism.
Step 2 Position the stapler so that the moving hammer handle is down
and the staple exit is up
Step 3 Load the staples into the chamber on the bottom with the points up.
Step 4 Push the pushup mechanism into the locked position until it latches, you will feel the spring resistance as the staples are pushed into place.
Posted on Jan 16, 2012
Number for staples
make sure the delivery lot is clear of bent or misfired staples
only fit as many as will sit in the retainer pressure spring needs a little slack
put in longest sections of unbroken ones as possible
any small single sections will lead to a jam
May 02, 2016 | Staples Tools & Hardware - Others
Why won't my R23 release staples?
is it jamed with bent staples clear it out , open it and see if it is , or if the spring came off
Mar 07, 2015 | Staples Tools & Hardware - Others
I bought a Powerfix Profi hand stapler from Aldi store but cannot get replacement staples. There is no support from their website
You can use about any replacement staples from a D.I.Y. store:
8mm staples or 12mm U-type staples or 10mm T-type nails
Nov 03, 2011 | Tools & Hardware - Others
I get a Staple Detect error each time I try to scan a page. I've checked all of the rollers; they are fine. There are no staples anywhere in the picture. Can I turn Staple Detection off?
I presume you are using CpaturePerfect3 Scanning software. There is an option to stop checking of 'staples'.
In Canon 9080C staples are NOT detected by any metal detector! You'd notice a set of LEDs on one side and a set of sensors on the opposite side of the scanner wall, just above the paper tray. Incase there is a document thats stapled, while one sheet is going in, the other sheet will get lifted because of staple. Thus when there is obstruction in the LED sensor, it is presumed to be a stapled document. Conversely, even if a document is bent enough to block the sensors, the scanner assumes it as a stapled document. Ensure your documents are fairly flat.
S. Mohan, Chennai, India
Dec 30, 2010 | Canon DR-9080C Path-Through Scanner
Stanley sharpshooter
Look at the above picture of the stapler and follow the bottom of it from the left side over to the right side. Right there on the end of it is a small piece of metal that looks bent down, bull this out and set your row of staples on top of the sled you pulled out and then slide it back it. it is ready to staple something.
Jul 14, 2010 | Stanley CT10C Heavy Duty Staple Gun/Cable...
How to remove jammed staples in staple gun?
Take out the small bolt that is secured with a nut at the back of the gun (at the end where you feed the staples) -- then drop the inset. Now you have access to the jammed area. Clear out jammed staples and put the stapler back together. Easiest way is to hold the nut and turn the bolt from the other side.
Jun 16, 2009 | Arrow T50P ARROW STAPLE GUN
My T50M Staple strips break up in the gun and jam after 4-5 staples. This happens with old staples (10+ years) and with new staples that were purchased two days ago. Out of frustration I purchased a new...
The staples are held together with an epoxy. I have used staples that are older than 10 years. The problem is the gun. Check for dirt or a burk in the magazine as well as a bent pusher blade. My gun also had a problem loosing a screw and nut that attached at the blade guide.
Jun 12, 2009 | Arrow T50P ARROW STAPLE GUN
Electric stapler won't staple???
hi there. i hope i can help you? what you need to do is open the stapler up check for any stuck staples? where they come out. dont put two many in at any one time. please make sure you are putting the correct staples in? is there a sound when in normal use? if yes it may well be a blockage. also check the fuse in the plug just in case ? i hope this will help you,
May 01, 2009 | Kitchen Appliances - Others
Putting staples in thew easy shot
Squeeze the plastic clips that are located on the opposite side from where the staples come out. Squeeze and pull straight out. There is a rail inside, where the staples sit. When loading the staples, keep them in the same orientation as they are expected to come out when you are using it (sharp edge down).
Oct 26, 2008 | Comfort LLC Arrow 5650dtc Staple Gun &...
Powerfast Stanley TR110 Light-Duty Staple Gun Logo
Top Powerfast Tools & Hardware - Others Experts
Are you a Powerfast Tool and Hardware - Other Expert? Answer questions, earn points and help others
