Question about Canon Office Equipment & Supplies
Ip2700 print slow - Canon Office Equipment & Supplies
My Canon PIXMA IP2700 Prints blank pages.what can I do?
click on devices and printers, right click on the printer image , then trouble shooter and follow instructions. the heads may be blocked if not used for some time . I have been told there is a chip that stops the head from working after several cartridge changes.
Apr 19, 2015 | Canon Pixma iP2700 InkJet Photo Printer
Stripes in printing pictures in canon ip2700
Run the utility maintenance printer coming with the printer , for to clean the head from your printer.
God bless you
Jul 28, 2013 | Canon iP2700 Inkjet Photo Printer
My canon ip2700 colour wont print
how to overcome my ip 2700 canon 006 error?
May 10, 2012 | Canon Pixma iP2700 InkJet Photo Printer
I can't print with my cannon ip2700 with only colored ink, what can I do?
There is no way to print with only one catridge in Canon product... thanks
Aug 26, 2011 | Canon Pixma iP2700 InkJet Photo Printer
Canon ip2700 after refill of Black cartridge ink status still shows 'low' and print is very poor - breaks, incomplete - as ink running out. How to reset ink level, or to disable warning, and to get print...
For your ip2700, even if you reset your refilled cartridge, they are not going to be usable.
After 4~5 times of color refill, you will see e5 error that cartridge is not readable anymore.
So you need to replace your cartridge with new one somehow.
If you would like to save money, try refill kit by "ROADINK".
Not only they are easy, but also the printing quality is good.
For your better understanding pls check out my youtube video.
And will see how easy ink refill can be done.
Apr 20, 2011 | Canon iP2700 Inkjet Photo Printer
I can't print my documents. My Printers model is Canon IP2700 and it says there that the error code is 5100. How can I fix the problem? we need the print immediately. Is there any solution we can fix it?
Usually, error code 5100 means some kind of obstruction in the print path, maybe something that had fallen inside the printer, the gears being jammed by something that got loose inside the printer, or ink on the clear plastic encoder/timing strip (a plastic strip about 1/4" in width that you can see running from side to side and connects to the print head).
Clean the plastic strip with alcohol , check if there is nothing blocking the head carriage set (sometimes kids play and hide toys, pens, coins, inside printers, VCRs or any other devices that have "doors"...).
Hope this info may help you!
Mar 12, 2011 | Canon Pixma iP2700 InkJet Photo Printer
12 people viewed this question
old marine
old marine
