Question about Powerfast Stanley TR110 Light-Duty Staple Gun
Staples aren't going in on both sides
The staple is crooked
5 Suggested Answers
SOURCE: LOAD IT
pull out the spring at the end of the gun. turn the staple gun upside down. Lay the staples in the track pointed side up, push in the spring slide so that it locks. You are ready to staple.
Posted on Dec 07, 2008
  • 3 Answers
SOURCE: I have a PowerFast staple gun #31600. Can not
I got some staples stuck in my Powerfast 31600 too. I THOUGHT they were the right staples, I was wrong. You have to bend a little tab on the bottom of the stapler to let the slide come out of the back. Then you can remove the staples. Replace the slide and tap the tab back into place with a punch.
Posted on Aug 11, 2010
jesusandsean
SOURCE: TRYING TO LOAD A STANLEY
Have you looked at the spring for possible loss of pressure.
Posted on Mar 05, 2011
SOURCE: I have a stanley heavy
The staples load on the underside of the stapler.
Step 1 Push down and retract the stapler pushup mechanism.
Step 2 Position the stapler so that the moving hammer handle is down
and the staple exit is up
Step 3 Load the staples into the chamber on the bottom with the points up.
Step 4 Push the pushup mechanism into the locked position until it latches, you will feel the spring resistance as the staples are pushed into place.
Posted on Jan 16, 2012
How do I change staples in a bizhub600
Depend on which staples. Saddle stich (example, Church service program with staples in the middle type) or booklet/corner with the staple on the left side or the corner. open finisher pull out the big section to the left side see to blue/green handles rear one is for corner staple which goes the fastest do to being used the most. when you pull them out there is a plastic guide they should follow if they don't line up power off the machine close all door power on machine. the stapler should go to default location which allows the staple cart. to be removed. DO NOT THROW THE CART AWAY!!!! YOU will be replacing the staples in the cart. Once out Push at he bottom pull the top. DO NOT PULL THE WHITE WRAP ON THE NEW STAPLE UNTIL INSTALLED in the cart. Had customer do that staples spilled on the floor customer installed the staples in the wrong direction.
Also be careful the is a tiny black accurator the mite come out keep it that's what tells the copier the staple is installed give to technician to reinstall.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Feb 10, 2014 | Konica Minolta Bizhub 600 750 Image...
The staples go through the material, but don't fasten or close on the back side
This is not a type of stapler that clinches the legs of the staples. There would have to be a lower jaw to do that. Like a desk top stapler has.
Nov 25, 2012 | Stanley TR250 H Heavy Duty Heavy Duty...
I bought a Powerfix Profi hand stapler from Aldi store but cannot get replacement staples. There is no support from their website
You can use about any replacement staples from a D.I.Y. store:
8mm staples or 12mm U-type staples or 10mm T-type nails
Nov 03, 2011 | Tools & Hardware - Others
Stanley light duty staple gun loads and shoots but staples not coming out. nothing jammed as far as I can see. Should I open it up and have a look at the interior? Thank you Denise
It sounds to me like you must have a staple that has seperated and probablygot stuck in staple feed shute' I wouold carefuflly remove side plate and see if there is a staple in there crooked or if their is is small metal chip left over from manufacture.I hope this helps you.THANK.
Apr 07, 2011 | Stanley TR40 Light Duty Tacker
I am trying to find a stapling machine capable of stitching some heavy duty cloth into an aluminium channel section. The legs on the aluminium are 1.5mm thick. Can you help?
Its not going to work you can;t staple aluminum mabey try a strip that over the cloth drill and pop rivit but nothing that i know of will shout throgh aluminum the staples aren;t stroung enough and wouldn;t hold even if you could get them through
Nov 22, 2010 | Stanley Heavy Duty Stapler, Cast Aluminum...
Swingline heavy duty stapler wont staple??? staples come out crooked
I'm having the same problem,...... Ugh,.. The stupid lil bendy thing that u put in the groove for the staples that u attach to the spring took me forever to put in place.. And I think it make have gotten out of place when I finally kept it in place long enough to close it,.
Aug 05, 2010 | Black & Decker 5700 Powershot Forward...
How to remove jammed staples in staple gun?
Take out the small bolt that is secured with a nut at the back of the gun (at the end where you feed the staples) -- then drop the inset. Now you have access to the jammed area. Clear out jammed staples and put the stapler back together. Easiest way is to hold the nut and turn the bolt from the other side.
Jun 16, 2009 | Arrow T50P ARROW STAPLE GUN
Instructions on unjamming swingline electric stapler model 270; jam is at the front of the stapler; staplers come out either broken, flaten or crooked and does not secure document.
First, are you using the recommended staples for this stapler? Many heavy duty electric staplers don't use "standard" desk staples. Second, try unplugging the stapler, unloading the staples, and if possible, reach a couple of fingers into the stapler and try manually pushing up on the staple head to see if you can get the driver blade to come down. Does it come down smoothly, or does it seem like there is something stuck in there? If you aren't sure about disassembling the unit (my usual method-but I'd recommend having the parts diagram handy), try using a flashlight to look at the underside of the staple head, where the staples come out - can you see anything stuck in there? If so, you might be able to use a small knife blade or small dental pick to get jammed staple pieces out.
Mar 03, 2009 | Staples Swingline® 36115 Staple Guns Tools...
Stanley Sharpshooter electric staple/nail gun-Hi-Lo knob moves
This is an ongoing problem with this tool. Between inadvertently moving it while using it and the constant rebound of the tool, the setting gets changed. The only suggestion I have is to duct tape the setting wheel into position.
Feb 12, 2009 | Stanley Staple/Nail Gun Elec
Powerfast Stanley TR110 Light-Duty Staple Gun Logo
Top Powerfast Tools & Hardware - Others Experts
john h
Are you a Powerfast Tool and Hardware - Other Expert? Answer questions, earn points and help others
