Question about Sunpak 5800D Tripod
Missing parts two of the stoppers that hold the legs are missing and the top plate that screws into your camera is gone
2 Suggested Answers
info76732
  • 221 Answers
SOURCE: missing parts
This is known as a circlip.
You should be able to buy a replacement at any engineering shop for pennies.
Posted on Dec 10, 2013
I have a slim af2100 tripod head. How do you adjust the grip on the top plate as its slipping and won't hold the camera firmly?
The plate should screw to the camera, and the tighting screw would provide the right amount of tensio to hold the camera. Make sure the rubber gripper on the top if the quick release is not missing, if it is, then there is nothing to grip and it will slip.
Oct 26, 2014 | Photography
Tip
Turn Travel Trunk into a Coffee Table
Making your old travel trunk into a coffee table can be a very good feature to add to your decore and can be a great conversation starting piece. The best part is that turining it into a coffee table is not a very difficult thing to do.
Most travel trunks are a little too short to be a proper coffee table so you are going to want to find some table legs that you like and cut them down to the height that you want the table to be at. If they are wood you can even stain them to match the trunk or other furniture in your house.
Things you are going to need:
- A travel trunk
- 4 table leg straight top plates
- 4 table legs
- screws and a drill
If you are going to stain the legs then you should stain the legs before you start and allow them to dry.
Using the drill screw the table leg plates to the corners on the underside of the trunk. Once the legs dry screw them into the leg plates and flit the trunk over. And walla! you have a brand new vintage coffee table.
on Oct 21, 2013 | Luggage & Travel
Problem with Hamilton Beach Brewstation I have the water tank apart and I need to know how to put the spring and seal back in
I'll assume you have the pivoting arm with the rubber washer stopper apart. The rubber stopper pulls out of its housing. If you have that out you need to stuff it back in its hole with a small screwdriver. If not: the pivot for the arm rests in two grooves; the arm is held UP with a spring under the arm. (The top of the washer seals the dispensing hole from inside the pot.) The pot has an indentation the spring fits in, the arm also has a depression to hold the spring. It's tricky, but u can get everything lined up in order to put the holding plate (with the 2 screws) in place. (Hold the assembly in place with one finger and with the other hand put a finger thru the holding plate. Move the holding plate toward its final position and switch fingers holding the assembly in place. You're now holding the assembly with the finger that has the holding plate.) Position the holding plate and tighten the screws.
Jun 11, 2014 | Hamilton Beach Brewstation 48465
Hi, I have just bought the 190CXPRO3 carbon fibre
Little confused here. Is the head the part you want to detach from an older set of legs? Do you want to remove center post from new legs or old legs. The base plate remains on the center post/ Aftre removing 3 set screws, and you want to remove the head from the baseplate and it will not turn, grap slip joint pliers or a pipe wrench, wrap the jaws with cloth ( to prevent marring of head or legs) and while holding head with wrench, have someone else turn legs
Apr 26, 2011 | Manfrotto (190XB,128RC) Tripod
I have a Quickie LXI wheelchair. I keep having problems with the screws that hold the seating, upholstery on. The screws keep breaking off down in the sleeve that holds the screws. Part of them have...
My brother has Parkinson's and the involuntary movements of his feet cause the footpieces on the wheelchair to break. He has gotten through two sets of footrests in a short period of time.
Any suggestions.
Oct 26, 2010 | Quickie Wheelchairs Parts Breezy Ultra 4...
Screw that goes through plate holding camera has something missin
Does it have a slot going around the bolt below the threads, that would be for a "C" ring
Automotive part store would have it.
Mar 06, 2010 | Velbon Tripod with Twist Lock Legs and...
I purchased a second hand Miranda TP20 tripod from a charity sale for a few pounds. The screw plate mounting is missing fromn the top of the tripod - where can I purchase the part from?
the giottos 6E01 quick release plate will fit snug. i bought one for my miranda tp20 today. you can get them from harrison cameras or warehouse express.
Nov 06, 2008 | Vivitar Pink Vivicam 3188 Camera Great...
Bernina 180 Bobbin case spinning
Its called the bobbin stopper. Pop off your needle plate by pressing on the marked corner. In the back on the left you will see a small allen screw which must have come loose. Position the bobbin stopper in place and tighten that screw. If it already is tight, loosen it and reposition the bobbin stopper in the notch and tighten it back up.
Good luck.
Oct 04, 2008 | Bernina Artista 180
Solidex camcorder tripods
OKAY!! Thanks to the reply of "Baldwink", I was able to locate the product he suggested here in the U.S. from several dealers. This is the plate that mounts to the camera and allows easy removal/attachment to the tripod.
For the Solidex VT-90 tripod (the one I have and may fit others), order the Cullman CU-40470 Quick Release Plate. This is also described as the "Cullman Medium Quick Release 42mm" plate.
If you don't have the VT-90, measure the shoe plate area on top and remember that there will be at least one beveled (angled) area. Mine measured exactly 42mm square, so I am confident that the Cullman plate will fit. Also, the standard thread size for camera mounting is 1/4", but there are some cameras that use 3/8", so you might want to double check your camera for this spec.
I googled "cullman 40470 quick release" and found several U.S. dealers. The best price was from Adorama.com at $14 plus $5 ground shipping. Some dealers want as much as $33.
After nearly 20 years, I can use my Solidex VT-90 again!
Nov 15, 2007 | Photography
Sunpak 5800D Tripod Logo
Top Sunpak Photography Experts
Andrew Taylor
Andrew Taylor
richie46
Jay Plesset
Are you a Sunpak Photography Expert? Answer questions, earn points and help others
