Question about Cuisinart DLC-1 Mini-Prep Food Processor
Need replacement blade for a Krups 708 mini food processor
The blade is Old & has started to crack
  • Jess Gilman
    Jess Gilman Oct 10, 2017
    Looking for this blade. Krups 708
    Master:
  • 286 Answers
Check the link below, or also on Amazon.
Krups Food Processor Parts
Posted on Oct 11, 2017
5 Suggested Answers
SOURCE: stuck dough blade
On the DLC 7 Pro cuisinart the blade was removed by removing
the plastic bottom. Make sure the unit is unplugged. Remove the four rubber pads on the bottom. This was the hardest part because the pads are glued so securely that the inner rubber surface tears as it's removed. I used two flat blade screwdrivers and worked carefully, back and forth. Using a #2 philips, remove the four screws. Place the unit on its side and while inserting a screwdriver between a spoke and the motor frame gently turn the blade counter clockwise. Be careful not to put pressure against the cooling fins. Very little pressure was needed and the blade came right out. I might have been able to hold the shaft from turning without removing the bottom, by going through the vent slots in the bottom, but I was concerned with cracking the plastic. To replace the rubber pads I matched the design of the torn rubber pad with the shape (design) of the surface glued rubber and used thin two-sided tape.
Posted on Apr 05, 2008
SOURCE: Cuisinart Food processor
Go to the cuisinart website and you can buy replacement parts. You will have to buy the entire shaft not just the top but it is still good!
Posted on Jul 14, 2008
  • 24 Answers
SOURCE: food processor modle FP155OS, motor
Cont -23051554 / 23095757
UNIQUE SERVICES
MUMBAI--400008
Posted on Jul 31, 2008
  • 18 Answers
SOURCE: Plastic housing cracked Cuisinart DFP-11 Deluxe food processor
The Motor Shaft Cover parts are not shown on the Cuisinart website under parts, but they are available if you call Customer Service. These parts are quite inexpensive (often $3 + s&h). Have your model number ready, and they can get the right one out to you.
Posted on Dec 10, 2012
I have a mini food processor and the housing around the blade is cracking in several places. The blade could then dislodge. Is this normal
Don't think it's normal. Maybe the model you have is a bit too old and the housing which I aaume is made of plastic is starting to deteriorate
Sep 06, 2017 | Food Processors
Where can I get new chopper blade for my Krups food processor rotary 500/701A
You should be able to purchase spares from your original supplier.
Mar 21, 2015 | Krups Food Processors
Need Universal blade for Krups Rotary 500 Food Processor anyone please?
The blades are obsolete, you are probably wasting your time looking
Oct 02, 2013 | Food Processors
Krups Rotary 500 S shaped blade broken. Where can I get one
I'm also looking for a blade for the same food processor - the one with the serrated holes on both sides, we use it to grate potatoes. Can we do a swap? We do not use any of the other blades.
Apr 01, 2011 | Food Processors
Where can I get a replacement blade for a Krups rotary 500 food processor?
Which blade do you need? I am also having problems finding a replacement blade for the same machine - the only one we use is the one that grates but the centre melted recently. Can we do a swap?
Aug 30, 2010 | Krups Food Processors
I'm in need of a metal disc blade for the Black & Decker Mini Food Processor. The Model was called: Short Cut Food Processor Cat. No. F1 - CFP-10 is on the bottom of the mini food processor.
shopping.msn.com/.../food-processors/.../black...decker/.../forsale?...food-processors...Black...Decker -
www.amazon.com/Black-Decker...Processor.../B00005MF96 -
Jun 23, 2009 | Black & Decker Food Processors
Replacement slicing and shredding blade
Same thing happened to me. Did you ever find one?
Apr 04, 2009 | GE Food Processor
Cuisinart DLC-1 Mini-Prep Food Processor Logo
472 people viewed this question
Top Cuisinart Food Processors Experts
Colin Stickland
Colin Stickland
Greg Cann
Greg Cann
Are you a Cuisinart Food Processor Expert? Answer questions, earn points and help others
