MAV-39 washer fills with water will not run door is shut
bozcro
  • 867 Answers
SOURCE: whirlpool duet washer fills with water when not running
one of the control valves (hot or cold) is not closing the water supply, most likely leaking so the electronics are good. one of the valves needs replacing, but if you dont want to spend the money just shut the water supply off at the water supply taps.
Posted on Jul 17, 2009
  • 574 Answers
SOURCE: washer fill water will not shut off
It may be that the water inlet valve isnt cutting off completely or it,s not getting a signal to cut off.
Posted on Sep 13, 2009
Testimonial: "thanks for your help"
  • 6277 Answers
SOURCE: After washing -washer slowly fills with water and
I would suspect the water inlet control valve may be malfunctioning- not closing (its default no power position).
Quick temporary fix, although tiresome, turn whichever tap, hot or cold, off when washing finished. You've probably already thought of that!
In the meantime I would suggest a service call is required ;-0(
John C
Posted on Mar 02, 2011
Testimonial: "Thanks- I felt sure water cannot get into the washer unless this valve is mal-functioning--checked price on Whirlpool site--$59.00--cut price to 56"
  • 207 Answers
SOURCE: Kenmore washer 90 series continue
Sounds like the fill switch needs to be replaced. A good way to test it is to set your machine on low fill and see if it fills past 3/4. If it does, it's the fill switch.
Posted on Aug 20, 2011
chrispolkele
  • 4342 Answers
Our people make the difference
    Verified Fixya Pro
    SOURCE: Frigidaire front load washer won't fill with water
    http://www.washerhelp.co.uk/diy-repair-help.html
    Posted on Aug 21, 2012
    Hi, I have a Maytag Alantis Washer (model: MAV
    Does it not spin just in the final cycle or not at all during the wash cycle? Also, does the wash cycle agitate normal?
    Regards,Richard
    Nov 07, 2011 | Maytag Washing Machines
    My washer fills and doesn't stop. I try to advance it to the spin cycle but none of the cycles work. I changed the lid switch because it wouldn't fill at all. Now it fills and nothing else. Tested...
    The fill switch is bad. That's the only "safety" on the washer that will shut the water off after reaching desired depth. To test it, run your machine on the various water levels. For example, start out on the low setting. If the water doesn't shut off after the tub is half full, then it's the fill switch inside the unit next to the tub.
    Sep 13, 2011 | Washing Machines
    I get error FE- book says unplug and call a tech. Is this something I can fix myself?
    FE error means that the water is filling past it's set point. You may have a broken water valve that won't shut off when it's in the filling mode. You can check by running the washer and watching the water fill. If the water level fills above the bottom of the glass, you have a water valve that's not shutting off. Replace the water valve.
    Aug 21, 2011 | LG WM2487H Front Load Washer
    I have a GE washer that during the spin cycle / rinse on my washer the water won't shut off and will run and run until I turn the water valve off. This occurs during spin cycle when it adds water but...
    water valve or water presher switch my vote is water valve start washer when water is filling unplug from wall if water is still running it is the water valve if water stops it has to do with presser switch let me know what happens I will walk you threw how to repair thanks
    Jun 24, 2011 | GE WPGT9360EPL Top Load Washer
    After washing -washer slowly fills with water and runs out the door--not every time it is used. First noticed clothes still wet needing to run spin cycle--then washer leaked on floor over week end and...
    John C
    Mar 02, 2011 | Whirlpool Duet GHW9150P Front Load Washer
    Model mav6000awu has a sound of water rushing when machine finished filling and running.started doing this recently.
    most maytag toploader mav did have that sound if it drain & spin your ok i have the same washer and it has the same sound & work fine that washer will only last about 10 years (i work for maytag )
    Feb 18, 2009 | Maytag Washing Machines
    Wash cycle will not start
    you may have leaned on lid and damaged the lid switch , so the washer thinks the lid is open all the time unit will fill then stop with lid up.
    Apr 13, 2008 | Maytag Atlantis MAV6000 Top Load Washer
    Washing Machines Logo
    11 people viewed this question
    Top Washing Machines Experts
    Gerry Harvey
    Gerry Harvey
