Question about Moen Plumbing
Replacemoenbathroomsinkwasher replacing washer moen bathroom sink what special tool to use to get handle off.
  • 11 Answers
SOURCE: Moen Villeta 2 handle bathroom faucet, need to disassemble
hold the handle and twist the piece below that doesnt turn, anti-clockwise, it should unsrew and the handle should pull off.
Posted on Feb 11, 2009
  • 374 Answers
SOURCE: Bathroom Faucet Handle Fell Off
There is a small allen screw in the base of the handle- the part the stem screws into to turn the water to the on position. If you have lost the one for your handle call moen at 1-800-289-6636 in the US. Their hours are Mon-Fri 8-8 EST and Sat 8-18:30 or follow this link MOEN. In Canada 1-800-465-6130 and hours are Mon-Fri 7:30-17:00 EST.
Posted on Mar 13, 2009
  • 659 Answers
SOURCE: Reinstalling a handle on an older Moen 84206
Here is the owners manual for your faucet that will guide you through putting the handle back on. Good luck!
http://www.moen.com/shared/pdf/instruction_sheets/INS060B.pdf
Posted on Apr 07, 2009
  • 6 Answers
SOURCE: can't remove moen bathroom faucet assembly to
If you are dealing with the type of Moen faucet I think you are, what you need to do is remove the pop-up rod. do this by loosening the locking bolt on the linkage under the sink and pulling the rod out from the top. Once the rod is out you will need to find the correct size allen wrench which goes into the center hole. there is a mounting bolt in there that needs to be unscrewed. Easy when you know how.
Posted on Jun 17, 2009
motor1258
  • 6674 Answers
SOURCE: moen single handle kitchen faucet, Hot water and
Hot water line connected to left side of faucet? Did you replace tap set, or just cartridge? Cartridge may be out 180 degrees.
Posted on Dec 29, 2009
Have a moen brantford bathroom faucet. One handle has become very hard to turn. The hot water side turns fine, but you have to use muscle to turn on the cold. Does the handle need to be replaced or the...
It usually takes a special tool to remove a Moen cartridge. Just getting the handle off can be tough. How long have you had this unit? maybe it would be cheaper just to replace the whole thing. My last Moen lasted a good twenty years, still working good, but finally starting to corrode. Good product.
Nov 30, 2013 | Moen 6610 Brantford Two Handle Lavatory...
I need replacement part for bath sink cartridge 4570
The Moen 1225 or 1200 cartridges are the same except the 1200 is brass in stead of plastic. They will fit most Moen single handle faucets. If it is a two-handle faucet, the 1224 cartridge will fit most two-handle models unless it is a fancy widespread faucet more than about 15 years old. I don't know the model numbers for those cartridges. All of these cartridges require a removal tool if you can't get them out with a pair of pliers.
Dec 09, 2011 | Moen Soap & Lotion Dispenser 3910S
Moen 2 handle bathroom faucet is leaking out of base of the left handle
There is a plastic retainer not with two tabs used for removal. You will need a removal tool to get this retainer off. Any plumbing supply that carries Moen should have this tool.
After removing the retainer nut, the cartridge pulls right out. Good luck!
May 23, 2017 | Moen Kingsley Two Handle Bathroom Sink...
My moen bathroom sink handle came off. The srew into the handle comes up from the stem? how do I access the srew to reinstall handle? Thank-You
pop the cap off top of handle with steak knife, screw is underneath,unless yours is like the one pictured,then its an allan screw from the back.you had one when it was installed and,these can be really stuck
Jan 28, 2011 | Moen Bathroom Sink Faucet - 4-inch...
My waltec bathroom sink was leaking now that i messed with it ,its running by itself how do i fix this problem
It would help to know where is was leaking and what you "messed with"?
But in general, the idea is to replace the washers.
To do that, first turn off the water under the sink.
Then you first remove the handle on the leaking side.
There is often a small metal or plastic cover over a phillips screw.
Then remove the metal cap around the handle stem by unthreading or lifting up.
Then you can remove the valve by turning it as if to make the water go on.
It will have a washer on the bottom, held on with a screw.
Remove the screw, get a new washer, and then replace.
http://www.moen.com/shared/pdf/instruction_sheets/ins1923a.pdf
Dec 20, 2010 | Moen Kingsley Two Handle Bathroom Sink...
My classmate
Moen Monticello 4-inch centerset bath faucets can be repair easily with only a screwdriver and adjustable wrench. Turn the water off to the both sides of the faucets under the sink. Open both the hot and cold-water valves to alleviate any remaining pressure. Remove the handles by grasping the base of the handle and turning it counterclockwise.( This works for both lever and cross handles). Loosen the Moen faucet cartridge bonnet nut with an adjustable wrench by turning it counterclockwise to the left. Pull the stem from the faucet by hand and replace. Reinstall the bonnet nuts and handles. Turn the water back on and test the faucet for leaks. The Moen Monticello faucet comes with a limited lifetime warranty. Try calling Moen to get your replacement parts free.
Dec 09, 2010 | Moen Bathroom Sink Faucet - 4-inch...
Moen bathroom faucet leaks from the cartridge. Unable to remove the cartridge. Do I need a special tool?
Usually not a special tool needed. Moen will provide FREE replacements for you, call them up and they will ship to your door, free.
Sep 28, 2010 | Moen & Replacement Cartridge
Facet leaking
You can purchase a replacement cartridge for that... most hardware stores or places like Home Depot or Lowe's will have them. Take in the old acrtridge or the model of thefaucet. Some of them need a special puller to get the old cartridge out..
heatman101
Jul 11, 2010 | Moen & Villeta Two Handle Lavatory Faucet
How do I get to the valve cartridge to replace it?
how to replace moen cartridge for two handle kitchen faucet ... cartridge for two handle kitchen faucet exporters,how to replace moen cartridge for two handle kitchen faucet suppliers,how to replace moen cartridge ...cn-faucet.com/ kp-how-to-replace-moen-cartridge-for-two-handle...
Mar 17, 2010 | Moen Bathroom Sink Faucet - 4-inch...
HOW TO DISMENTLE OR REPLACE A MOEN SINGLE LEVER
shut water off at stops under sink. Unscrew water supply lines from directly below handles. Above them you will find plastic nuts, remove them. Disconnect pop/up lever and you should be able to lift faucet from sink.
Sep 24, 2009 | Moen & One Handle Tub & Shower Faucet
Plumbing Logo
22 people viewed this question
Top Moen Plumbing Experts
john h
Don Numinen
Don Numinen
Mike
Are you a Moen Plumbing Expert? Answer questions, earn points and help others
