Question about NEC Dth-16d-1 Dterm 80 Elite Ipk Phone W/lcd & Warranty
Phone receiver is dirty - NEC Dth-16d-1 Dterm 80 Elite Ipk Phone W/lcd & Warranty
Scooba 390 empty dirty tank
it is trash do to the fact that it is not receiving suction to pull the dirty water to the dirty resavore
Mar 24, 2014 | Eureka Atlantis 2590A Wet/Dry Vacuum
My samsung galaxy y duos switches itself off
Cell Phone Keeps Shutting Off
Vibrations on dirty battery contacts could be the cause of this problem. Remove the battery and clean the battery contacts with methylated spirits and the battery contacts in the cell phone.
Nov 06, 2012 | Samsung Galaxy Y Duos Samsung
Phone will not charge in charger
Does the phone have an indicator light which should light up when charging? If so, and its not lighting up, investigate the electrical contacts. Usually small pins in the base of the phone. Sometimes bent or maybe debris in socket or could be dirty. They are very low voltage, so no risk but easily interrupted by poor contact.
if no luck, test charger output with test meter - could be a broken charger or electrical fault in the cord.
Jan 18, 2012 | Bell Cordless Telephone 2.4 GHz
Help with Sharp Fax UXP100 . When sending a fax they are going very, very slow. What should I troubleshoot? Thx
Check your phone line by removing fax and plugging a normal handset into the line socket and then listen to line. If a line has noise on it, it will slow transmission down, it can also cause wiggly lines on transmitt and receive, if this is the case, it needs to be dealt with by your phone line provider, just report a noisy line
Having the machine set to fine in transmission settings can also cause slow faxs, and a dirty scanner glass can also cause receiver image to have marks on received image but it is normally marks down the page
hope my good deed free for the day helps.
cheers
Soulvisitor
Nov 22, 2011 | Sharp Office Equipment & Supplies
Intermittant buzz/distortion from receiver through speakers
This could be multiple issues and needs to be diagnosed on site.
Dirty power can cause this, nicks in any speaker wire, faulty speaker, faulty receiver, etc.
Feb 20, 2011 | Denon AVR-1804 Receiver
I have a Sony Ericsson W580i that last Thursday its battery went flat then i went to connect it to battery charger and it wont charger up all it does it flash the red light at side and vibrate and wont...
I had the same problem. Your connection is dirty. Take a toothbrush and brush the charger receiver vigorously. If you can see that there is some buildup on the connector scrape it off with a knife. This worked for me.
Oct 08, 2009 | Sony Ericsson w580i Cellular Phone
Spilled wine on cordless receiver. It works but
call to the retailer he will setup all theses hings
Sep 16, 2009 | Lands Phones
White space in middle of faxes sent or received
Printing irregularites on sent faxes are due to spots or a dirty scanner.
Spaces on received faxes are due to a dirty drum, corona wire, or a failing or improperly installed toner cartridge. A new cartridge should be gently shaken back and forth sideways prior to installation.
Jun 23, 2009 | Brother IntelliFAX 4750 Plain Paper Laser...
Fax not clear
Noisy phone line can cause this or it could be drum cartridge or even fuser, check phone line for noise by listening to it, if noisy report it or put on required filter if using ADSL.
Also test machine when doing a copy, and when printing a report, is there a problem too?
without more info you fault is one of these.. line, drum cartridge , fuser or dirty scan glass (where originals are fed.)
Nov 08, 2007 | Panasonic KX-FL511 Plain Paper Laser Fax
NEC Dth-16d-1 Dterm 80 Elite Ipk Phone W/lcd & Warranty Logo
18 people viewed this question
Top NEC Lands Phones Experts
Brian LaDuca
george  peters
george peters
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
