Question about Yaesu FT-ONE Technical Workshop Manual
Ft 1 will not transmit
My ft 1 is about 25 years old ,been stored for 10 years covered. got it out ,but in line can hear but not transmit
Flywheel torque spec's for 1983 Ford F-100
Could it be a F-150 instead?
Ford Engine Bolt Torque Chart Bolt Torque Spec Chart for Ford Engines
These specs are for stock-type bolts with light engine oil applied to the threads and the underside of the bolt head. Moly and other lubes offer reduced friction and increased bolt tension, which will affect the torque figure. If you use after-market performance bolts like ARP's, you should follow the recommended torque specifications.
260, 289, 302 Torque Spec.
Fastener Type Torque Spec Main cap bolts 60-70 ft-lbs Outer main cap bolts 35-40 ft-lbs. Connecting rod bolts (40-45 ft-lbs. for 289 HP & Boss 302) Cylinder head bolts 65-72 ft-lbs. Rocker arms 17-23 ft-lbs. Intake manifold bolts 23-25 ft-lbs Oil pump bolt 23-28 ft-lbs. Cam bolts 40-45 ft-lbs. Cam thrust plate bolts 8-10 ft-lbs. Harmonic damper bolts 70-90 ft-lbs. Flywheel / flex-plate bolts 75-85 ft-lbs. Pressure plate bolts 35 ft-lbs. Front cover bolts 12-15 ft-lbs. 351W Torque Spec.
Fastener Type Torque Spec Main cap bolts 95-105 ft-lbs Connecting rod bolts 40-45 ft-lbs. Cylinder head bolts 90-100 ft-lbs. Rocker arms 17-23 ft-lbs. Intake manifold bolts 23-25 ft-lbs. Oil pump bolts 23-28 ft-lbs. Cam bolts 40-45 ft-lbs. Cam thrust plate bolts 8-10 ft-lbs. Harmonic damper bolt 70-90 ft-lbs. Flywheel / flex-plate bolts 75-85 ft-lbs. Pressure plate bolts 35 ft-lbs. Front cover bolts 12-15 ft-lbs. 351C, 351M Torque Spec.
Fastener Type Torque Spec Main cap bolts 95-105 ft-lbs. Connecting rod bolts 40-45 ft-lbs. (45-50 ft-lbs. For Boss 351C) Cylinder head bolts 105 ft-lbs. (125 ft-lbs. For Boss 351C) Rocker arms (non-adjustable) Rocker arms (non-adjustable) 5/16in. intake manifold bolts 21-25 ft-lbs. 3/8in. intake manifold bolts 28-23 ft-lbs Oil pump bolt 25 ft-lbs. Cam bolts 40-45 ft-lbs. Cam thrust plate bolts 9-12 ft-lbs. Harmonic damper bolt 70-90 ft-lbs. Flywheel / flex-plate bolts 75-85 ft-lbs. Pressure plate bolts 35 ft-lbs. Front cover bolts 12-18 ft-lbs. 360, 390, 406, 427, 428FE Torque Spec.
Fastener Type Torque Spec Main cap bolts 95-105 ft-lbs. Crossbolts for 406-427 40 ft-lbs. Connecting rod bolts 40-45 ft-lbs. (53-58 ft-lbs. For 406 and 427) Cylinder head bolts 80-90 ft-lbs. (100-110 ft-lbs. For 1963-67 427) Rocker arm shaft bolts 40-45 ft-lbs. Intake manifold bolts 32-35 ft-lbs. Oil pump bolt 12-15 ft-lbs. Cam bolts 40-45 ft-lbs. Harmonic damper bolt 70-90 ft-lbs. Flywheel / flex-plate bolts 75-85 ft-lbs. Pressure plate bolts 35 ft-lbs. Front cover bolts 12-15 ft-lbs. 429-460 Torque Spec.
Fastener Type Torque Spec Main cap bolts 95-105 ft-lbs Connecting rod bolts 40-45 ft-lbs. Cylinder head bolts 140 ft-lbs. Rocker arms (non-adjustable) 18-22 ft-lbs. Intake manifold bolts 25-30 ft-lbs. Oil pump bolt 25 ft-lbs. Cam bolts 40-45 ft-lbs. Harmonic damper bolt 70-90 ft-lbs. Flywheel / flex-plate bolts 75-85 ft-lbs. Pressure plate bolts 35 ft-lbs. Front cover bolts 12-18 ft-lbs.
