Question about Everlast Pilates Door Gym
Everlast Door Gym manual - Everlast Pilates Door Gym
Everlast ev800 manual
I would suggest either contacting Everlast or Impex (I believe they manufacture Everlast's home gyms). I also found an assembly manual for EVE-900, which may be similar. You can find it here: http://catalog.impex-fitness.com/images/eve-900%20manual.pdf
Everlast
Phone: 800.821.7930
(Monday - Friday 8:00 a.m. - 5:00 p.m. CST)
Live Chat: (Monday - Friday 8:00 a.m. - 5:00 p.m. CST)
Email: orderpro@everlast.com
Fax: 800.480.0348
Mailing Address:
Everlast Customer Service
1900 Highway DD
Moberly, MO 65270
Impex
Tel: (800) 999-8899
Fax (626) 961-9966
www.impex-fitness.com
info@impex-fitness.com
Nov 09, 2013 | Everlast Exercise & Fitness
Tip
SEWING MACHINE BOBBINS
Drop in bobbins rotate clockwise. Others - front and side loading rotate counterclockwise.
The front/side loading bobbin.
1. Remove bobbin case
2. Load with bobbin (rotating ccl).
3. Place thread under tension spring.
4. Adjust until you can dangle bobbin from finger and bob around. It should extend one inch when done.
5. Replace bobbin case and bobbin.
The top loading bobbin.
1. Put bobbin in. (rotating clockwise)
2. Remove throat plate.
3 Adjust tension by slightly tugging on the thread.
There should be resistance but not too much. This may take a while to get it right.
4. Replace throat plate.
on Feb 21, 2015 | Everlast Door Gym with Adjustable Tension
Exercises
all depends from your a)age b) experience c) phisical conditions .
I can recommend you visit your doctor, and explain and then go to some GYM.
God bless you
Jul 21, 2012 | Everlast Pilates Door Gym
I have just purchased an Everlast EV1500 multigym and it has no instructions manual with it - does anyone know where I can get one from or even if I could download one? Max
please send the manual for panasonic iron box for NI-S100ts
without the manual iam not able to use the iron box.
chandrasekar
chennai
india
Feb 08, 2011 | Kitchen Ranges
How to put the pullies together.everlast ev 1000 multi gym
i have lost my everlast 1000 gym user manual any idea where i can get a new one from . Thanks keithyjones@live.com
May 11, 2010 | Exercise & Fitness
How do I fix the cable on my everlast one-gym model OG-TS 100
Go to a good hardware store and have them make one for you.
Apr 08, 2010 | Exercise & Fitness
How do I fix the cable on my everlast one-gym?
Go to your local yellow pages and find a hoist & rigging store. Call and ask if they can make cables for you. then take a number pictures from different angles of your unit to show how the other cables are strung. then proceed to take the old cable off. Good Luck!!
Everlast Pilates Door Gym Logo
Top Everlast Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Everlast Exercise and Fitnes Expert? Answer questions, earn points and help others
