Question about Samsung WA400PJHDWR Top Load Washers
Have a samsung WA400PJHDWR/AA, have it set on cold water setting, but hot water is going in, hoses are hooked up correctly
3 Suggested Answers
  • 3 Answers
SOURCE: no hot water
our samsung front loader is the same, thats because it has a ceramic plate in it and heats up the cold water during the cycle :)
Posted on Apr 16, 2010
  • 8 Answers
SOURCE: Just moved my Samsung WF448AAP, hooked it up and
you might have anti flood hoses that are braided going to the machine . remove them and make sure your water supply is coming through the water hoses.
Posted on May 06, 2010
Can I hook the wash and rinse to cold water hose?
Not sure what you are asking. If you want to wash and rinse you clothes in cold water only, there should be a water temp selection switch to allow you to do that. If you are asking if you can hook cold water hose to both ports on the washer back the answer is yes but it is easier to just cap off the hot side of the water valve on the back of the machine. Most machine water inlet valves are a 3/4 thread garden hose connection. Go to a hardware store or a Lowes/ Homedepot and ask for a screw on cap. They come in both plastic and brass. If you do cap the hot side of the inlet valve, make sure your washer has a cold only setting for wash and rinse and keep it set there. If it gets moved to hot nothing will fill or run.
Apr 15, 2015 | Washing Machines
Water mixing improperly set on cold and warm or hot water is being dispenced
Did you check to make sure the hoses are connected to the correct temperature spigot? They may have been swapped when the washer was hooked up. Really easy to fix, just unscrew the hoses that go from the faucets and switch!
Aug 19, 2010 | Kenmore 24032\24036 Top Load Washer
Maytag performa washer hot/cold cycles reverse, hooked up correct
This sounds like a cold water supply problem that's usually caused by a problem at the water inlet valve. First, remove the water supply hoses and check the small screens inside the water inlet valve. Make sure they are not clogged with rust or debris. Next, check the solenoids using a multimeter or ohmmeter. Check for continuity. A lack of continuity indicates a faulty solenoid and the water inlet valve assy will need to be replaced. I will attach a photo for reference. Hope this helps and best wishes.
Aug 10, 2009 | Maytag Performa PAV2200
Orientation of inlet pipes
I am not to sure if this answers your question but I think you are asking which way the hot and cold hoses connect to the wasing machine? if this is the case if you look on the back of the washing machine you will see stamped in the metel a H for hot connect the hot water inlet hose to this, If it is not marked, hook up the hot water hose to the washing machine and place the water temp selector to hot and turn machine on if hot water comes out you have the correct hose hooked up,if not then the cold water hose goes were you hooked up the hot water hose. hope this helps
Jun 24, 2009 | Washing Machines
Can't get anything but warm of hot water
If you set the washer for cold wash with a cold rinse, no hot or warm should enter the machine. If any hot or warm enters machine on cold / cold, check to see if the hot and cold hoses are hooked up correctly, and not reversed.
Jun 14, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Mavt634 cold water comes out the hot water inlet connection
Need to make sure that the water connections are correct - first that the hot water hose and cold water hose have not been interchanged and then if they are correct try interchanging the electrical connections to the water valves.
Mar 10, 2008 | Washing Machines
No hot water to wash
Is the hot water hot that is coming to the washer? Are you using the correct settings on the unit? If yes to both then either the solinoid water valve is bad or the timer switch unit is bad. Try going to a totally hot water setting. While turning on the machine feel of the hot water line at the machine and see if you notice a buzz or feel a click as you turn on the machine. On this setting does water run in and is it hot or cold. If water runs and it is cold try going to a total cold setting and see if you get cold or hot water. Is this a new setup or has it been working and stopped? If new, you could have the hoses connected backward. If you get water in both hot and cold settings but cold both ways then your hot water heater is not working....let me know....
Feb 10, 2008 | Frigidaire FEX831CS Top Load Stacked...
Samsung WA400PJHDWR Top Load Washers Logo
52 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