Dec 18, 2015 | Ford Cars & Trucks
Torque spec's for the fly wheel
Dec 18, 2015 | Cars & Trucks
How to turn beep off when transmitting
all the beep is for is so people can tell when you are done transmitting. There should be a push knob or button or just a plain old knob that has R.B. printed next to it . Turn it off.
Apr 12, 2014 | Yaesu FT-2900R 75 Watt 2 Meter VHF Mobile...
Can you expand the freq. range of the cobra 25 CB 40 channel radio
Yes its possible to do with the EXPO kits.. or an eeprom. but beware of the FCC rules please. RX purposes' only not to be used for Transmiting..
May 05, 2013 | Cobra 25 LTD 40-Channel CB Radio
What is covered in the 100,000 mile/ 10 year warrenty for my 2004 optima
10-YEAR/100,000-MILE POWERTRAIN PROTECTION Covers repair or replacement of powertrain components (i.e., selected engine and transmission/transaxle components), originally manufactured or installed by Hyundai that are defective in material or factory workmanship, under normal use and maintenance. Coverage applies to original owner only, effective with 2004 model year and newer model year vehicles. On 1999-2003 model years, coverage applies to original owner and immediate family members (i.e., wife, husband, daughter, son, stepdaughter, stepson).
Second and/or subsequent owners have powertrain components coverage under the 5-Year/60,000-Mile New Vehicle Limited Warranty. Excludes coverage for vehicles in commercial use (e.g. taxi, route delivery, delivery service, rental, etc.).
5-YEAR/60,000-MILE NEW VEHICLE LIMITED WARRANTY Covers repair or replacement of any component manufactured or originally installed by Hyundai that is defective in material or factory workmanship, under normal use and maintenance.
The following components are covered for time and mileage limits indicated:
• Radio and audio systems (i.e., radio, compact disc player, DVD player, navigation system, and Bluetooth®): 3 years/36,000 miles
• Paint: 3 years/36,000 miles
• Battery: 3 years/unlimited miles (100% covered 2 years/unlimited miles; after 2 years and within 3 years, 25% cost of battery and 100% labor cost covered)
• Air conditioner refrigerant charge: 1 year/unlimited miles
• Adjustments: 1 year/12,000 miles
• Wear items: 1 year/12,000 miles (e.g., belts, brake pads and linings, clutch linings, filters, wiper blades, bulbs, fuses)
Mar 04, 2011 | 2004 Kia Optima
I need the head bolt torque specification for a 2005 aveo
install:
  1. The cylinder head should be cleaned and inspected prior to installation.
  2. Lightly oil all bolt and stud bolt threads before installation.
  3. Clean all gasket mating surfaces thoroughly.
  4. Install a new head gasket on the cylinder block. WARNING Always use new cylinder head bolts when installing the cylinder head or damage to the engine may occur.
  5. Install the cylinder head on the cylinder block.
  6. Tighten the cylinder head bolts in reverse of the removal sequence. Tighten the 2004 cylinder head bolts to 18 ft. lbs. (25 Nm). Tighten an additional 70°, plus 70°, plus another 50°. Tighten 2005 bolts to 18 ft. lbs. (25 Nm). Tighten an additional 60°, plus 60°, plus another 10°.
  7. Install the right engine mount. Tighten the engine mount attaching bolts to 22 ft. lbs. (30 Nm).
  8. Install or connect the following:
    • Intake manifold
    • Intake manifold support bracket. Tighten the bolts to 18 ft. lbs. (25 Nm).
    • Throttle cable
    • Surge tank coolant hose
    • Heater hose to cylinder head
    • Fuel feed line at the fuel rail
    • All vacuum hoses
    • Exhaust manifold
    • Rear timing belt cover
    • Timing belt tensioner. Tighten the bolts to 18 ft. lbs. (25 Nm).
    • Idler pulley. Tighten the bolts to 18 ft. lbs. (25 Nm).
    • Intake and exhaust camshaft gears. Tighten the bolts to 49 ft. lbs. (68 Nm).
  9. Apply a small amount of gasket sealant to the corners of the front camshaft caps and the top of the rear camshaft cover-to-cylinder head seal.
