Question about Sunpak FP-38 Flash
Flash not working on fp38 sunpak - Sunpak FP-38 Flash
How does the Sunpak Auto 555 Thyristor Flash Unit work concrning a battery? Does it always need the ourside battery pack unit also?
When internal cells are fully charged it do not need external ones
http://www.photographyreview.com/mfr/sunpak/flashes/PRD_84012_3121crx.aspx
Aug 07, 2010 | Sunpak Auto 555 TTL Flash
Sunpack Compatibilty
ifyour nikon has a hotshoe it should work quite well. I use sunpak flash on both canon and olympus without any problems. Just connect to hotshoe and shoot.
Please rate my help++++Thanks for using FIXYA
Jun 03, 2010 | Sunpak 383 Super Flash
About parts of Sunpak 544 flashes!
IF you are working on them then you know the part number on the transformer. You may need to use Alibaba to see if the part is available in China.
Jul 31, 2017 | Sunpak Auto 544 Flash
Will my sunpak PZ4000 flash trigger voltage harm my nikon D50 circuitry?
The Sunpak PZ 4000 and 5000 were made for film cameras. I have one for my EOS film cameras. It works just fine. I know this series of flashes was not made for the digital cameras. It likely will not harm your camera if the flash is designed for your camera brand. But some functions will not work.
For example, do not use a flash for Minolta on a Nikon.
You risk damaging your cameras electronics or frying the flash.
Get their PZ 20, PZ 30, PZ40 or PZ 42X for your digital camera.
Oct 02, 2009 | Sunpak PZ 4000AF for Nikon TTL Flash
Can i use my sunpak 4000af with my canon rebel t1i?
Sep 30, 2009 | Sunpak PZ 4000AF for Canon TTL Flash
Need manual for Sunpak 4000AF Power Zoom Flash
Regarding using the Sunpak 4000AF flash with my Canon EOS Digital Rebel, I can't get the flash to fire. There seems to be no combinations of settings that works to make the flash work. Could a weak battery in the Canon cause this? Does it require some other wire connector between the flash and the camera?
I know this is old technology now, I have a pocket digital for most of my uses, but I'd like to try bounce flash again on my old Rebel digital, and so I've gotten out my old camera and the flash I had bought for it. I had bought the Sunpak flash years ago and I honestly don't remember if I got it to work back then or not.
Thanks for any advice.
Jun 25, 2009 | Sunpak PZ 4000AF for Canon TTL Flash
Sunpak PZ 4000AF for Canon EOS 35mm SLR body
Canon digital uses E-TTL metering for best flash results, the older Sunpak unit isn't compatible with this, so it is not fully compatible. It may work in manual mode - but won't be as good as a more modern compatible digital flash like the Canon or Metz (eg 58AF1 Canon) versions.
May 11, 2009 | Sunpak PZ 4000AF for Canon TTL Flash
Sunpak 2000 DZ
see if this helps:
http://www.flickr.com/groups/400d/discuss/72157603805472662/
Feb 10, 2008 | Sunpak 2000DZ Flash
Sunpak pz 4000 af
probably in MANUAL mode only.... my Nikon and Canon's work with the pz4000 (at a save trip voltage I may add) but in a manual mode as mentioned above.....
Jan 20, 2008 | Sunpak PZ 4000AF for Canon TTL Flash
Sunpak FP-38 Flash Logo
27 people viewed this question
Top Sunpak Cameras Experts
Doberman
teddyboy
Are you a Sunpak Camera Expert? Answer questions, earn points and help others