  10. Install the valve cover using a new gasket
  11. Align the timing marks on the camshaft gears.
  12. Align the mark on the crankshaft gear with the notch at the bottom of the rear timing belt cover.
  13. Install the timing belt and rotate the water pump clockwise to apply tension to the timing belt.
  14. Tighten the water pump bolts to 89 inch lbs. (10 Nm).
  15. Adjust the timing belt tension.
  16. Install or connect the following:
    • Spark plug wires
    • Upper and lower timing belt coversCrankshaft pulley. Tighten the bolt to 70 ft. lbs. (95 Nm), plus an additional 30°, then another 15°.
    • Accessory drive belt
    • Air cleaner housing
    • Radiator hoses
    • Front splash shield
    • Right front wheel
    • Coolant temperature sensor
    • Fuel feed line from fuel rail
    • IAT sensor
    • Intake manifold pressure sensor
    • DIS coil connector
    • Fuel injector connectors
    • ECM ground terminal
    • Negative battery cable
  17. Fill the engine with oil and coolant.
Apr 02, 2010 | 2005 Chevrolet Aveo
Does any one have the torque specs and sec for a 1999 dodge neon 2.0 dohc
Standard Head Gasket
Step 1: Tighten bolts 1-6 to 25 Ft. Lbs. (34 N.m) and bolts 7-10 to 20 ft. lbs. (28 N.m).
Step 2: Tighten bolts 1-6 to 50 Ft. Lbs. (68 N.m) and bolts 7-10 to 20 ft. lbs. (28 N.m).
Step 3: (Repeat Step 2) Tighten bolts 1-6 to 50 Ft. Lbs. (68 N.m) and bolts 7-10 to 20 ft. lbs.
(28 N.m).
Step 4: Tighten all bolts an additional 1/4 turn (DO NOT use a torque wrench for this step).
Multi-Layer Steel (MLS) Head Gasket
Step 2: Tighten bolts 1-6 to 50 Ft. Lbs. (68 N.m) and bolts 7-10 to 35 ft. lbs. (47 N.m).
Step 3: (Repeat Step 2) Tighten bolts 1-6 to 50 Ft. Lbs. (68 N.m) and bolts 7-10 to 35 ft. lbs.
(47 N.m).
Tightening sequence
* Clean and oil threads before installation.
Dec 02, 2009 | 1999 Dodge Neon
Brakes faded, caused accident '89 350 Ford RV
The original heat shiel must have fallen off. they all come with this. You are correct the fluid became supper heated and lost it ability to compress properly.
Aug 27, 2009 | 2007 Ford E-350 Super Duty Length XLT
Torque specs for the cylinder head
2004 ENGINE
Engine Mechanical - 1.6L (L91) - Aveo
SPECIFICATIONS
FASTENER TIGHTENING SPECIFICATIONS
Fastener Tightening Specifications
Application
Specification
Metric English
A/C Compressor Mounting Bolts 27 N.m 20 lb ft
A/C Compressor Mounting Bracket Bolts 50 N.m 37 lb ft
Air Filter Housing Bolts 12 N.m 106 lb in
Alternator Adjusting Bolt 20 N.m 15 lb ft
Alternator Adjusting Bracket Retaining Bolt 20 N.m 15 lb ft
Auxiliary Catalytic Converter-to-Exhaust Manifold
Nuts and Bracket Bolts
40 N.m 30 lb ft
Camshaft Cap Bolts 16 N.m 12 lb ft
Camshaft Gear Bolt 67.5 N.m 49 lb ft
Camshaft Pressure Plate Bolts 10 N.m 89 lb in
Connecting Rod Bearing Cap Bolts 25 N.m+30°+15° 18 lb ft+30°+15°
Coolant Pump Retaining Bolts 10 N.m 89 lb in
Coolant Temperature Sensor 20 N.m 15 lb ft
Crankshaft Bearing Cap Bolts 50 N.m+45°+15° 37 lb ft+45°+15°
Crankshaft Position Sensor Retaining Bolt 10 N.m 89 lb in
Crankshaft Pulley Bolt 95 N.m+30°+15° 70 lb ft+30°+15°
Cylinder Head Bolts - Camshaft Support Housing
and Cylinder Head Mounting Bolts
25 N.m+60°+60°
+60°+15°
18 lb ft+60°+60°
+60°+10°
Electronic Ignition System Ignition Coil Mounting
Bolts
10 N.m 89 lb in
Engine Mount Bracket Retaining Bolt 65 N.m 48 lb ft
Engine Mount Bracket-to-Engine Mount Retaining
Bolts
60 N.m 44 lb ft
Engine Mount Retaining Nuts 40 N.m 30 lb ft
Exhaust Flexible Pipe Bracket Bolts 40 N.m 30 lb ft
Exhaust Gas Recirculation Valve Adapter Bolts 25 N.m 18 lb ft
Exhaust Manifold Heat Shield Bolts 15 N.m 11 lb ft
Exhaust Manifold Nuts 25 N.m 18 lb ft
Flexible Plate Bolts 60 N.m 44 lb ft
Flexible Plate Inspection Cover Bolts 10 N.m 89 lb in
Flywheel Bolts 35 N.m+30°+15° 26 lb ft+30°+15°
Flywheel Inspection Cover Bolts 12 N.m 106 lb in
Front Muffler-to-Main Catalytic Converter Nuts 30 N.m 22 lb ft
Fuel Rail Retaining Bolts 25 N.m 18 lb ft
MITCHELL 1 ARTICLE - 2004 ENGINE Engine Mechanical - 1.6L (L91) - Aveo Page 1 of 330
http://www.eautorepair.net/app/PrintItems.asp?S0=2097152&S1=0&SG=%7BEEDCF... 3/30/2009
ENGINE MECHANICAL SPECIFICATIONS
Engine Mechanical Specifications
Intake Manifold Retaining Nuts 25 N.m 18 lb ft
Intake Manifold Support Bracket Lower Bolt-to-
Engine Block 40 N.m 30 lb ft
Intake Manifold Support Bracket Upper Bolts 25 N.m 18 lb ft
Lower Timing Belt Cover Bolts 10 N.m 89 lb in
Oil Pan Retaining Bolts 10 N.m 89 lb in
Oil Pressure Switch 40 N.m 30 lb ft
Oil Pump Retaining Bolts 10 N.m 89 lb in
Oil Pump/Pickup Tube and Support Bracket Bolts 10 N.m 89 lb in
Oil Pump Safety Relief Valve Bolt 36 N.m 22 lb ft
Oil Pump Rear Cover Bolts 6 N.m 53 lb in
Power Steering Pump Mounting Bolts 25 N.m 18 lb ft
Power Steering Pump Pulley Bolts 25 N.m 18 lb ft
Rear Timing Belt Cover Bolts 10 N.m 89 lb in
Spark Plug Cover Bolts 3 N.m 27 lb in
Spark Plugs 25 N.m 18 lb ft
Thermostat Housing Mounting Bolts 20 N.m 15 lb ft
Throttle Cable Bracket Bolts 8 N.m 71 lb in
Timing Belt Automatic Tensioner Bolt 25 N.m 18 lb ft
Timing Belt Idler Pulley Bolt 40 N.m 30 lb in
Transaxle Bell Housing Bolts 75 N.m 55 lb ft
Transaxle Brace Bolts 40 N.m 30 lb ft
Transaxle Torque Converter Bolts 65 N.m 48 lb ft
Upper Timing Belt Cover Bolts 10 N.m 89 lb in
Valve Cover Bolts 10 N.m 89 lb in
Application
Specification
Metric English
General Data
 Engine Type 4 Cylinder - In-Line
 Displacement 1598 cm3 97.51 in3
 Bore Stroke 79.0x81.5 mm 3.1x3.21 in
 Compression Ratio 9.5:1
 Firing Order 1-3-4-2
 Maximum Power - At 6200 RPM 77 kw/103.3 hp
 Maximum Torque - At 3400 RPM 145 N.m 106.9 lb ft
Cylinder Bore
 Diameter 79 mm 3.1 in
 Out of Round - Maximum 0.0065 mm 0.00025 in
 Taper - Maximum 0.0065 mm 0.00025 in
Piston
MITCHELL 1 ARTICLE - 2004 ENGINE Engine Mechanical - 1.6L (L91) - Aveo Page 2 of 330
Jan 07, 2009 | 2004 Chevrolet Aveo
Warranty Return
You will have to do this at their site
http://www.olympusamerica.com/cpg_section/cpg_servicerepair.asp
circuit city does not provide a manufactures warranty.
Jan 06, 2008 | Olympus Camedia C-350 Digital Camera
Yaesu FT-ONE Technical Workshop Manual Logo
Top Yaesu Radio Communications Experts
Steve
eradiostore
eradiostore
Nyte_Ryder
Are you a Yaesu Radio Communication Expert? Answer questions, earn points and help others
